1st July 2021, 14:58 | #30701 | Link |
Life's clearer in 4K UHD
Indeed and agreed
1st July 2021, 15:10 | #30702 | Link | |
Even though I need sleep, it is all a little clearer now. |
1st July 2021, 15:32 | #30703 | Link | |
1024 bytes = 1 kb etc As for the math, not necessary. The multiplier is 1024, so 22.95 GB is just shy of 23500 MB (numerically speaking, not size) so it should be the same. For the compulsive types just use the 1024 multiplier to comfirm |
1st July 2021, 15:33 | #30704 | Link | |
2nd July 2021, 00:12 | #30705 | Link | |
The point I'm trying to make, in order to make it easier and not confuse the human reader, i to use the MB number for both locations, or the GB number for both location. It is human nature to just take the 23500 MB number and turn it into 23.5 GB. That is what I did and as it turns out, that is wrong. |
2nd July 2021, 00:21 | #30706 | Link |
Here we go again...
OK, so I'm still having problems when BDRB is converting audio tracks to AC3. Any DTS, DTS-MA, True-HD, or LPCM tracks get converted to AC3 MONO. I've never had this problem before so something has recently changed with the way the audio tracks are being converted. This happens on any disc I've tried, regardless of what the original track format is.
Ex: Converting my Bad Santa disc to BD9 Movie-only UHD-HEVC format. The disc contains a LPCM 5.1 track that I choose to convert to AC3. Everything seems to go as planned until I try to play the resulting directory in MPC-HC. MPC-HC opens the movie, but the movie will not start, it just hangs at 00:00. Log, .inf and MediaInfo below. Running the same disc thru ClownBD or the aforementioned UsEac3to are converted correctly. I can then load the movie into BDRB and convert to UHD-HEVC from there. So something is wonky with the way BDRB is converting the tracks. Don't take my word for it, try it yourself with any disc and convert to AC3 and see what you come up with. Thanks for any suggestions... BDRB Log: Code:
[07/01/21] BD Rebuilder v0.61.22 [12:14:31] Source: BST1NND1_BADDERSANTA_00025 - Input BD size: 21.16 GB - Approximate total content: [01:39:16.408] - Target BD size: 7.84 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), 1-Pass VBR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [12:14:33] PHASE ONE, Encoding - [12:14:33] Processing: VID_00076 (1 of 1) - [12:14:33] Extracting A/V streams [VID_00076] - [12:17:26] Reencoding video [VID_00076] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 142,811 frames - Bitrate: 9,715 Kbs - [12:17:26] Reencoding: VID_00076, Pass 1 of 1 - [12:29:47] Video Encode complete - [12:29:47] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [12:30:07]PHASE ONE complete [12:30:07]PHASE TWO - Rebuild Started - [12:30:07] Rebuilding AVCHD file Structure [12:30:21] - Encode and Rebuild complete - WORKFILES folder removed. [12:30:22] JOB: BST1NND1_BADDERSANTA finished. Code:
[Status] LABEL=BST1NND1_BADDERSANTA VERSION=v0.61.22 SOURCE_SIZE=22719553536 SOURCE_VIDEO_SIZE=22719553536 TARGET_SIZE=8422162432 REDUCTION=.370701053550844 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=4 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00076] AUDIO=10 PGS=1 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8422162432 RATE=9715 NSIZE=0 FLINK=0 MLINK=0 Code:
General Complete name : C:\Users\eM-SSD\Videos\1080p_HEVC\BST1NND1_BADDERSANTA\\BDMV\PLAYLIST\00000.mpls Format : Blu-ray Playlist File size : 512 Bytes Duration : 1 h 39 min Overall bit rate : 1 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4.1@High Codec ID : 36 Duration : 1 h 39 min Bit rate : 9 174 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.185 Stream size : 6.36 GiB Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 1 h 39 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 454 MiB Language : English Service kind : Complete Main bsid : 8 Dialog Normalization : -31 Dialog Normalization : -31 dB acmod : 1 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 1 format_identifier : AC-3 SamplingCount_Source : General_Duration Duration_Source : General_Duration Source : 00000.m2ts / 00000.m2ts Last edited by spotswood; 4th July 2021 at 21:15. Reason: clarification... |
2nd July 2021, 00:38 | #30707 | Link | |
@spotswood
Could you outline the entire process you go through. I notice from your log that the source movie is only 21.16GB. That doesn't sound large enough to be from an original BD -- so I'm assuming you are importing? I'm guessing whatever is causing this has to be specific to your system, as I'm getting no other reports of mono output. I would expect that to be pretty noticeable. If anyone else is seeing this issue -- please chime in. I can't think of any significant changes recently to the audio processing. You haven't replaced any of the included utilities with other versions? Quote:
2nd July 2021, 03:39 | #30708 | Link | ||||
Movie & Menus Log: Code:
---------------------- [07/01/21] BD Rebuilder v0.61.22 [13:29:00] Source: BST1NND1_BADDERSANTA - Input BD size: 42.67 GB - Approximate total content: [04:08:03.576] - Target BD size: 7.84 GB - Windows Version: 6.2 [9200] - MOVIE and MENUS mode enabled - Quality: High Quality (Default), 1-Pass VBR - Converting to UHD-BD (HEVC) output format - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [13:29:00] PHASE ONE, Encoding - [13:29:00] Blanking: VID_00000 (1 of 32) - [13:29:00] Blanking: VID_00001 (2 of 32) - [13:29:00] Blanking: VID_00002 (3 of 32) - [13:29:00] Blanking: VID_00009 (4 of 32) - [13:29:00] Blanking: VID_00011 (5 of 32) - [13:29:00] Blanking: VID_00023 (6 of 32) - [13:29:00] Blanking: VID_00024 (7 of 32) - [13:29:00] Processing: VID_00043 (8 of 32) - [13:29:00] Extracting A/V streams [VID_00043] - [13:29:05] Reencoding video [VID_00043] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,085 frames - Bitrate: 826 Kbs - [13:29:05] Reencoding: VID_00043, Pass 1 of 1 - [13:29:08] Video Encode complete - [13:29:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:29:08] Multiplexing M2TS - [13:29:12] Processing: VID_00064 (9 of 32) - [13:29:12] Extracting A/V streams [VID_00064] - [13:29:17] Reencoding video [VID_00064] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,440 frames - [13:29:17] Reencoding: VID_00064, Pass 1 of 1 - [13:29:25] Video Encode complete - [13:29:25] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [13:29:25] Multiplexing M2TS - [13:29:29] Processing: VID_00076 (10 of 32) - [13:29:29] Extracting A/V streams [VID_00076] - [13:32:23] Reencoding video [VID_00076] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 142,811 frames - Bitrate: 4,393 Kbs - [13:32:23] Reencoding: VID_00076, Pass 1 of 1 - [13:44:09] Video Encode complete - [13:44:09] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [13:44:17] Multiplexing M2TS - [13:44:25] Processing: VID_00078 (11 of 32) - [13:44:25] Extracting A/V streams [VID_00078] - [13:44:30] Reencoding video [VID_00078] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 12 frames - [13:44:30] Reencoding: VID_00078, Pass 1 of 1 - [13:44:31] Video Encode complete - [13:44:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [13:44:31] Multiplexing M2TS - [13:44:35] Blanking: VID_00091 (12 of 32) - [13:44:35] Blanking: VID_00109 (13 of 32) - [13:44:35] Blanking: VID_00130 (14 of 32) - [13:44:35] Blanking: VID_00131 (15 of 32) - [13:44:35] Blanking: VID_00132 (16 of 32) - [13:44:35] Processing: VID_00133 (17 of 32) - [13:44:35] Extracting A/V streams [VID_00133] - [13:46:00] Reencoding video [VID_00133] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 72,592 frames - Bitrate: 4,547 Kbs - [13:46:00] Reencoding: VID_00133, Pass 1 of 1 - [13:52:02] Video Encode complete - [13:52:02] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [13:52:10] Multiplexing M2TS - [13:52:16] Processing: VID_00134 (18 of 32) - [13:52:16] Extracting A/V streams [VID_00134] - [13:53:15] Reencoding video [VID_00134] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 54,763 frames - Bitrate: 4,263 Kbs - [13:53:15] Reencoding: VID_00134, Pass 1 of 1 - [13:57:47] Video Encode complete - [13:57:47] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [13:57:50] Multiplexing M2TS - [13:57:55] Processing: VID_00136 (19 of 32) - [13:57:55] Extracting A/V streams [VID_00136] - [13:58:00] Reencoding video [VID_00136] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,694 frames - Bitrate: 822 Kbs - [13:58:00] Reencoding: VID_00136, Pass 1 of 1 - [13:58:03] Video Encode complete - [13:58:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:58:03] Multiplexing M2TS - [13:58:07] Processing: VID_00137 (20 of 32) - [13:58:07] Extracting A/V streams [VID_00137] - [13:58:12] Reencoding video [VID_00137] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 7,228 frames - Bitrate: 824 Kbs - [13:58:12] Reencoding: VID_00137, Pass 1 of 1 - [13:58:18] Video Encode complete - [13:58:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:58:18] Multiplexing M2TS - [13:58:22] Processing: VID_00138 (21 of 32) - [13:58:22] Extracting A/V streams [VID_00138] - [13:58:26] Reencoding video [VID_00138] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,277 frames - Bitrate: 820 Kbs - [13:58:26] Reencoding: VID_00138, Pass 1 of 1 - [13:58:30] Video Encode complete - [13:58:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:58:30] Multiplexing M2TS - [13:58:34] Processing: VID_00139 (22 of 32) - [13:58:34] Extracting A/V streams [VID_00139] - [13:58:38] Reencoding video [VID_00139] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,982 frames - Bitrate: 835 Kbs - [13:58:38] Reencoding: VID_00139, Pass 1 of 1 - [13:58:41] Video Encode complete - [13:58:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:58:41] Multiplexing M2TS - [13:58:45] Processing: VID_00140 (23 of 32) - [13:58:45] Extracting A/V streams [VID_00140] - [13:58:55] Reencoding video [VID_00140] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 49,444 frames - Bitrate: 817 Kbs - [13:58:55] Reencoding: VID_00140, Pass 1 of 1 - [13:59:32] Video Encode complete - [13:59:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:59:32] Multiplexing M2TS - [13:59:36] Blanking: VID_00141 (24 of 32) - [13:59:36] Blanking: VID_00142 (25 of 32) - [13:59:36] Blanking: VID_00143 (26 of 32) - [13:59:36] Processing: VID_00144 (27 of 32) - [13:59:36] Extracting A/V streams [VID_00144] - [13:59:41] Reencoding video [VID_00144] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,362 frames - Bitrate: 1,881 Kbs - [13:59:41] Reencoding: VID_00144, Pass 1 of 1 - [13:59:49] Video Encode complete - [13:59:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [13:59:49] Multiplexing M2TS - [13:59:53] Processing: VID_00147 (28 of 32) - [13:59:53] Extracting A/V streams [VID_00147] - [13:59:57] Reencoding video [VID_00147] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 829 frames - Bitrate: 1,214 Kbs - [13:59:57] Reencoding: VID_00147, Pass 1 of 1 - [14:00:03] Video Encode complete - [14:00:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [14:00:03] Multiplexing M2TS - [14:00:06] Processing: VID_00149 (29 of 32) - [14:00:06] Extracting A/V streams [VID_00149] - [14:00:11] Reencoding video [VID_00149] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,440 frames - Bitrate: 700 Kbs - [14:00:11] Reencoding: VID_00149, Pass 1 of 1 - [14:00:19] Video Encode complete - [14:00:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [14:00:19] Multiplexing M2TS - [14:00:23] Processing: VID_00151 (30 of 32) - [14:00:23] Extracting A/V streams [VID_00151] - [14:00:28] Reencoding video [VID_00151] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12 frames - [14:00:28] Reencoding: VID_00151, Pass 1 of 1 - [14:00:29] Video Encode complete - [14:00:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [14:00:29] Multiplexing M2TS - [14:00:33] Processing: VID_00153 (31 of 32) - [14:00:33] Extracting A/V streams [VID_00153] - [14:00:37] Reencoding video [VID_00153] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 90 frames - Bitrate: 2,430 Kbs - [14:00:37] Reencoding: VID_00153, Pass 1 of 1 - [14:00:38] Video Encode complete - [14:00:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:00:38] Multiplexing M2TS - [14:00:42] Blanking: VID_00154 (32 of 32) [14:00:42]PHASE ONE complete [14:00:42]PHASE TWO - Rebuild Started - [14:00:42] Rebuilding BD file Structure [14:00:44] - Encode and Rebuild complete - WORKFILES folder removed. [14:00:45] JOB: BST1NND1_BADDERSANTA finished. Quote:
2nd July 2021, 04:16 | #30709 | Link | |
6th July 2021, 17:31 | #30710 | Link |
I, too, have experienced some randomness with EC3 (E-AC3) 5.1 audio. I have seen BDRB do all of these things depending on the source material (and without changing any BDRB settings between different titles):
- keep the original audio (I think!) - re-encode to AC3 5.1 - misinterpret the number of channels down to either 1 (mono) or 2 and re-encode to AC3 accordingly. I can't work out why some succeed with original audio and why some need re-encoding. But I'm not too bothered either way. It's the wholly incorrect conversions that are of concern. Interestingly any such title, if placed into tsMuXer also reports an incorrect number of channels. However Handbrake sees the right channel format and will re-encode audio to DD5.1. Sadly, handbrake has to encode video alongside so it does take a while. I'm guessing that the EC-3 encode is in some way corrupted and isn't "seen" by some (but not all) apps as having the actual channel setup. MediaInfo also reports them correctly. So what I have done with these titles - and this appears to work - is 1: Re-encode using Handbrake, with video settings at their lowest quality, fastest (etc etc) values for best speed with no concern for picture quality at all. 2: tsMuxer to place the Handbrake soundtrack (only) against the source video (only) discarding the EC3 audio and poor quality video from Handbrake. 3: and then put that into BDRB to get a finished product. For example, using one source MediaInfo: Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : ec-3 Duration : 1 h 40 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 458 MiB (4%) Language : English Service kind : Complete Main Encoded date : UTC 2021-06-25 14:22:13 Tagged date : UTC 2021-06-25 14:22:13 Looks like this in tsMuxer (see 1.gif attached) (channels: 2) Has produced this in BDRB (MediaInfo of the imported m2ts file) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 1 h 40 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 458 MiB (4%) Service kind : Complete Main Handbrake sees it like this (see attachment 2.gif) and will generate a correct AC3 DD 5.1 audo track from it. 1 English (E-AC3) (5.1ch) (640kbps) VLC says this under codec data: Codec: ec-3 Language: English Type: Audio Channels: 3F2M/LFE Sample rate: 48000 Hz Bits per sample: 32 Last edited by RetsimLegin; 2nd September 2021 at 09:11. |
6th July 2021, 22:09 | #30711 | Link |
Hello all... hope everyone had a good holiday weekend. Has anyone tried to reencode a BD with a lossless track (True-HD/Atmos, DTS-MA etc.) to AC3? What were your findings?
I tried it again with my The Good, The Bad and The Ugly BD that has a DTS-MA track. Way overkill for this title, so again I set up BDRB to reencode the DTS-MA track to AC3. Same result, the DTS-MA track is converted to AC3 Mono. @jdobbs... if you need any other info than the logs below, let me know. I have saved the workfiles folder from this job... System settings: Code:
[07/06/21] Checking System Settings - BD-Rebuilder v0.61.22 - Windows Version: 6.2 [9200] - Working Path Free Space: 157.42GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [07/06/21] Systems Settings Check complete Code:
---------------------- [07/06/21] BD Rebuilder v0.61.22 [09:51:52] Source: THE_GOOD_THE_BAD_AND_THE_UGLY_00800 - Input BD size: 39.98 GB - Approximate total content: [02:58:36.622] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), 1-Pass VBR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [09:51:52] PHASE ONE, Encoding - [09:51:52] Processing: VID_01559 (1 of 1) - [09:51:52] Extracting A/V streams [VID_01559] - [10:00:01] Reencoding video [VID_01559] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 256,942 frames - Bitrate: 15,731 Kbs - [10:00:01] Reencoding: VID_01559, Pass 1 of 1 - [10:22:50] Video Encode complete - [10:22:50] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [10:23:09]PHASE ONE complete [10:23:09]PHASE TWO - Rebuild Started - [10:23:09] Rebuilding BD file Structure [10:23:43] - Encode and Rebuild complete [10:23:43] JOB: THE_GOOD_THE_BAD_AND_THE_UGLY finished. Code:
[Status] LABEL=THE_GOOD_THE_BAD_AND_THE_UGLY VERSION=v0.61.22 SOURCE_SIZE=42932496384 SOURCE_VIDEO_SIZE=42932496384 TARGET_SIZE=24641536000 REDUCTION=.573960008744876 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=4 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [01559] AUDIO=10000000 PGS=100000000000000000 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 RATE=15731 NSIZE=0 FLINK=0 MLINK=0 Code:
General Complete name : C:\Users\eM-SSD\Videos\1080p_HEVC\THE_GOOD_THE_BAD_AND_THE_UGLY\\BDMV\PLAYLIST\00000.mpls Format : Blu-ray Playlist File size : 694 Bytes Duration : 2 h 58 min Overall bit rate : 1 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4.1@High Codec ID : 36 Duration : 2 h 58 min Bit rate : 15.2 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.307 Stream size : 19.0 GiB Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 h 58 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 818 MiB Language : English Service kind : Complete Main bsid : 8 Dialog Normalization : -31 Dialog Normalization : -31 dB acmod : 1 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 1 format_identifier : AC-3 SamplingCount_Source : General_Duration Duration_Source : General_Duration Source : 00000.m2ts / 00000.m2ts Last edited by spotswood; 6th July 2021 at 22:27. |
6th July 2021, 22:19 | #30712 | Link |
Regarding the above... I can get what I want by running the disc through ClownBD first, which correctly converts the DTS-MA track to AC3 5.1@640, and then load the resulting BD folder output into BDRB. From there I convert to UHD-HEVC format and the finished output plays perfectly in MPC-HC and/or Kodi with both the audio and video in sync.
I don't mind the extra step, I just can't figure out why BDRB is having problems with the audio conversion when it never had that problem before. Thanks again for any help, suggestions or recommendations. Last edited by spotswood; 6th July 2021 at 22:29. Reason: addl. info |
7th July 2021, 04:02 | #30713 | Link |
Greetings all,
I'd like to see if anyone else has seen similar. For me, 61.22 was a regression. I think it might have to do with the way nvencc was built, if it was changed. The last build, 61.21, I was able to re-encode using my GPU, at least the utilization rate was quite high for both the GPU and the CPU. I thought it is likely to be nvencc, because I have another software I use and recently they decided to no longer build for win8.1 on an update. In their changelog, they decided to only build for the latest on Win10, I feel like something similar may be happening with nvencc in bdrb which is frustrating. Yes, 8.1 is older, but I built this as a HTPC and last year bought this graphics card with the intent to encode many of the discs from my library, and not have it rely on my mediocre i5. I just bought all 6 seasons of The Clone Wars, but so far it has been a disaster trying to get them re-encoded correctly. So here is some of the info, My system: Code:
Operating System: Windows 8.1 Pro with Media Center, 64-bit DirectX version: 11.0 GPU processor: GeForce GTX 1660 Driver version: 452.06 Driver Type: Standard Direct3D API version: 11.2 Direct3D feature level: 12_1 CUDA Cores: 1408 Core clock: 1785 MHz Memory data rate: 8.00 Gbps Memory interface: 192-bit Memory bandwidth: 192.05 GB/s Total available graphics memory: 10147 MB Dedicated video memory: 6144 MB GDDR5 System video memory: 0 MB Shared system memory: 4003 MB Bus: PCI Express x16 Gen3 nvDevToolS.dll 27.21.14.5206 NVIDIA 3D Settings Server PhysX 09.19.0218 NVIDIA PhysX NVCUDA64.DLL 27.21.14.5206 NVIDIA CUDA 11.0.228 driver My 61.21 output: Code:
61.21 [07/01/21] Checking System Settings - BD-Rebuilder v0.61.21 - Windows Version: 6.2 [9200] - Working Path Free Space: 571.73GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [07/01/21] Systems Settings Check complete ---------------------- [07/01/21] BD Rebuilder v0.61.21 [23:52:08] Source: TOP_GUN_00001 - Input BD size: 33.72 GB - Approximate total content: [01:49:35.569] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Quality: Highest (Very Slow) - Automatic cropping of borders enabled - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [23:52:13] PHASE ONE, Encoding - [23:52:13] Processing: VID_00001 (1 of 1) - [23:52:13] Extracting A/V streams [VID_00001] - [23:55:17] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 157,656 frames - Bitrate: 5,000 Kbs - [23:55:17] Reencoding: VID_00001, Pass 1 of 2 - [00:13:45] Reencoding: VID_00001, Pass 2 of 2 - [00:13:45] Video Encode complete - [00:13:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio [00:13:45]PHASE ONE complete [00:13:45]PHASE TWO - Rebuild Started - [00:13:45] Building ALTERNATE OUTPUT Structure [00:15:24] - Encode and Rebuild complete [00:15:24] JOB: TOP_GUN finished. Code:
[Status] LABEL=TOP_GUN VERSION=v0.61.21 SOURCE_SIZE=36207679488 SOURCE_VIDEO_SIZE=36207679488 TARGET_SIZE=24641536000 REDUCTION=.680561039769664 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=11 USE_LAVF=0 INSTANCES=2 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00001] AUDIO=11000 PGS=10000 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 NSIZE=0 My 61.22 output fails on every attempt: Code:
61.22 [07/01/21] Checking System Settings - BD-Rebuilder v0.61.22 - Windows Version: 6.2 [9200] - Working Path Free Space: 566.96GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [07/01/21] Systems Settings Check complete ---------------------- [07/01/21] BD Rebuilder v0.61.22 [20:42:38] Source: TOP_GUN_00001 - Input BD size: 33.72 GB - Approximate total content: [01:49:35.569] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Quality: High Quality (Default) - Automatic cropping of borders enabled - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:42:41] PHASE ONE, Encoding - [20:42:41] Processing: VID_00001 (1 of 1) - [20:42:41] Extracting A/V streams [VID_00001] - [20:45:48] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 157,656 frames - [20:45:48] Reencoding: VID_00001, Pass 1 of 1 [20:45:49] - Failed video encode, aborted ---------------------- [07/01/21] BD Rebuilder v0.61.22 [20:52:42] Source: TOP_GUN_00001 - Input BD size: 33.72 GB - Approximate total content: [01:49:35.569] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Quality: High Quality (Default) - Automatic cropping of borders enabled - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:53:01] PHASE ONE, Encoding - [20:53:01] Processing: VID_00001 (1 of 1) - [20:53:01] Extracting A/V streams [VID_00001] - [20:56:07] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 157,656 frames - [20:56:07] Reencoding: VID_00001, Pass 1 of 1 [20:56:09] - Failed video encode, aborted Code:
copyHtoD: failed to allocate memory: cudaErrorUnsupportedPtxVersion Finally, if any of you brilliant minds can see any issues with my encode settings on 61.21? Even though it completed the encode, there were A LOT of artifacts on the encode. Previously, I've been using just the CPU for encoding, not the nvencc/GPU. I don't recall getting such poor quality, but I'm guessing that this probably has to do with my settings. Thank you everyone for any assistance and for also realizing that I'm highly unlikely to upgrade to Win10. |
10th July 2021, 14:41 | #30716 | Link |
Yeah, nevermind .. I found one...
Original: Code:
General ID : 0 (0x0) Complete name : V:\FullDisc\SONIC_THE_HEDGEHOG\BDMV\STREAM\00351.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 28.7 GiB Duration : 1 h 38 min Overall bit rate mode : Variable Overall bit rate : 41.5 Mb/s Maximum Overall bit rate : 48.0 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : 27 Duration : 1 h 38 min Bit rate mode : Variable Bit rate : 33.8 Mb/s Maximum bit rate : 29.9 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.681 Stream size : 23.4 GiB (81%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : MLP FBA AC-3 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Format settings : Dolby Surround EX Muxing mode : Stream extension Codec ID : 131 Duration : 1 h 38 min Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 7 872 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossless Stream size : 453 MiB (2%) Service kind : Complete Main Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE Code:
General ID : 1 (0x1) Complete name : F:\BDMV\STREAM\00351.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 17.2 GiB Duration : 1 h 38 min Overall bit rate mode : Variable Overall bit rate : 24.9 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Format settings, GOP : M=4, N=24 Codec ID : 27 Duration : 1 h 38 min Bit rate mode : Variable Bit rate : 22.5 Mb/s Maximum bit rate : 35.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.453 Stream size : 15.6 GiB (91%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround EX Codec ID : 129 Duration : 1 h 38 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 453 MiB (3%) Service kind : Complete Main |
13th July 2021, 04:37 | #30720 | Link |
Special SeeD
BD Rebuilder fails when using DGIndexNV + x264 + Blank Extras.
For some reason is calling FRIMSOURCE instead of DGIndexNV when encoding small files, my PC is AMD so... it fails. Code:
#Created by BD Rebuilder - v0.61.18 LoadPlugin("D:\Archivos de Programa\BD Rebuilder\tools\frimsource.dll") FRIMSource(codec="h264",filename="E:\BOB ESPONJA\BDMV\STREAM\01138.m2ts",container="ts",platform="hw",num_frames=361,cache=24) ConvertToYV12().AssumeFPS(24000,1001) Code:
---------------------- [07/12/21] BD Rebuilder v0.61.18 [20:02:29] Source: BOB ESPONJA - Input BD size: 39.32 GB - Approximate total content: [02:35:08.714] - Target BD size: 23.44 GB - Windows Version: 6.2 [9200] - MOVIE and MENUS mode enabled - Quality: High Quality (Default), Two Pass - X264 Tweak(s) enabled - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:02:29] PHASE ONE, Encoding - [20:02:29] Blanking: VID_00051 (1 of 97) - [20:02:29] Blanking: VID_00053 (2 of 97) - [20:02:29] Processing: VID_00800 (3 of 97) - [20:02:29] Extracting A/V streams [VID_00800] - [20:03:51] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 131,652 frames - Bitrate: 16,584 Kbs - [20:03:51] Reencoding: VID_00800, Pass 1 of 2 - [20:19:12] Reencoding: VID_00800, Pass 2 of 2 - [20:50:16] Video Encode complete - [20:50:16] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4356 (spa): Keeping original audio - Track 4357 (spa): Keeping original audio - Track 4360 (jpn): Keeping original audio - [20:50:16] Multiplexing M2TS - [20:50:38] Processing: VID_01007 (4 of 97) - [20:50:38] Extracting A/V streams [VID_01007] - [20:50:42] Reencoding video [VID_01007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 531 frames - Bitrate: 13,625 Kbs - [20:50:42] Reencoding: VID_01007, Pass 1 of 2 - [20:50:47] Reencoding: VID_01007, Pass 2 of 2 - [20:50:56] Video Encode complete - [20:50:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:50:56] Multiplexing M2TS - [20:50:59] Processing: VID_01008 (5 of 97) - [20:51:00] Extracting A/V streams [VID_01008] - [20:51:04] Reencoding video [VID_01008] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 531 frames - Bitrate: 13,625 Kbs - [20:51:04] Reencoding: VID_01008, Pass 1 of 2 - [20:51:09] Reencoding: VID_01008, Pass 2 of 2 - [20:51:18] Video Encode complete - [20:51:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:51:18] Multiplexing M2TS - [20:51:22] Processing: VID_01009 (6 of 97) - [20:51:22] Extracting A/V streams [VID_01009] - [20:51:26] Reencoding video [VID_01009] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 531 frames - Bitrate: 13,625 Kbs - [20:51:26] Reencoding: VID_01009, Pass 1 of 2 - [20:51:31] Reencoding: VID_01009, Pass 2 of 2 - [20:51:40] Video Encode complete - [20:51:40] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:51:40] Multiplexing M2TS ... - [20:51:44] Processing: VID_01115 (59 of 97) - [20:51:44] Extracting A/V streams [VID_01115] - [20:51:51] Reencoding video [VID_01115] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,965 frames - Bitrate: 18,325 Kbs - [20:51:51] Reencoding: VID_01115, Pass 1 of 2 - [20:52:34] Reencoding: VID_01115, Pass 2 of 2 - [20:54:10] Video Encode complete - [20:54:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4355 (spa): Keeping original audio - Track 4356 (spa): Keeping original audio - Track 4359 (jpn): Keeping original audio - [20:54:10] Multiplexing M2TS - [20:54:15] Processing: VID_01116 (60 of 97) - [20:54:15] Extracting A/V streams [VID_01116] - [20:54:20] Reencoding video [VID_01116] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,381 frames - Bitrate: 17,283 Kbs - [20:54:20] Reencoding: VID_01116, Pass 1 of 2 - [20:54:56] Reencoding: VID_01116, Pass 2 of 2 - [20:56:09] Video Encode complete - [20:56:09] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:56:09] Multiplexing M2TS - [20:56:13] Processing: VID_01117 (61 of 97) - [20:56:13] Extracting A/V streams [VID_01117] - [20:56:18] Reencoding video [VID_01117] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,920 frames - Bitrate: 17,083 Kbs - [20:56:18] Reencoding: VID_01117, Pass 1 of 2 - [20:56:34] Reencoding: VID_01117, Pass 2 of 2 - [20:57:03] Video Encode complete - [20:57:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:57:03] Multiplexing M2TS - [20:57:07] Processing: VID_01118 (62 of 97) - [20:57:07] Extracting A/V streams [VID_01118] - [20:57:13] Reencoding video [VID_01118] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,968 frames - Bitrate: 16,988 Kbs - [20:57:13] Reencoding: VID_01118, Pass 1 of 2 - [20:57:53] Reencoding: VID_01118, Pass 2 of 2 - [20:59:15] Video Encode complete - [20:59:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:59:15] Multiplexing M2TS - [20:59:19] Processing: VID_01119 (63 of 97) - [20:59:19] Extracting A/V streams [VID_01119] - [20:59:25] Reencoding video [VID_01119] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,073 frames - Bitrate: 16,994 Kbs - [20:59:25] Reencoding: VID_01119, Pass 1 of 2 - [20:59:57] Reencoding: VID_01119, Pass 2 of 2 - [21:01:01] Video Encode complete - [21:01:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:01:01] Multiplexing M2TS - [21:01:05] Processing: VID_01121 (64 of 97) - [21:01:05] Extracting A/V streams [VID_01121] - [21:01:09] Reencoding video [VID_01121] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 14,252 Kbs - [21:01:09] Reencoding: VID_01121, Pass 1 of 2 - [21:01:11] Reencoding: VID_01121, Pass 2 of 2 - [21:01:13] Video Encode complete - [21:01:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:01:13] Multiplexing M2TS - [21:01:17] Processing: VID_01122 (65 of 97) - [21:01:17] Extracting A/V streams [VID_01122] - [21:01:22] Reencoding video [VID_01122] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,457 frames - Bitrate: 14,586 Kbs - [21:01:22] Reencoding: VID_01122, Pass 1 of 2 - [21:01:44] Reencoding: VID_01122, Pass 2 of 2 - [21:02:07] Video Encode complete - [21:02:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:02:07] Multiplexing M2TS - [21:02:11] Processing: VID_01123 (66 of 97) - [21:02:11] Extracting A/V streams [VID_01123] - [21:02:16] Reencoding video [VID_01123] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,664 frames - Bitrate: 14,271 Kbs - [21:02:17] Reencoding: VID_01123, Pass 1 of 2 - [21:02:25] Reencoding: VID_01123, Pass 2 of 2 - [21:02:34] Video Encode complete - [21:02:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:02:34] Multiplexing M2TS - [21:02:38] Processing: VID_01124 (67 of 97) - [21:02:38] Extracting A/V streams [VID_01124] - [21:02:42] Reencoding video [VID_01124] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 14,252 Kbs - [21:02:42] Reencoding: VID_01124, Pass 1 of 2 - [21:02:43] Reencoding: VID_01124, Pass 2 of 2 - [21:02:45] Video Encode complete - [21:02:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:02:46] Multiplexing M2TS - [21:02:49] Processing: VID_01125 (68 of 97) - [21:02:49] Extracting A/V streams [VID_01125] - [21:02:54] Reencoding video [VID_01125] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 14,198 Kbs - [21:02:54] Reencoding: VID_01125, Pass 1 of 2 - [21:02:55] Reencoding: VID_01125, Pass 2 of 2 - [21:02:57] Video Encode complete - [21:02:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:02:57] Multiplexing M2TS - [21:03:01] Processing: VID_01126 (69 of 97) - [21:03:01] Extracting A/V streams [VID_01126] - [21:03:07] Reencoding video [VID_01126] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,222 frames - Bitrate: 16,721 Kbs - [21:03:07] Reencoding: VID_01126, Pass 1 of 2 - [21:04:00] Reencoding: VID_01126, Pass 2 of 2 - [21:05:46] Video Encode complete - [21:05:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:05:46] Multiplexing M2TS - [21:05:51] Processing: VID_01127 (70 of 97) - [21:05:51] Extracting A/V streams [VID_01127] - [21:05:56] Reencoding video [VID_01127] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,457 frames - Bitrate: 16,709 Kbs - [21:05:56] Reencoding: VID_01127, Pass 1 of 2 - [21:06:23] Reencoding: VID_01127, Pass 2 of 2 - [21:07:14] Video Encode complete - [21:07:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:07:14] Multiplexing M2TS - [21:07:19] Processing: VID_01129 (71 of 97) - [21:07:19] Extracting A/V streams [VID_01129] - [21:07:23] Reencoding video [VID_01129] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 14,198 Kbs - [21:07:23] Reencoding: VID_01129, Pass 1 of 2 - [21:07:24] Reencoding: VID_01129, Pass 2 of 2 - [21:07:27] Video Encode complete - [21:07:27] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:07:27] Multiplexing M2TS - [21:07:30] Processing: VID_01130 (72 of 97) - [21:07:30] Extracting A/V streams [VID_01130] - [21:07:39] Reencoding video [VID_01130] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,317 frames - Bitrate: 16,744 Kbs - [21:07:39] Reencoding: VID_01130, Pass 1 of 2 - [21:09:13] Reencoding: VID_01130, Pass 2 of 2 - [21:12:43] Video Encode complete - [21:12:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:12:43] Multiplexing M2TS - [21:12:48] Processing: VID_01131 (73 of 97) - [21:12:48] Extracting A/V streams [VID_01131] - [21:12:55] Reencoding video [VID_01131] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,636 frames - Bitrate: 16,744 Kbs - [21:12:55] Reencoding: VID_01131, Pass 1 of 2 - [21:13:54] Reencoding: VID_01131, Pass 2 of 2 - [21:16:00] Video Encode complete - [21:16:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:16:00] Multiplexing M2TS - [21:16:05] Processing: VID_01132 (74 of 97) - [21:16:05] Extracting A/V streams [VID_01132] - [21:16:10] Reencoding video [VID_01132] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,092 frames - Bitrate: 16,900 Kbs - [21:16:10] Reencoding: VID_01132, Pass 1 of 2 - [21:16:30] Reencoding: VID_01132, Pass 2 of 2 - [21:17:09] Video Encode complete - [21:17:09] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:17:09] Multiplexing M2TS - [21:17:13] Processing: VID_01133 (75 of 97) - [21:17:13] Extracting A/V streams [VID_01133] - [21:17:17] Reencoding video [VID_01133] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 14,232 Kbs - [21:17:17] Reencoding: VID_01133, Pass 1 of 2 - [21:17:18] Reencoding: VID_01133, Pass 2 of 2 - [21:17:20] Video Encode complete - [21:17:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:17:20] Multiplexing M2TS - [21:17:24] Processing: VID_01134 (76 of 97) - [21:17:24] Extracting A/V streams [VID_01134] - [21:17:28] Reencoding video [VID_01134] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 17,100 Kbs - [21:17:28] Reencoding: VID_01134, Pass 1 of 2 - [21:17:30] Reencoding: VID_01134, Pass 2 of 2 - [21:17:31] Video Encode complete - [21:17:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:17:31] Multiplexing M2TS - [21:17:35] Processing: VID_01135 (77 of 97) - [21:17:35] Extracting A/V streams [VID_01135] - [21:17:39] Reencoding video [VID_01135] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 96 frames - Bitrate: 17,046 Kbs - [21:17:39] Reencoding: VID_01135, Pass 1 of 2 - [21:17:41] Reencoding: VID_01135, Pass 2 of 2 - [21:17:43] Video Encode complete - [21:17:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:17:43] Multiplexing M2TS - [21:17:46] Processing: VID_01136 (78 of 97) - [21:17:46] Extracting A/V streams [VID_01136] - [21:17:52] Reencoding video [VID_01136] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,032 frames - Bitrate: 16,702 Kbs - [21:17:52] Reencoding: VID_01136, Pass 1 of 2 - [21:18:13] Reencoding: VID_01136, Pass 2 of 2 - [21:18:56] Video Encode complete - [21:18:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:18:56] Multiplexing M2TS - [21:19:00] Blanking: VID_01137 (79 of 97) - [21:19:00] Processing: VID_01138 (80 of 97) - [21:19:00] Extracting A/V streams [VID_01138] - [21:19:05] Reencoding video [VID_01138] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 361 frames - Bitrate: 500 Kbs - [21:19:05] Reencoding: VID_01138, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.61.18 - Windows Version: 6.2 [9200] - Working Path Free Space: 667.15GB - AVISYNTH Version: 3.7.0.0, not recommended version - X264: Wrong version found - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [21:19:06] - Failed video encode, aborted |
