6th January 2017, 09:16 | #41901 | Link | |
10 Bit p010 is real 10 bit and most probably never needs debanding with those inputs and then it's entirely up to your display panel efficiency what you'll see 10 bit->8 bit->MadVR (Debanding)->Panel you now did 10 bit->MadVR (no debanding/no dithering)->Panel Lets sumarize it 10 bit->MadVR (Pure) 10 bit->8 bit->MadVR (Pure) 10 bit->8 bit->MadVR Debanding High 10 bit->8 bit->Ordered Dithering->MadVR (Pure) 10 bit->8 bit->Random Dithering->MadVR (Pure) Wow here you really see the Power of Ordered/Random Dithering that is Psy wise almost a 100% hit of the input quality without MadVR touching anything. Now it shouldn't surprise anyone anymore why there is no (No Dithering) Option in Lav Video
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th January 2017 at 13:16. |
6th January 2017, 15:36 | #41903 | Link |
Wrong color Astra1 UHD
I described my problem here: https://forum.doom9.org/showthread.p...14#post1792014
Here the ctrl-j output: http://puu.sh/td7rh/19227caded.jpg Here a sample: https://www.dropbox.com/s/cbbp9073q8...20UHD_.ts?dl=0 Kind regards, Clemens |
6th January 2017, 15:48 | #41904 | Link |
That combination seems to cry after problems 8bit p10 DXVA2
Try Fullscreen Exclusive to get into 10 bit
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th January 2017 at 15:53. |
6th January 2017, 15:55 | #41905 | Link |
The same problems on a channel with p1010 10 bit 4:2:0 (dxva2)
http://puu.sh/td8tH/3ca44b49e7.jpg (If sample needed please ask) I will try your suggestion EDIT How do I do this? (sorry I'm a noob ) Which shortcut I have to press or which setting I have to change for this? Last edited by Clemens; 6th January 2017 at 16:00. |
6th January 2017, 16:07 | #41906 | Link |
These 2 options at least
Then go into Fullscreen
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
6th January 2017, 16:13 | #41907 | Link |
This is completely from my memory and don't really want to go into any testing, but try disabling use a separate device for presentation. I did sometime ago and haven't had problems since. I did other changes as well so that's why I'm mostly guessing here.
6th January 2017, 16:20 | #41908 | Link |
I have done some more tests:
- CPU decoding -> colors are fine (off course no fluent image) - DXVA2 + custom EVR Renderer -> works fine - DXVA2 + MadVR -> doesn't work --> seems to be very similar to the magenta bug in the bug tracker: http://bugs.madshi.net/view.php?id=456 I guess DXVA2 is doing something wrong... Have you the same problems with other GPUs? (mine is a GTX 960) The Exclusive mode doesn't change anything... Problem is there for all 4k HEVC 10 bit channels (also the HLG teststream channel) Last edited by Clemens; 6th January 2017 at 16:23. |
6th January 2017, 17:37 | #41909 | Link |
Indeed strange VP7 should do it are you sure the Mixer input output types are 10 bit with EVR Custom rendering and DXVA ?
And are you in 10 bit Display Driver Mode also for MadVR and still in Exclusive Fullscreen you get those color shifting ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th January 2017 at 17:41. |
6th January 2017, 17:47 | #41910 | Link |
I have no idea what the EVR renderer does How can I check this?
And I'm using a 8bit UHD display. If you mean with your question "the native display bitdepth is:" then I can say I tried 10 bit and 8 bit there no difference. Can you play the sample file without any problems (some posts above)? Would like to know if only I have the problem. And what do you mean with the VP7 thing? (as said I am a noob ) Btw. thanks for looking at it (it's not that important to me I just thougt to report it to make madvr better if the bug is in madvr) |
6th January 2017, 17:47 | #41911 | Link | |
Same results with an RX 470 here,dxva2(native) gives black screen. |
6th January 2017, 17:55 | #41913 | Link |
That isn't how madVR works, what are you doing to get it to 8-bit before madVR?
10 bit->16 bit madVR (debanding)->8-bit->Panel ngu low is consistent with "NGU 1080p to 4k"?
madVR options explained Last edited by Asmodian; 6th January 2017 at 17:58. |
6th January 2017, 18:00 | #41914 | Link |
10 bit P010->YV12 8 bit (no dithering)->MadVR Debanding High
Is the heavy banding result above with 10 bit P010->YV12 8 bit (Ordered/Random Dithering) has the biggest visual Deband effect, you virtualy dont need MadVR Debanding High and it's overhead anymore.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th January 2017 at 18:11. |
6th January 2017, 18:10 | #41915 | Link |
Other test done with my problem: DXVA2(copy back) works also fine and with correct colors...DXVA2(native) gives the purple screen...
So: DXVA2 (native) -> EVR custom -> OK DXVA2 (native) -> MadVR -> NOT OK, purple colors no Hardware Decoding -> OK with both (but stuttering bacause of software decoding) DXVA2 (copy back) -> both OK |
6th January 2017, 18:14 | #41916 | Link |
Same with the Samsung 10 bit Streams ?
http://demo-uhd3d.com/fiche.php?cat=uhd&id=91 http://demo-uhd3d.com/fiche.php?cat=uhd&id=97 Hmm so DXVA Native wont work, but why ? Native Display Bitdepth (Driver) should be 10 bit The Controll Panel should be set to 10 bit Though if it only would work with copyback that wouldn't be really that bad the overhead is not that much bigger normally, though for people with laptops that want maximum power saving could be a problem. VP7 stands for Video Processor (Version 7) the VPU (Video Processing Unit) inside of your GM206 GTX 960 also called marketing wise Nvidia PureVideo.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th January 2017 at 18:59. |
6th January 2017, 18:44 | #41919 | Link | |
i will never post you a 10 bit screen because it is technically not doable. setting the output to 10 bit doesn't mean you get 10 bit too. the windows desktop is working in 8 bit. madVR is not debanding when outputting 8 bit. @Clemens DXVA native is a lowering picture quality with nvidia and it should be avoided using madVR. your GPU is not by any chance a 2 GB GTX 960? |
