Old 8th December 2017, 17:36   #15321  |  Link
byteshare
ByteShare
byteshare's Avatar
@Atak_Snajpera
I think I found an issue(s)...
In the #:\Temp\RipBot264temp\Job##\Chunks\CombineAllChunks.cmd file my install (latest updates, forced a recheck to be sure) I found that it is pointing to "vjoin_.exe"
When I looked in the vjoin folder I found only "vjoin.exe" I copied the vjoin and renamed it to the file it wanted.
Second issue is with remuxed BluRays anytime there is a sub file (even if I didn't select one to be muxed back in) the remux process is erroring out, see log:
E:\>"E:\!0-Trans\!2Tools\RipBot264v1.21.0\EncodingClient.exe" "E:\Temp\RipBot264temp\job1\job1_EncodingClient.meta"
E:\>"E:\!0-Trans\!2Tools\RipBot264v1.21.0\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Merge Audio&Video\A\MOONRAKER_t29 Cable Car [Deinterlace].mkv" --compression 0:none --title "MOONRAKER_t29 Cable Car [Deinterlace]" --default-duration 0:30000/1001fps "E:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng "E:\Temp\RipBot264temp\job1\Encoded_Audio_1.opus" --default-track 0:no --language 0:ita -s 0 -D -A "E:\Temp\RipBot264temp\job1\2_subtitles_Italian.idx" --default-track 0:no --language 0:spa -s 0 -D -A "E:\Temp\RipBot264temp\job1\3_subtitles_Spanish.idx" --default-track 0:no --language 0:gaa -s 0 -D -A "E:\Temp\RipBot264temp\job1\4_subtitles_Hungarian.idx" --default-track 0:no --language 0or -s 0 -D -A "E:\Temp\RipBot264temp\job1\5_subtitles_Portuguese.idx" --default-track 0:no --language 0:und -s 0 -D -A "E:\Temp\RipBot264temp\job1\6_subtitles_Undetermined.idx"
mkvmerge v18.0.0 ('Apricity') 32-bit
Error: The file 'E:\Temp\RipBot264temp\job1\2_subtitles_Italian.idx' could not be opened for reading: open file error.
It is looking for a *.IDX file when it shouldn't. SUP subs from BluRays don't have IDX files I thought. I checked with MKVExtract and I only get .sup files out.
Old 8th December 2017, 18:50   #15322  |  Link
Issue #2
Please tell me step by step what to do to force this bug.
Old 8th December 2017, 22:42   #15323  |  Link
byteshare
ByteShare
byteshare's Avatar
Issue #2
I can send you a sample file but All I do is add the file > Setup HEVC/AVISynth settings > uncheck audio and don't check any subs just let it auto pick when doing batch (remux subs). After encode finishes and tries to mux is when it errors out.
Last edited by byteshare; 8th December 2017 at 23:02. Reason: Released my wording could be confusing
Old 8th December 2017, 22:54   #15324  |  Link
I can send you a sample file but All I do is add the file > Setup HEVC/AVISynth settings > uncheck audio and don't check any subs. After encode finishes and tries to mux is when it errors out.
Yes, please...
Old 9th December 2017, 19:56   #15325  |  Link
GZZ
Getting an error in the Avisynth Filter If I choose Mono Noise 2 - See screenshot: https://www.dropbox.com/s/czdxzc5s1v...givet.png?dl=0
Using the newest 1.20.1 version.
GZZ is offline   Reply With Quote
Old 10th December 2017, 02:31   #15326  |  Link
00-00
Having an issue with audio in batch mode on version 1.21.0. When I batch add files they have no audio, either in the preview, in the encoding settings audio bar - it simply says 'No Audio', and the finished files have no audio either. if I add them manually one by one though they do have audio. I've tried earlier versions and they don't have this problem and audio works OK.
I have been using .m2ts files for this, hope someone can help!
00-00 is offline   Reply With Quote
Old 13th December 2017, 09:54   #15327  |  Link
PetBel
Problem with Version 1.21.1
Since a few weeks I have Problems with RipBot (with local and distributed encoding), so i decided to make tests on a PC with a clean Windows installation and only RipBot and the needed Software on it. But I still have Problems.
Here is a step by step description:
- clean Windows 10 Installation with all updates
- Download ripbot 1.21.0 and install Avisynth from Tools Directory
- install latest Java and MediaSplitter
- Update Ripbot to 1.21.1 with auto updater
- add a m2ts file from a BD iso Image (I use one that i have already encoded with an earlier Version of RipBot, so I am sure the source is ok)
The result is an empty "New Job" window with the message "Decoding Error" in the top right Corner.
Is there any log I can check to get more information about what is wrong?
PetBel is offline   Reply With Quote
Old 15th December 2017, 20:12   #15328  |  Link
JASAN
Windows Defender TOday
Hi again Atak, Is this a false positive? Encodingserver.exe is prompting windows defender to put up a virus warning.
JASAN is offline   Reply With Quote
Old 17th December 2017, 15:29   #15329  |  Link
Ryushin
Ryushin's Avatar
4K UHD Status
Just wondering if encoding 4K/UHD is possible? I know mkv does not have support for Dolby Vision, but it does for HDR10. Does RipBot264 pass through the HDR10 information to the MKV? What about passing through Dolby Atmos?
I have a UHD friendly drive coming today and about half of my 4K discs can be ripped. I'd like to start encoding them to put on my NAS. MakeMKV lets me convert the disc into a native file and AnyDVDHD is adding support to rip the discs to a folder.
Pretty excited to finally put my 4K discs up on my server.
Old 17th December 2017, 16:25   #15330  |  Link
slalom
slalom's Avatar
@Atak
what about these errors?
FFVideoSource: No video track found
FFAudioSource: No audio track found
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 17th December 2017, 17:50   #15331  |  Link
Ryushin
Ryushin's Avatar
ChapterDB
Just found out about chapterdb.org and I think it is a pretty cool idea.:
http://www.chapterdb.org
Atak, do think it's possible to integrate this into RipBot264? There is an API for it.
Old 17th December 2017, 18:46   #15332  |  Link
Send me few HDR10 samples and I will implement pass through in ripbot264.
honestly i'm not interested...
Old 22nd December 2017, 00:26   #15333  |  Link
Ryushin
Ryushin's Avatar
Ripped my first 4K UltraHD movie using AnyDVD and when I went to select the streams, the Blu-ray Structure box shows the video as blank.
This is all so new everyone is still figuring how the 4K discs are working.
Old 22nd December 2017, 11:55   #15334  |  Link
Send me whole UHD BluRay folder structure. Trim main movie and extras to reduce file size.
Old 25th December 2017, 13:49   #15335  |  Link
Ronski
Merry Christmas everyone!
I'll post this now otherwise I will forget, the move file option seems to have stopped working, I have the following option in my encodingclient.ini file but Ripbot is copying the file rather than moving it.
[hidden settings]
MoveFiletoSharedFolder=1
My last encode was done at the end of November and I'm sure that was fine - I would have noticed the long wait for the file to be copied.
I've also noticed that Ripbot doesn't check for sufficient disc space, my encode just stopped/hung and then I noticed there was zero disc space. In fact it had copied about 22GB of a 34GB file, so the copy had failed and then Ripbot just tried to carry on with the encoding instead of issuing an error
Edit: I should add I'm on version v1.20.1, not 1.21.0 as I thought, so I'll force an update later and see if the copy/move issue remains
Ronski is offline   Reply With Quote
Old 25th December 2017, 15:55   #15336  |  Link
Danette
Batch Stumble - Never Ending "Waiting For File"
I have demuxed m2v video files from mkv containers and have loaded them into RipBot264 via the batch function. When I click "Start", RipBot264 moves into a "Waiting for file..." mode that never ends. It waits forever. I wouldn't call it a freeze, since I can abort it. When I load the files individually, RipBot264 has no problem processing them.
Danette is offline   Reply With Quote
Old 25th December 2017, 18:21   #15337  |  Link
Most likely file handle is still locked (function FileOpen returns 0 each time) by some other process.
From my code it looks like this
Repeat
  FileHandle := FileOpen(inputfile, fmOpenRead or fmShareExclusive);
  sleep(100);
until (FileHandle>0) or (Terminated=true) or (FileExists(inputfile)=false);
if FileHandle>0 then FileClose(FileHandle);
I've just checked on my machine with .m2v and file was automatically processed in automatic batch mode.
Old 25th December 2017, 18:45   #15338  |  Link
Ronski
Just updated to v1.21.0 and the file is still being copied rather than moved when using the [hidden settings] MoveFiletoSharedFolder=1 option
Old 25th December 2017, 19:41   #15339  |  Link
try this
[settings]
MoveVideoFiletoSharedFolder=1
BTW. That option is no longer hidden. You can change it directly in GUI.
Old 26th December 2017, 11:29   #15340  |  Link
Ronski
Thanks very much Atak fort the quick reply and update, that worked.
