Old 2nd July 2005, 21:40   #101  |  Link
Doom9
clueless n00b
and one more thing: I'll start integration once I'm done with the automated 3 pass and the current code has been tested a bit.. autoclick caters to an audience that often doesn't get the complexity of the process so I'd like all the underlying code to be tested. While I think I'm doing a reasonable amount of testing before every release, there's been a lot of changes in between the last two versions.
For the web's most comprehensive collection of DVD backup guides go to www.doom9.org
Doom9 is offline   Reply With Quote
Old 3rd July 2005, 01:14   #102  |  Link
berrinam
berrinam's Avatar
Originally Posted by Doom9
public string StartPath
			get {return path;}
Is not required because the main Form already has a property for that: MeGUIPath
Ok, fixed.
In addition, it has a property to get the settings for the currently configured video codec:
public VideoCodecSettings VidCodecSettings
so you should use that.
I'll add the same to get the current audio settings. Since I'm making heavy use of inheritance we should work with the generic types whenever possible and get the actual type using the "is" operator.
I understand, but I need to get the individual codec settings for when I change codec (videoConfigButton_Click). As in, when the LAVC is configured, it gets main form's CurrentLavcSettings. If it were just to call VidCodecSettings, then what would happens if the VidCodecSettings were x264CodecSettings, as opposed to LavcCodecSettings? I'm sure there is a better way to do it, but how?
And I hope you don't mind that when I integrate it, I'm going to rewrite parts of the code.. I saw you integrated autocrop and dgindex project creation code, which is not ideal. I'll move those a/multiple separate classes so that the code will only have to be maintained once. Or you can create those classes, as you like.
Yes, I was planning to do that, I just never got around to it. I presume you want some sort of VideoUtil class that manages autocropping and resizing?
The way I see OneClick is as a set-and-forget method for anyone, so long as no AviSynth filters are wanted. For the people who aren't experienced, the default settings (through profiles) should be good, but it should also be appropriate for advanced users on sources that need no filtering.
I am at a loss with what to do about chapters and subtitles, because they seem to break up the automated process (is there any automation in chapter or subtitle extraction?). At the moment, neither are implemented (the chapters file is there, but it has no effect). Should I exclude them?
berrinam is offline   Reply With Quote
Old 3rd July 2005, 01:21   #103  |  Link
Doom9
clueless n00b
about Chinese vs Cantonese vs Mandarin: Here's the list of what mp4box supports: http://cvs.sourceforge.net/viewcvs.p....1&view=markup
sadly, neither Cantonese nor Mandarin are on the list
If you look at the ISO standard, those just don't exist: http://www.w3.org/WAI/ER/IG/ert/iso639.htm
Old 3rd July 2005, 01:28   #104  |  Link
berrinam
berrinam's Avatar
Also, with so much inheritance, would it be a good idea to inherit all of the configuration dialogs from a videocodecconfigurationdialog class, which has input, output, encoderpath, creditsstartframe, and so on? Then, the VideoCodecSettings class could have a getConfigDialog method.
Old 3rd July 2005, 01:31   #105  |  Link
Doom9
clueless n00b
hmm.. I guess it depends on how you want to configure it.. I haven't seen the GUI yet, but assuming it looks like North101's design there's no config button.. perhaps there ought to be one? But then again we'd also have to offer profiles.. what do you think about adding those two? It would certainly be easier not to do it but I'm not sure what is more beneficial for the user.
If the one click window is a dialog and we're not going to add config and profiles, then I'd prefer to give the form a reference to all currently configured VideoCodecSettings and AudioCodecSettings objects at construction time.
Well, chapters can be done if you're using DVD Decrypter (it can write a chapter file while ripping). Subs are indeed something else.. they need to be done manually before using MeGUI.
So leave chapter and try to auto-load the chapters file based on the name of the video input (rip something with DVD Dec and chapter extraction enabled to see how it names chapter files.. I don't know that either).
I guess we can drop subs for now and add them if somebody asks for them or if mp4box supports vobsub muxing one day (I have an RFE open but haven't gotten around to uploading some sample files)
Exactly.
Old 3rd July 2005, 01:38   #106  |  Link
Doom9
clueless n00b
I've thought about that when I moved the configuration to separate dialogs.. conceptually it makes sense, but since we have different sizes, number of tabs, and most settings do not match I think it would become complex rather quickly (each constructor or load event handler would have to resize the GUI move GUI elements around.. I've already made a first attempt but somehow the visual inheritance didn't work out the way I wanted it.. but if you want to give it a shot go ahead).
Old 3rd July 2005, 01:40   #107  |  Link
berrinam
berrinam's Avatar
At the moment, my design has profiles and configuration. The code is mostly copied from version .0.1.9.8 of the main form. I take the philosophy that profiles mean that the inexperienced user can use pre-configured profiles, and the advanced user can choose whatever settings he or she chooses.
I do that. Another option that comes to mind just now is this: configure the profiles in the main form, and then just select which one you want in the oneclickwindow. What do you think?
Will do.
Old 3rd July 2005, 01:42   #108  |  Link
berrinam
berrinam's Avatar
I will try that. Anyway, what I was thinking was just to overload the getConfigDialog method.
Old 3rd July 2005, 01:46   #109  |  Link
Doom9
clueless n00b
I don't quite get that. With so many dialogs, the GUI setup should be done in the InitializeComponent method (the one VS generates on its own and that contains everything you do in the GUI designer). Sure you can do a whole GUI manually (I once wrote a Java mail program like that.. it was a real pain in the ass), but I'd be very uncomfortable not being able to edit the GUI quickly in the designer.. there are always things that need changing.
That's how I meant "having profiles". And of course you need to filter them by codec (see the configuration dialogs for code.. it's already done there).
Old 3rd July 2005, 01:53   #110  |  Link
berrinam
berrinam's Avatar
I just meant have, as part of the x264Settings class, a createConfigDialoog method which creates an instance of x264ConfigDialog and wirets all the settings ... I'm not sure if this is any better, though. Anyway, I know what I mean, I think I understand you, so it should be fine -- I'll write the code.
Sounds good.
Old 3rd July 2005, 01:58   #111  |  Link
Doom9
clueless n00b
I've uploaded the latest sources. Darned new PC crashing again just killed my VS installation.. VS tells me it's not properly installed for the current user. Now I have to extract the 19k files again and reinstall.. damn.
I'm not sure it's such a good idea to create a form from a data container class.. the way it's done now, send a container class to the gui and get one back seems more straightforward.
Old 3rd July 2005, 02:01   #112  |  Link
berrinam
berrinam's Avatar
I agree that sounds better, but where does it do this?
Old 3rd July 2005, 02:07   #113  |  Link
Doom9
clueless n00b
load form1.cs in the designer, double click on the config button and see what it does.. after creating the forum, I use a property of the form to set the current settings. When I get a OK result back, I use the same property to get the updated settings back, and overwrite the currentXYZSettings in the main form.
Old 3rd July 2005, 02:11   #114  |  Link
berrinam
berrinam's Avatar
Aah right... data container, not GUI container. I'll do it as you say.
Old 3rd July 2005, 02:14   #115  |  Link
berrinam
berrinam's Avatar
Oo, one more thing -- choice for mp4/avi or just stick to mp4? I favor having a choice for everything, but defaulting to mp4
Old 3rd July 2005, 02:19   #116  |  Link
Doom9
clueless n00b
well.. I guess since I spent all this time implementing it.. keep both.. but avi is limited to one track and currently ac3 input doesn't work (mencoder's problem not mine) I'd definitely default to mp4
Old 3rd July 2005, 14:08   #117  |  Link
berrinam
berrinam's Avatar
Ok, I have updated oneclickwindow for 0.2.0.6. It does not (yet) have avi output, chapter support or auto3pass, but the rest seems to be there, and it seems to work. Built on top of version 2.0.6, I have attached changes here
EDIT: I haven't used rapidshare.de before, and I'm not sure if it worked. As a backup I have also attached the same file.
PS. I will catch up on the missing features tomorrow
Old 3rd July 2005, 14:14   #118  |  Link
Doom9
clueless n00b
I see you've attached a new AviSynth window.. what has changed except for moving out the stuff into the videoutil class? (I'm about to release 0207 with full job updates but if that's the only change I can already incorporate that new code so when you make the update tomorrow you can base your code on 0207 directly)
also.. I'd need to have the launching code for the main form separately.. I'm still working on the main form right now (job updates obviously are in there).
Old 3rd July 2005, 14:21   #119  |  Link
berrinam
berrinam's Avatar
Ok, it seems you want a full changelog, as earlier. Here goes:
Avisynth window: delete all methods in autocrop region and replace with
		private void autoCropButton_Click(object sender, System.EventArgs e)
			CropValues final = VideoUtil.autocrop(reader);
			bool error = (final.left == -1);
			if (!error)
				cropLeft.Value = final.left;
				cropTop.Value = final.top;
				cropRight.Value = final.right;
				cropBottom.Value = final.bottom;
				if (!crop.Checked)
					crop.Checked = true;
			else
				MessageBox.Show("I'm afraid I was unable to find 3 frames that have matching crop values");
Main Form: Add OneClickEncodeWindow menu item with this event handler:
		private void mnuToolsOneClick_Click(object sender, System.EventArgs e)
			OneClickWindow oneClick = new OneClickWindow(this, videoProfiles, audioProfiles, videoProfile.SelectedIndex, audioProfile.SelectedIndex);
			oneClick.ShowDialog();
Main Form: add this properties
		public JobUtil JobUtil
			get {return this.jobUtil;}
And the other files are new, and the project file just includes them
Old 3rd July 2005, 14:26   #120  |  Link
berrinam
berrinam's Avatar
Missed something. Avisynthwindow: delete getAspectRatio method. Change
suggestResolution_CheckedChanged(blah, blah) to
		private void suggestResolution_CheckedChanged(object sender, System.EventArgs e)
			if (suggestResolution.Checked)
				verticalResolution.Value = (decimal)VideoUtil.suggestResolution(reader.Height, Double.Parse(customDAR.Text)
EDIT: fixed code in this post
development, megui, not a help thread
