20th August 2008, 17:33 | #81 | Link |
In MPlayer from 2008-07-18 should be PAFF implemented. I think it is supported at least for a half of year.
Now I'd like to ask you for help with my problem. On my work computer I can't run MPlayer. The CLI version MPlayer.exe always instantly exits without any output. I tried different versions and builds. I have a suspicion that a firewall or other "service" is blocking MPlayer. I tried to rename the .exe but it didn't help. Do you have any idea how to check if my suspicion is correct? And more importantly do you have any idea how I could fool the service? |
20th August 2008, 21:22 | #82 | Link |
Software Developer
I don't see how a firewall could prevent MPlayer from starting up
I recommend you try to run MPlayer.exe from gdb and see what it reports. Maybe you get some useful output... You can get latest gdb version here: http://sourceforge.net/project/showf...ease_id=594520 Try like this: "C:\MinGW\Bin\gdb.exe" "C:\Program Files\MPlayer for Windows\MPlayer.exe" Then type "run" to start execution and see what will happen...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th August 2008 at 22:21. |
21st August 2008, 06:49 | #83 | Link |
Hi Dat!There is no problem with my setup,ive tried anything anbd everything,i mean what can i do wrong.Im running Vista AMD 64X2 2,3ghz ,4gb memory.Dat tell me how to setup then,ive never had problems befor it the latest build only.
21st August 2008, 08:58 | #84 | Link |
I have no idea what software or problems there could be with Your PC, my current setup is Vista x64 Intel Q9550 (this thing rocks!!!) 4gb ram, and mplayer and mencoder work perfectly!
On that note... Mulder, one thing that anoys me about your Installer is no Mencoder!!!! Could you do 2 packages.... one with mencoder and one without! |
21st August 2008, 15:10 | #85 | Link | |
aka XaS
You can get mencoder from here (bundled with mplayer) though
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
21st August 2008, 15:56 | #86 | Link | |
Is it of any help? I'm afraid not. I think I might need a debug version of MPlayer. |
21st August 2008, 18:51 | #87 | Link | |
Software Developer
But you don't get any output at all. That really bizarre. Sure your MPlayer.exe file is okay ??? You should get something like this: Code:
LoRd_MuldeR@MULDER_NEU ~ $ cd "/c/program files (x86)/MPlayer for Windows" LoRd_MuldeR@MULDER_NEU /c/program files (x86)/MPlayer for Windows $ gdb MPlayer.exe GNU gdb 6.8 Copyright (C) 2008 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i686-pc-mingw32"... (no debugging symbols found) (gdb) run Starting program: c:\program files (x86)\MPlayer for Windows/MPlayer.exe [New thread 4992.0x1384] Error: dll starting at 0x77d40000 not found. Error while mapping shared library sections: NOT_AN_IMAGE: No such file or directory. Error while mapping shared library sections: C:\WINDOWS\SysWOW64\ntdll32.dll: No such file or directory. Error: dll starting at 0x77d40000 not found. Error: dll starting at 0x77c20000 not found. (no debugging symbols found) (no debugging symbols found) [New thread 4992.0x1388] (no debugging symbols found) MPlayer Sherpya-SVN-r27323-4.2.4 (C) 2000-2008 MPlayer Team CPU: Intel(R) Core(TM)2 Quad CPU @ 2.40GHz (Family: 6, Model: 15, Step ping: 7) CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 Usage: mplayer [options] [url|path/]filename Basic options: (complete list in the man page) -vo <drv> select video output driver ('-vo help' for a list) -ao <drv> select audio output driver ('-ao help' for a list) vcd://<trackno> play (S)VCD (Super Video CD) track (raw device, no mount) dvd://<titleno> play DVD title from device instead of plain file -alang/-slang select DVD audio/subtitle language (by 2-char country code) -ss <position> seek to given (seconds or hh:mm:ss) position -nosound do not play sound -fs fullscreen playback (or -vm, -zoom, details in the man page) -x <x> -y <y> set display resolution (for use with -vm or -zoom) -sub <file> specify subtitle file to use (also see -subfps, -subdelay) -playlist <file> specify playlist file -vid x -aid y select video (x) and audio (y) stream to play -fps x -srate y change video (x fps) and audio (y Hz) rate -pp <quality> enable postprocessing filter (details in the man page) -framedrop enable frame dropping (for slow machines) Basic keys: (complete list in the man page, also check input.conf) <- or -> seek backward/forward 10 seconds down or up seek backward/forward 1 minute pgdown or pgup seek backward/forward 10 minutes < or > step backward/forward in playlist p or SPACE pause movie (press any key to continue) q or ESC stop playing and quit program + or - adjust audio delay by +/- 0.1 second o cycle OSD mode: none / seekbar / seekbar + timer * or / increase or decrease PCM volume x or z adjust subtitle delay by +/- 0.1 second r or t adjust subtitle position up/down, also see -vf expand * * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * * Program exited normally. (gdb)
21st August 2008, 18:53 | #88 | Link | |
Software Developer
So there is absolutely no difference if you download the MEncoder.exe alone. See the link provided by DarkZell666.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd August 2008 at 12:45. |
21st August 2008, 19:59 | #89 | Link |
LoRd_MuldeR> The same MPlayer.exe works on other computers without any problems. But it doesn't work on any computer at work. I also tried other builds with the same result. So my conclusion is that there must be something in our network which kills MPlayer as soon as it is started.
But I'm wondering how the "service" could recognize that the process is MPlayer. Do you have any idea? |
21st August 2008, 20:06 | #90 | Link | |
aka XaS
Or even a whitelist with authorised programs in which mplayer isn't listed ? What if you rename to somethingelse.exe ?
21st August 2008, 20:06 | #91 | Link |
Software Developer
The network cannot cause the problem, because the MPlayer process won't open any network connections before writing the copyright notice and stuff to stdout.
Unless you try to open a web stream, it won't open any network connection at all... I guess it's some "conflicting" software, which is installed on all the computers at work. Maybe some tool that prevents workers from stating up "entertainment" software or buggy A/V software ?!?!?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st August 2008 at 20:13. |
21st August 2008, 21:40 | #92 | Link |
DarkZell666> As I already wrote renaming the EXE doesn't help. Also almost all other programs (in portable versions) work without any problems.
LoRd_MuldeR> Yes, this is also what I think. Maybe antivirus (which I can't stop) is causing it. But I'm wondering how it can identify that the process is MPlayer. |
21st August 2008, 22:03 | #93 | Link |
Software Developer
Hash? Signature? Heuristics? ...
21st August 2008, 22:11 | #94 | Link | |
aka XaS
Well, antiviruses identify viruses directly by detecting "bytecode patterns", or so to say. It would be very farfetched to think they actually built a signature to forbid mplayer, but technically it's possible imho. As MuldeR says, some companies use hidden processes to actually do just that sort of thing. They can even detect forbidden processes remotely (how cool is that ? ... lol). How exactly they detect mplayer depends on the product. Right-click on mplayer.exe and check the "version" tab. Some of them maybe use the info from in there, dunno ... There's tons of meta-information to be used to identify a program, and the "version" tab is only part of it
22nd August 2008, 19:19 | #96 | Link |
LoRd_MuldeR
Thank you for your wonderful job. Two question: *if I put the mplayer window in some position on the screen there is an option to retain this position when the next title from my playlist is played? *when i make some changes on brightness/contrast there is an option to retain these settings when the next title from my play list is played? when the next title is played MPlayer redraw some default values... MPLayer is wonderful to play music too... sorry but i use one old 10/2007 version. All the newest mplayer versions have 40-50% more CPU using... i do not know why this happen, but anyway... great player... the best literally. Last edited by panzerino; 22nd August 2008 at 21:32. |
23rd August 2008, 12:19 | #99 | Link |
As i previously stated in this thread, then the MPlayer build that's included in the latest official MPUI package(dev-SVN-r26251-3.4.2 from the 15th of march '08 which is compiled with CPU runtime-detection), uses less CPU cycles and RAM while also being 1.8mb smaller than the P4 optimized "Sherpya" build(Sherpya-SVN-r27323-4.2.4) that's included in MuldeR's latest installer...
Direct-link to a zip archive with the lighter/smaller MPlayer-SVN-r26251: http://garr.dl.sourceforge.net/sourc...SVN-r26251.zip |
23rd August 2008, 12:58 | #100 | Link | |
Software Developer
mplayer, mpui, player, smplayer, win32 |
