Old 13th November 2013, 19:15   #221  |  Link
Wilbert
Did you ever get SoundOut() to work? You mentioned that you might try to recompile the plugin.
Haven't tried yet. Will do so on Sunday.
Wilbert is offline   Reply With Quote
Old 13th November 2013, 19:20   #222  |  Link
Richard1485
Thanks. Now I know that I haven't overlooked an update to the plugin.
Old 13th November 2013, 21:13   #223  |  Link
Gavino
Avisynth language lover
SoundOut() works for me with 2.6a4.
Also worked for poisondeathray (post #100).
Does it always fail for you, Wilbert, or is it dependent on script contents?
I only tried a simple test - perhaps you need something which heavily exercises the audio cache to provoke the error?
EDIT: I notice now Jeff B above reports failure is source-dependent.
GScript and GRunT - complex Avisynth scripting made easier
Gavino is offline   Reply With Quote
Old 23rd November 2013, 20:25   #224  |  Link
Wilbert
I guess so, but i don't remember. A simple Tone() didn't work either. Anyway I managed to compile it finally: http://forum.doom9.org/showthread.ph...82#post1654982. It was a bit more involved than ultim said since some header files were missing too among some other things. Let me know if there are any issues.
