29th May 2010, 07:57 | #5741 | Link | ||
Programmer (or just 教务长)
2. Video will not be reencoded. You have to change the mode to [full-mode], otherwise you have no access to add/remove audio tracks/subtitles. Quote:
30th May 2010, 11:53 | #5743 | Link |
Build 754:
* Finally a preview for both title-list menu styles is available. * For [classic title list menu] the font size from MENU tab will be used for title names. Title list menu: "Classic" LIST title-list menu: Dean |
30th May 2010, 14:21 | #5745 | Link |
Aging Video Hobbyist
I've been wondering if I'm the only person on Planet Earth that doesn't care about fancy menus! I will give this a try and hopefully I can replace Ulead MF6+ (eventually). There's still no "audio for menu" option though?
1st June 2010, 12:21 | #5747 | Link |
Please forgive if I've overlooked something obvious, is there a way to import images for the chapter thumbnails?
I know it works if you create the disc layout on hdd, replace the images in the HDAVCTN folder (using the same file names), then load the multiAVCHD.mpf that multiAVCHD created. Previews still show the old chapter menus, but after changing the thumbnail border color [not sure if that's needed to trigger the menu re-render], creating the disc layout a 2nd time uses those new thumbnails. The reason for changing thumbnails is that the start of a chapter can be black, or it can be the beginning of a pan shot etc, & often a snapshot at that time doesn't give a good hint of what scene a chapter button will take you to. Thanks --- BTW, multiAVCHD works great with mpg2 out of Vegas (in Vegas I modify one of the existing BD templates) -- unless I missed something the multiAVCHD site only mentions AVC from Vegas has been reported to work. It also appears to work with AVC encoded using the ATI stream encoder in Roxio VideoWave -- I can't recommend it because I've had all sorts of problems with VideoWave encoding, but if someone has it working, my limited testing showed it seems to work with multiAVCHD just fine. I *think* it might use the x264 encoder, but the BD template is *off* enough that tsMuxer won't take the AVC, where multiAVCHD fixes the video so it works. *Should* be able to correct that with a new template in VideoWave, but I've never gotten a new AVCHD template working. It's a shame because their stream encoder seemed promising. Last edited by mic; 1st June 2010 at 12:23. Reason: typo |
1st June 2010, 12:29 | #5748 | Link |
You didn't overlook anything... I just need to figure a way to allow user to use external chapter images.
I believe I can implement something like the HDAVCTN folder but for files... For example if you have: X:\test\video.m2ts x:\test\HDAVCTN_video.m2ts\ch01.jpg ... x:\test\HDAVCTN_video.m2ts\ch96.jpg it may work... I'm not sure if it will be of any use... What do you think or suggest? Dean |
1st June 2010, 21:04 | #5749 | Link |
I just tried to backup [re-author mode - no editing] my Avatar BD and got an error at "preparing menu" stage - now I am left with ~90GB in the destination AVCHD folder where as the source is only 45.4GB after nearly 10 hours of just splitting and re-mapping - anyone else run into this?
1st June 2010, 23:58 | #5750 | Link | |
Having multiAVCHD accept the image files from the start would be a big help & speed things up, but I feel bad asking you to do the extra work if I'm the only one that might use it. Replacing the files does work & re-rendering the layout doesn't take too long -- maybe some others will chime in? Myself I save snapshots in Vegas or PowerDVD, & if/when I want to get fancy I fade or frame the edges of the thumbnail in an image editor -- I don't mind it at all, but maybe some would like it better if you tied in the video preview you've already got in the properties dialog?.. You've got the chapter thumbnails listed right there, so maybe tie the two together, like click this button when the frame you want to use is in the preview? Thanks again |
2nd June 2010, 00:07 | #5751 | Link | |
2nd June 2010, 06:54 | #5752 | Link | ||
2) multiAVCHD cannot handle multi-versions of a movie (branched titles). It is clearly stated in this post. Quote:
2nd June 2010, 07:27 | #5753 | Link | |
Thanks for the reply Dean!
Sorry but thats the last thing I see in the multiAVCHD.log file: [09:19:29] Preparing menu pages... [09:19:29] Encoding Title List menu page [1/16]. [09:19:58] Encoding Title List menu page [2/16]. [09:20:08] Encoding Title List menu page [3/16]. [09:20:19] Encoding Title List menu page [4/16]. [09:20:29] Encoding Title List menu page [5/16]. [09:20:39] Encoding Title List menu page [6/16]. [09:20:49] Encoding Title List menu page [7/16]. [09:20:59] Encoding Title List menu page [8/16]. [09:21:09] Encoding Title List menu page [9/16]. [09:21:19] Encoding Title List menu page [10/16]. [09:21:29] Encoding Title List menu page [11/16]. [09:21:40] Encoding Title List menu page [12/16]. [09:21:50] Encoding Title List menu page [13/16]. [09:22:00] Encoding Title List menu page [14/16]. [09:22:11] Encoding Title List menu page [15/16]. [09:22:21] Encoding Title List menu page [16/16]. I also see another file called "details.txt" which was filled with a bunch of "imdb" links. Quote:
So, is there a work around to just get the main title? Thanks again for all your work and in no way am I unappreciative of the great useful program of yours. Last edited by sreemv; 2nd June 2010 at 07:35. |
2nd June 2010, 08:24 | #5754 | Link |
If you load the original BDMV folder you'll be prompted if you want to enter re-author mode. If you do there is no way that you'll get 'encoding title-list menu'.
Yes, you can get the main movie only if you remove all playlists from media tab, which you don't need. 1) Start multiAVCHD 2) Set "Do not implort BDMV/AVCHD/DVD playlists if shorter than" [3600] in AUTHOR tab 3) Drag&drop the BDMV folder and answer with "NO" at the prompt. 4) Open [properties] and remove playlists if needed. Dean |
2nd June 2010, 15:24 | #5755 | Link |
windows7
its me again with windows 7 with the new installation problems trying to work through it and understand what is required to get a working copy of multi avchd on a new installed os.
so i've made progress but i'm not 100 percent fixed yet. i was able to start over and reinstall everything for the directions i read on the board and the biggest difference came for making sure in windows 7 to use the tweak tool that seems to give it a big difference by manually setting everything to use at ffshow now i have a different problem i was able to create a compilation and it was able to process through all of the titles until i got to the motion menu section and then within the first 3 titles i had a machine locked up with the error message the x 264 has quit responding. i noticed when it's creating that motion menus i get at least a dozen icons filling my tray i get 1 of haali and 1 of ffshow and it get some titles well give me the next 264 has stop working. any suggestions? |
2nd June 2010, 17:39 | #5756 | Link |
Dean, some of my menus are acting in a strage way... in preview works ok, but after transcode, some buttons insists in not appear (see image). The first button it's normal, the second is missing half, and the third one, doesn't appear. Did you already notice that? It's the third or fourth movie this happens...
By the way, the button mappings are ok, and all working after transcode. |
2nd June 2010, 17:42 | #5757 | Link |
I'm aware of the problem, but I forgot to fix it. There are some hidden buttons which overlap with your buttons and that's why it happens. These hidden ones are on the right side, so if you had yours to the left it won't happen.
I'll fix it in the next build. Thanks for reminding me of it. |
2nd June 2010, 19:35 | #5758 | Link |
Just wanted to post an update about my test clip. The conversion came out ok, but with an interesting twist. When the ball was thrown, it was like watching it under a strobe light. You could see it traveling almost 1 frame at at time, but leaving an after image as well. The players movement was normal with no jerkiness, just the ball had this strange effect. When I played the original on the camcorder, the strobe light effect was still there, but much smoother movement. I'll upload a segment sometime showing this, because it's really interesting to watch.
3rd June 2010, 11:15 | #5759 | Link |
Build 755 (requires full-download | mirror)
* Classic title-list menu: font, size, color and outline set in MENU tab will be used for title names * Title-list menus: different default background audio * Main menu: fixed button overlapping (reported few posts up) * Chapter/Title-list menus: fixed hidden buttons in IGS which cause troubles in some players not changing the active navigation page, causing wrong chapter jumps from chapter menu. Corel WinDVD 10 now doesn't crash when chapter/title-list menu is displayed (but may crash if main menu doesn't have all four buttons PLAY/SETUP/CHAPTERS/TITLE LIST) (to do). * multiAVCHD.dat updated to [04010755] Dean |
3rd June 2010, 15:17 | #5760 | Link |
Hi deank, I just tried the latest build 755 on a movie only backup created with BD-RB, that has a file size of 4.28GB. I use multiAVCHD to import this movies .mpls file and also add the original Blu-ray's menu .m2ts file, which is 46.5MB.
I notice after multiAVCHD completes, the new movie and menu is 4.35GB, and the newly created menu is 76.1MB. In the past the reencoded menu had a smaller than the original file size. For this particular backup, all is well. But is this normal for the reencoded menu to be larger than the original? |
