2nd November 2020, 10:58 | #60561 | Link |
BT.2020 displayed as if it was P3 is washed out, BT.2020 is very large and anything else assumes the content covers a much smaller range.
madVR options explained |
2nd November 2020, 11:56 | #60562 | Link |
but if you don't tell madVR that the display is calibrated to X it will convert it to bt 709 with SDR output.
to get it washed out you have to set this display is calibrated to something over BT 709 but he said the display can't be set to that so why would he do that? |
2nd November 2020, 23:34 | #60565 | Link | |
2nd November 2020, 23:50 | #60567 | Link |
Hi, just looking at black levels again as seem to have some odd issues, just want to get my head straight again first.
1 Full, Full, Full -- Video Level CORRECT : WtW & BtW Clipped, Single scaling 2 Full, Full, Limited -- Video Level WRONG : Crushed Blacks 3 Full, Limited, Full -- Video Level WRONG : Washed Out Colors 4 Full, Limited, Limited -- Video Level CORRECT : WtW & BtW Clipped, Double scaling 5 Limited, Full, Full -- Video Level WRONG : Washed Out Color 6 Limited, Full, Limited -- Video Level CORRECT : WtW & BtB preserved, Zero scaling 7 Limited, Limited, Full -- Video Level WRONG : Extreme Washed Out Colors 8 Limited, Limited, Limited -- Video Level WRONG : Washed Out Colors 6 being the ideal scenario what exactly does this equate to, I thought it was: MADVR "0-235" -- AMD "444:FULL RGB" -- LG OLED TV "LOW", low being limted. However this is wrong, everything is crushed, eh? i'm guessing MADVR should be 0-255 to match the GPU?
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions Last edited by mclingo; 2nd November 2020 at 23:53. |
3rd November 2020, 00:17 | #60568 | Link |
No, something is wrong there. Are you SURE your LG is set to low? Because it absolutely should be Limited, FULL, Limited (madvr, gpu, display). Of course, I don't know much about AMD cards so who knows what that's doing?
3rd November 2020, 00:37 | #60569 | Link |
AMD 444 FULL RGB - MADVR 0-255 - LG OLED HIGH - gives corrects results
AMD 444 FULL RGB - MADVR 0-255 - LG OLED LOW - gives crushed results AMD 444 FULL RGB - MADVR 16-235 - LG OLED HIGH - gives correct results AMD 444 FULL RGB - MADVR 16-235 - LG OLED LOW - gives crushed results can anyone make sense of this?
3rd November 2020, 01:25 | #60570 | Link | |
edit: full range for everything is recommended for everything the scaling stuff is a lie written by someone not knowing how ycbcr -> RGB works. you can do convert directly to full RGB and directly to limited RGB this is just none sense. Last edited by huhn; 3rd November 2020 at 01:29. |
3rd November 2020, 02:08 | #60571 | Link |
@mclingo - when you say correct results, do you mean for playback or desktop use? If you need both, then it's either GPU Full -> madVR 0-255 -> TV High or GPU Limited -> madVR 0-255 -> TV Low. If you only care about video playback, then the ideal setup is GPU Full -> madVR 16-235 -> TV Low.
3rd November 2020, 02:15 | #60572 | Link |
@huhn - I agree with you, but the OLEDs have banding issues with full range, among other things. Not sure if mclingo's first gen would be affected, though.
3rd November 2020, 02:26 | #60573 | Link |
Yea for us OLED owners things aren't as cut and dried...sadly. We'd all love to be doing full across the board, but, as VBB said, banding.
3rd November 2020, 02:51 | #60574 | Link | |
Unless AMD is automatically converting? Seems very unlikely.
3rd November 2020, 08:39 | #60575 | Link |
QB the Slayer
I am not sure why people say there is banding on LG OLED with the High setting... this is not true. Banding in PC mode, yes. But there is no difference between the High/Low setting with regards to banding.
QB
3rd November 2020, 09:12 | #60576 | Link |
For the most part I think the LG setting is just named backward. I think High means "expect the full range and keep black 'high' (don't lower it)" and Low means "expect the limited range and make black 'low' (expand the range)". I also had to set mine to "just scan" to disable overscan during boot, and disable some of the OLED screen saver features like screen shift to keep the edge of windows from being shifted off screen.
Edit: Oh yeah, and I also think limited range 8-bit YCbCr444 looks better on this screen than full range 8-bit RGB, like it converts RGB to YCbCr420 and then back internally or something. Pretty annoying. Especially noticeable with small red text on a dark background. I don't have an HDMI 2.1 GPU right now but when I do I'm going to try 12-bit color to see how that compares. I'm using an LG OLED48CX6LB.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) Last edited by Ver Greeneyes; 3rd November 2020 at 09:24. |
3rd November 2020, 10:02 | #60577 | Link | |
I always assumed it refers to the value range, since full range is higher (255 data points) then limited (219 data points)
3rd November 2020, 10:26 | #60578 | Link |
Fair enough I much prefer the full range / limited range nomenclature though.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
3rd November 2020, 11:14 | #60579 | Link | |
I agree YCbCr 444 limited is ideal for LG's OLEDs. I see worse near black banding when using full range RGB compared to limited range 444. It might just be the extra dithering but I think the display simply does better with limited range input.
