3rd June 2017, 10:47 | #25923 | Link |
Not sure what's happening. Downloaded DGIndexNV.exe 2052, make a new directory as I do for each new version. Setup BD-RB as per usual. Ran the first run..and failed. Used 2053 next...failed.
Switched back to DGIndexNV.exe 2051 and all is well again. Anyone come across this? If I run DGIndexNV.exe from it's directory and have it read the file, it does fine. License is in the text file as per normal. Hmm.. Bug with BD-RB? Code:
[06/03/17] BD Rebuilder v0.50.23 [02:17:51] Source: MONTY_PYTHON_D1 - Input BD size: 42.66 GB - Approximate total content: [03:39:39.432] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [02:17:54] PHASE ONE, Encoding - [02:17:54] Blanking: VID_00007 (1 of 7) - [02:17:54] Blanking: VID_00005 (2 of 7) - [02:17:54] Blanking: VID_00006 (3 of 7) - [02:17:54] Processing: VID_00000 (4 of 7) - [02:17:54] Extracting A/V streams [VID_00000] - [02:19:05] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 92,396 frames - Inverse Telecining in effect (IVTC) - Bitrate: 12,546 Kbs - [02:19:06] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.50.23 - Windows Version: 6.1 [7601] - Working Path Free Space: 358.51GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [02:19:06] - Failed video encode, aborted ---------------------- [06/03/17] BD Rebuilder v0.50.23 [02:20:15] Source: MONTY_PYTHON_D1 - Input BD size: 42.66 GB - Approximate total content: [03:39:39.432] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [02:20:19] PHASE ONE, Encoding - [02:20:19] Blanking: VID_00007 (1 of 7) - [02:20:19] Blanking: VID_00005 (2 of 7) - [02:20:19] Blanking: VID_00006 (3 of 7) - [02:20:19] Processing: VID_00000 (4 of 7) - [02:20:19] Extracting A/V streams [VID_00000] - [02:21:37] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 92,396 frames - Inverse Telecining in effect (IVTC) - Bitrate: 12,296 Kbs - [02:21:37] Reencoding: VID_00000, Pass 1 of 2 It's doing fine...
3rd June 2017, 14:50 | #25925 | Link |
OOpps...I forgot about that though I read it. Heh!
5th June 2017, 18:12 | #25927 | Link |
I removed AviSynth 2.5.8 and installed 2.6.0 and then 2.6.1 but still encountering this error. Went back to AviSynth 2.6.0. I'm still checking into this, but anyone have any suggestions?
[06/05/17] BD Rebuilder v0.50.23 [06:40:52] Source: MONTY_PYTHON_D2 - Input BD size: 42.62 GB - Approximate total content: [04:05:23.675] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [06:40:54] PHASE ONE, Encoding - [06:40:54] Processing: VID_00000 (1 of 39) - [06:40:54] Multiplexing M2TS - [06:40:55] CreateBDFiles() 00063 2004 [06:40:58]PHASE ONE aborted by user request ---------------------- [06/05/17] BD Rebuilder v0.50.23 [07:11:20] Source: MONTY_PYTHON_D2 - Input BD size: 42.62 GB - Approximate total content: [04:05:23.675] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [07:11:21] PHASE ONE, Encoding - [07:11:21] Processing: VID_00000 (1 of 39) - [07:11:21] Extracting A/V streams [VID_00000] - [07:13:08] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 97,163 frames - Inverse Telecining in effect (IVTC) - Bitrate: 11,983 Kbs - [07:13:08] Reencoding: VID_00000, Pass 1 of 2 - [07:13:09] Reencoding: VID_00000, Pass 2 of 2 - [07:46:20] Video Encode complete - [07:46:20] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [07:46:25] Multiplexing M2TS - [07:46:25] CreateBDFiles() 00063 2004 [07:59:06]PHASE ONE aborted by user request ---------------------- [06/05/17] BD Rebuilder v0.50.23 [08:43:23] Source: MONTY_PYTHON_D2 - Input BD size: 42.62 GB - Approximate total content: [04:05:23.675] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [08:43:26] PHASE ONE, Encoding - [08:43:26] Processing: VID_00000 (1 of 39) - [08:43:26] Extracting A/V streams [VID_00000] - [08:45:13] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 97,163 frames - Inverse Telecining in effect (IVTC) - Bitrate: 11,983 Kbs - [08:45:13] Reencoding: VID_00000, Pass 1 of 2 - [08:45:14] Reencoding: VID_00000, Pass 2 of 2 - [09:17:55] Video Encode complete - [09:17:55] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [09:18:02] Multiplexing M2TS - [09:18:02] CreateBDFiles() 00063 2004 [09:29:22]PHASE ONE aborted by user request [06/05/17] BD Rebuilder v0.50.23 [09:34:53] Source: MONTY_PYTHON_D2 - Input BD size: 42.62 GB - Approximate total content: [04:05:23.675] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [09:34:54] PHASE ONE, Encoding - [09:34:54] Processing: VID_00000 (1 of 39) - [09:34:54] Multiplexing M2TS - [09:36:29] Processing: VID_00001 (2 of 39) - [09:36:29] Extracting A/V streams [VID_00001] - [09:38:08] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 90,158 frames - Inverse Telecining in effect (IVTC) - Bitrate: 11,996 Kbs - [09:38:08] Reencoding: VID_00001, Pass 1 of 2 - [09:38:08] Reencoding: VID_00001, Pass 2 of 2 - [10:07:00] Video Encode complete - [10:07:00] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [10:07:05] Multiplexing M2TS - [10:07:05] CreateBDFiles() 00063 2004 [10:09:16]PHASE ONE aborted by user request [06/05/17] Checking System Settings - BD-Rebuilder v0.50.23 - Windows Version: 6.1 [7601] - Working Path Free Space: 257.73GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [06/05/17] Systems Settings Check complete
5th June 2017, 23:51 | #25929 | Link |
During multiplexing? That should happen during extraction and rerendering, only, right?
6th June 2017, 00:33 | #25930 | Link |
Not necessarily. I looked at that section of code, indicated by the "2004" in the error message, SUP and IGS files can be manipulated directly (e.g. resizing or making empty). It really only involves a couple of subroutine calls -- and that seems to be the only possibility.
7th June 2017, 07:11 | #25931 | Link | |
From the changelog: Code:
April 11th, 2012 - v0.40.9 - Corrected the type of DGDecNV field operation used when IVTC is enabled. This should correct audio sync issues with IVTC/DGDecNV/MPEG-2 pulldown combinations. - Modified processing so that MULTIPROCESS is not used when the source that are to be processed for inverse telecining. Code:
Decoding/Frame serving: DGDecNV [3-way] ... Inverse Telecining in effect (IVTC) ggtop |
7th June 2017, 23:42 | #25932 | Link |
Checking....nope. I also got around to re-ripping it and...still the same.
8th June 2017, 00:05 | #25934 | Link |
I also did that before I re-ripped it. Scanned through fine. I had DGIndexNV.exe 2053 save the video and demux audio. Everything went fine.
8th June 2017, 00:12 | #25936 | Link |
Useful n00b
Maybe jdobbs can try to recreate the 63 error. He's usually very kind and diligent about getting disks to try to fix things. A great developer, one for the ages. One special guy.
8th June 2017, 00:48 | #25937 | Link |
I agree. I've changed IVTC_1080i to "0" and see if that's the cause and so far, it's going well.
8th June 2017, 01:31 | #25939 | Link |
I had BD-RB use the hidden option IVTC_1080i=1. I've changed it to 0 now it's going through all using High Speed to test. I wasn't using anything else other than IVTC active in Setup.
