6th October 2015, 17:40 | #33401 | Link |
It can crop away hard-coded subtitles inside the black bars or TV station logos or stuff like that.
6th October 2015, 18:14 | #33403 | Link | |
I'm so eager for the next thing that I forget all about patience, sorry about that madshi. Move along.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
6th October 2015, 18:14 | #33404 | Link |
It seems madVR is causing MPC-hc to crash if NVidia 3D vision is enabled when going into fullscreen? If I set MPC-HC to use EVR then it does not crash. Is there any way I can make a meaning full log for you to track this one given madvr does not seem to crash?
6th October 2015, 20:38 | #33405 | Link | |
I've had a similar problem with MPCHC hanging on every exit but the crash reporter window doesn't come up. I fixed it by cleaning out all codecs and reinstalling, upon which time I switched to the x64 version of MPCHC. Unfortunately I had to redo all the settings but there was no way around it.
HTPC: Intel Core i7 2700K, 16GB DDR3 1833, GTX 660Ti, Samsung SSD860, Asus z77, PCIe 3.0 Desktop: AMD Ryzen 3700x, 16GB DDR4, 1TB NVME SSD, Asus x570 Tuf Gaming, Nvidia RTX 2060. |
7th October 2015, 01:30 | #33406 | Link | |
The new built fixed the subtitle positioning: thanks for your continuous and generous work!!!
Best Regards! Leo! |
7th October 2015, 22:05 | #33408 | Link | |
Could you share python code sample for enabling smooth motion? That would help me a lot. |
7th October 2015, 22:14 | #33409 | Link |
Hi madshi or anyone, I have a video without black bars where the movie resolution is 960x720 and the target rectangle is 1280x720 (viewing in window)
In a window, it shows chroma > super-xbr and luma > jinc...does this mean the video is already being upscaled? I don't understand why it doesn't just show a 960x720 window. In full screen it shows chroma > super-xbr, image x > super-xbr and image y > super-xbr madvr 0.88.21 Last edited by JarrettH; 7th October 2015 at 22:21. |
7th October 2015, 22:17 | #33410 | Link | |
8th October 2015, 01:47 | #33411 | Link | |
So, I can suggest to people that comes from others O.S. (like me from Seven) to format and reinstall, because many issues seems to be related to the upgrade procedure. Thanks again and sorry for submitting a non-related issue.
8th October 2015, 09:04 | #33412 | Link | |
So you can't enable smooth motion without having the whole filterGraph (=player) running in your own program, hence the complicated part. Maybe there's a way to do it from an external process, we should ask madshi about that EDIT: You might use madVR's keyboard shortcuts instead of trying to access madVR COM interface. Your script would send keystrokes to the madVR window to toggle smooth motion for instance. I don't have any code sample for that though but I guess it's simple enough. EDIT2 : Here is a quick and dirty Python script to toggle madVR debug OSD (ctrl+J) - you could use any other shorcut. You'll need to find your player window's handle first, which is quite easy. EDIT3 : Oh there's another solution: You could use the SetSettings command of the madVR netProtocol. I've never tried that, but it should work too. See net-protocol.txt in your madVR folder. Last edited by sebdelsol; 8th October 2015 at 12:55. |
8th October 2015, 09:28 | #33413 | Link | |
Thanks for the explications, I was completely wrong. |
8th October 2015, 12:19 | #33414 | Link | |
(You can trigger smoothmotion via keyboard shortcut.)
8th October 2015, 17:58 | #33416 | Link |
Question:
Does all these picture enhancements like chroma upscaling/error diffusion/image doubling raise the transfer rate through the HDMI cables? is more data sent with this on compared to a regular blu ray player that doesnt have these features ? |
8th October 2015, 18:11 | #33417 | Link |
there is no general answer to this.
it depends alot on settings. Pc can output 8-12 bit RGB/YCbCr and a bd player too. if a bd player doesn't upscale it self than madVR with upscaling is kind of sending more data. edit: the things you listed aren't really picture enchantment they are necessary steps that needs to be done at some point if scaling is needed. Last edited by huhn; 8th October 2015 at 18:14. |
8th October 2015, 18:27 | #33418 | Link |
i also run a 3D LUT file with madvr
dont know it that also pushes up the transfer rate? why i asked was mainly because i could see an improvement when switching from a cheap noname HDMI cable to a 3m Supra cable to my PC. the improvement was higher sharpness mostly visible around peoples edges. the added sharpness was also there in motion. movies with a alot of grain before look more clean now with less or no grain. if i go from the above the cheaper hdmi cable was not able to transfer all of the data to the reciever. if it would i shouldnt see any improvement right. i also read that the Pioneer BDP LX58 blu ray player that i owned before was "pushing" the limits of what hdmi is capable off. dont know what they mean by that. if its transferspeeds or data sent that is maxed out. that blu ray player also has some upscaling features on but its not close to the performance you get from madvr. Last edited by Patrik G; 8th October 2015 at 18:35. |
8th October 2015, 19:02 | #33419 | Link | ||
10-bit output would but the bit-depth actually sent to the TV is set in the GPU's drivers, not madVR. Oh, madVR's display mode changer could change the bandwidth required, of course. Quote:
It is possible to use a different color space with sub-sampled chroma (YCbCr 4:2:2 or YCbCr 4:2:0) which is lower bandwidth and lower quality but it will not automatically switch to this mode due to the cable's quality. I am not sure what people were talking about with "pushing the limits of what HDMI is capable of", probably trying to sell a gold plated HDMI cable.
madVR options explained |
8th October 2015, 19:16 | #33420 | Link | |
just as i thought but im no expert here. it was the LX-58 blu ray player that was "pushing" the limits of hdmi. and i asume they was speaking of the picture enhancements/scaling from the blu ray player. but its probably marketing hype. lets see if i can catch the sharpness improvements on the camera with the different cables. if not there then its the famous placebo effect. |
