4th July 2020, 19:23 | #7681 | Link |
x265 v3.4+11-gee5a266a1 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.1.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/master https://bitbucket.org/multicoreware/x265_git/commits/ee5a266a1055222faff6c319c7589ddcbef3f9d1 |
5th July 2020, 12:48 | #7682 | Link |
QfG Group Germany
Have anyone an idea, how i can change the Info string in the sourcefiles of the Encoder? For Example, it likes so:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 26 min Bit rate : 7 441 kb/s Width : 3 840 pixels Height : 1 608 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.050 Stream size : 4.50 GiB (65%) Writing library : x265 3.2: QfG-Edition Encoding settings : Encoded-by-QfG / CRF=16.0 / High-Quality Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 712 cd/m2 Maximum Frame-Average Light Level : 355 cd/m2
6th July 2020, 07:47 | #7684 | Link | |
6th July 2020, 10:02 | #7685 | Link | |
I am planning to buy a Ryzen 7 3rd gen. Which type of build will be the best for it? Any idea? Thanks in advance |
6th July 2020, 10:21 | #7687 | Link | |
here : http://www.mediafire.com/file/p4rf0s...2_x64.zip/file
6th July 2020, 19:17 | #7689 | Link | |
10th July 2020, 23:50 | #7694 | Link | |
For adaptive quantization, it's more that the human eye can see errors in frequencies a lot more clearly in smooth areas than textured ones, because that creates edges that weren't there before. Blocking and ringing are a lot easier to see in an area where there shouldn't be detail at all. A bunch of foliage can have slight frequency errors which get masked by all the edges and detail already there. |
11th July 2020, 09:18 | #7695 | Link |
Pig on the wing
I find that all those special edge related AQ modes generally mess any noisy flat areas of the image, causing the floating wall of noise defect I strongly dislike. I don't know if tuning the strength helps but mode 1 still works best for me. Strength 0.8-1.0, lower for noisier material, higher for clean.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 11th July 2020 at 09:26. |
11th July 2020, 13:24 | #7696 | Link | |
Herr
which is clean (I assume that they mean clean) cartoon, sets (among other things), --aq-strength 0.4 Last edited by Forteen88; 11th July 2020 at 15:20. Reason: clarification |
11th July 2020, 14:03 | #7697 | Link |
Pig on the wing
If I'm not entirely mistaken, the whole idea of aq-strength is to adjust the amount of bits shifted from more complex blocks (like ones with edges etc.) to simple ones (like a flat background).
From an old x264 thread: High AQ strength retains more gradients but produces ringing. Low AQ strength preserves edges but produces banding. My theory here is that the random noise itself is complex and could actually be harder to compress than something with clear edges and detail. Lowering the strength should not cause excessive banding as the flat areas with noise already attract bits and are not really flat in terms of the encoder. In some tests I did, lowering the strength from 1.0 to 0.8 can cause the bitrate to drop around 10% with other settings remaining the same. With animation and cartoons, aq-mode 2 could well work because they are very different beasts compared to normal, real-life footage.
11th July 2020, 15:27 | #7698 | Link | |
Aq mode 4 also works well, but it's also quite a bit slower. |
11th July 2020, 20:04 | #7699 | Link |
Netflix's Sol Levante is the first creative commons licensed 4K HDR anime-style animation I've seen yet, and makes for some very interesting aq-mode and aq-strength testing.
https://netflixtechblog.com/bringing...e-fa68105067cd And don't forget --hevc-aq, aka --aq-mode 5. I suspect, but have not demonstrated, it could be quite good for line-art style animation. While lines are blurring a lot in the computer-assisted era, the classic differential attributes of cel animation are:
Just look a the --log-level 2 .csv of natural image and cel content and you'll see how different the distribution of block sizes and types is. |
12th July 2020, 16:22 | #7700 | Link |
Can someone tell me how to properly use the 2pass options 'analysis-save' and 'analysis-load' ?
I tried with: Code:
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p10le -strict -1 -vsync 0 -f yuv4mpegpipe - | "I:\Hybrid\64bit\x265.exe" --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --pass 1 --slow-firstpass --bitrate 1500 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt470bg --stats "E:\Temp\test_generated.stats" --analysis-save "E:\Temp\test_generated.analysis" --analysis-reuse-level 6 --no-multi-pass-opt-analysis --output "E:\Temp\test.265" Code:
y4m [info]: 640x352 fps 25/1 i420p10 sar 1:1 unknown frame count raw [info]: output file: E:\Temp\test.265 x265 [info]: HEVC encoder version 3.4+7-g38774073d x265 [info]: build info [Windows][GCC 10.1.0][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [warning]: analysis-load-reuse-level can be set only when analysis-load is enabled. Resetting analysis-load-reuse-level to 0. x265 [info]: Main 10 profile, Level-2.1 (Main tier) x265 [info]: Thread pool created using 16 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 4 / wpp(6 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 25 / 250 / 40 / 5.00 x265 [info]: Cb/Cr QP Offset : -2 / -2 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 0.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-1500 kbps / 0.60 x265 [info]: tools: limit-modes rd=3 ssim-rd psy-rd=2.50 rdoq=2 psy-rdoq=10.00 x265 [info]: tools: rskip mode=1 signhide tmvp b-intra strong-intra-smoothing x265 [info]: tools: deblock(tC=-1:B=-1) sao stats-write x265 [info]: frame I: 3, Avg QP:16.35 kb/s: 3518.73 x265 [info]: frame P: 120, Avg QP:13.21 kb/s: 3109.91 x265 [info]: frame B: 306, Avg QP:17.58 kb/s: 770.49 x265 [info]: Weighted P-Frames: Y:0.8% UV:0.8% x265 [info]: consecutive B-frames: 3.3% 0.0% 58.5% 21.1% 17.1% encoded 429 frames in 15.97s (26.86 fps), 1444.09 kb/s, Avg QP:16.35 Code:
x265 [warning]: analysis-load-reuse-level can be set only when analysis-load is enabled. Resetting analysis-load-reuse-level to 0. Code:
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p10le -strict -1 -vsync 0 -f yuv4mpegpipe - | "I:\Hybrid\64bit\x265.exe" --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --pass 2 --bitrate 1500 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt470bg --stats "E:\Temp\test_generated.stats" --analysis-load "E:\Temp\test_generated.analysis" --analysis-reuse-level 6 --no-multi-pass-opt-analysis --no-dynamic-refine --refine-ctu-distortion 1 --output "E:\Temp\2020-07-12@16_54_18_4110_03.265" Code:
y4m [info]: 640x352 fps 25/1 i420p10 sar 1:1 unknown frame count raw [info]: output file: E:\Temp\2020-07-12@16_54_18_4110_03.265 x265 [info]: HEVC encoder version 3.4+7-g38774073d x265 [info]: build info [Windows][GCC 10.1.0][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [warning]: analysis-save-reuse-level can be set only when analysis-save is enabled. Resetting analysis-save-reuse-level to 0. x265 [info]: Main 10 profile, Level-2.1 (Main tier) x265 [info]: Thread pool created using 16 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 4 / wpp(6 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 25 / 250 / 40 / 5.00 x265 [info]: Cb/Cr QP Offset : -2 / -2 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 0.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-1500 kbps / 0.60 x265 [info]: tools: limit-modes rd=3 ssim-rd psy-rd=2.50 rdoq=2 psy-rdoq=10.00 x265 [info]: tools: rskip mode=1 signhide tmvp b-intra strong-intra-smoothing x265 [info]: tools: deblock(tC=-1:B=-1) sao stats-read x265 is running, but seemingly not doing anything. Also tried with HEVC "encoder version 3.4+12-geff904199" same effect. -> Can someone tell me how to properly use the 2pass options 'analysis-save' and 'analysis-load' ? Cu Selur |
