27th September 2018, 12:28 | #16141 | Link | |
I only see the PC's IP
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
27th September 2018, 12:37 | #16142 | Link |
run ipconfig.exe /all and show me what you got.
27th September 2018, 13:38 | #16144 | Link |
Not in English, but you will understand Dual Gigabit, one port connected and all my shares are working
27th September 2018, 14:29 | #16146 | Link | |
\\192.168.1.3\ripbot264temp Code:
\\Pavlos-PC\ripbot264temp
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th September 2018 at 15:38. |
27th September 2018, 17:36 | #16147 | Link | |
Edit: solved it temporarily by reverting to old version. Here is my ipconfig /all: Code:
C:\Users\FvB>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : W8S Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : localdomain Ethernet adapter NIC23: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : localdomain Description . . . . . . . . . . . : Intel(R) 82574L Gigabit Network Connection Physical Address. . . . . . . . . : 00-E0-81-C8-C7-31 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) 82574L Gigabit Network Connection #3 Physical Address. . . . . . . . . : 00-E0-81-C8-C7-30 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter vEthernet (Default Switch): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter Physical Address. . . . . . . . . : FE-15-87-DA-C4-CC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::cc59:afbb:acfe:bb87%10(Preferred) IPv4 Address. . . . . . . . . . . : 172.24.140.97(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.240 Default Gateway . . . . . . . . . : DHCPv6 IAID . . . . . . . . . . . : 402527623 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-71-FD-1D-00-E0-81-C8-C7-30 DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Disabled Ethernet adapter vEthernet (vSwitch_FvB): Connection-specific DNS Suffix . : localdomain Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2 Physical Address. . . . . . . . . : 00-E0-81-C8-C7-2F DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::c44e:4c28:a595:b748%7(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.22(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : den 21 september 2018 22:25:14 Lease Expires . . . . . . . . . . : den 28 september 2018 10:25:34 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 385933441 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-71-FD-1D-00-E0-81-C8-C7-30 DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 192.168.1.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet 4: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TeamViewer VPN Adapter Physical Address. . . . . . . . . : 00-FF-96-49-29-A1 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Code:
\\W8S\ripbot264temp\ Code:
\\192.168.1.22\ripbot264temp\ Last edited by phred1; 27th September 2018 at 18:05. Reason: Corrected Encoding Client <- Encoding Server. + reverting to old version. |
27th September 2018, 18:45 | #16148 | Link | |
No and Yes respectively
29th September 2018, 07:32 | #16151 | Link |
Still errors on start up...
Atak,
Just wanted to let you know that after updating with the very latest, if I'm not connected to any LAN, I still get the pop up error's stating :- "List index out of bounds (-1)" I think it use to be (0). But if I close Ripbot down, fire up the network (turn the switch on), then there's no problems. PS:- I have only tried this on one pc, so far. |
29th September 2018, 14:08 | #16152 | Link |
So the previous version of Ripbot i was using was 1.20 have just updates to 1.23 and now when i try and load a script from avisynth i get the following error, 'There is no function named 'FFMpegSource2' any ideas why im now getting this error message when i didnt in the previous version?
29th September 2018, 14:18 | #16153 | Link | |
Might need to reload any old jobs. There have been a lot of changes, recently. Might need to refresh the Avisynth install from the "Tool's" folder. |
29th September 2018, 15:14 | #16154 | Link | |
ByteShare
29th September 2018, 17:35 | #16155 | Link | |
https://forum.doom9.org/showthread.p...66#post1801766 seems to work now thanks Last edited by BlockABoots; 29th September 2018 at 18:26. |
29th September 2018, 23:04 | #16156 | Link |
Latest Ripbot x86
My computer is x86 and I'd like to use the latest version of Ripbot. I installed Avisynth Plus MT over 2.6 and I tried that AvsPMod but to no avail. I'd like to move past v1.19.6 of ripbot. Help would be appreciated.
30th September 2018, 01:32 | #16157 | Link | |
Get the latest version of Ripbot264 off page 1 of the forum, unpack it, enable auto update, to get the latest build. Run "install.cmd" from Ripbot's "Tools/Avisynth" folder, and see if that works. Another idea might be to upgrade to a x64 version. 6 1/2 years a member, and it's your first post |
30th September 2018, 01:48 | #16158 | Link | |
@ 6 1/2 years a member. I thought I posted before but apparently not..... |
30th September 2018, 02:34 | #16159 | Link | |
So what OS are you running ?? Unless someone else comes up with a fix, you may have to update to x64 |
