3rd November 2020, 16:37 | #60582 | Link |
Hi, when I say correct results I guess I mean I get the expected results in that if my brightness and gamma are at default values on my TV the picture should not be crushed or washed out.
However, if we take the SDR black clipping pattern, I still think there is something wrong here. From memory the only way I could determine if BTB was being preserved was to push the brightness up a few notches and more bars appear, you'd have flashing bars all the way along like this: BTB full range preserved (after increasing brightness) https://1drv.ms/u/s!AgvFafeelEBilKN5...zSFYg?e=QEgoYi if they dont and the blacks all turn grey it suggest you're not getting BTW, is this right? Washed out (after increasing brightness) https://1drv.ms/u/s!AgvFafeelEBilKQc...mFwbg?e=3Ou1i8 Correct pattern https://1drv.ms/u/s!AgvFafeelEBilKN6...aisgw?e=15wmad
3rd November 2020, 16:41 | #60583 | Link | |
I've read in the past that I need 2.2 gamma and that's why the BT.2020 3DLUT in the calibration tab.Am I right? Last edited by Damien147; 3rd November 2020 at 17:25. |
3rd November 2020, 18:01 | #60585 | Link |
@mclingo - who said number 3 is correct?, because in those shots, pretty sure in a dark room number 1 looks right to me.
Have you checked the APL Clipping test file? Unless I've lost the plot lol.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 3rd November 2020 at 18:08. |
3rd November 2020, 18:31 | #60587 | Link |
Profile?I don't get you.
I understand a BT.709 for all but as I said the one for sdr is gonna be bt.1886 and I need another one for 2.2 gamma.Is it wrong to create another one with bt.2020 and 2.2 gamma for tomemapping? |
3rd November 2020, 18:57 | #60588 | Link |
sorry for tone mapping it should gamma 2.2 not any BT what ever. i will edit the post so no one that reads it and not this one will get the wrong idea sorry about that.
with profiles you can do a simple check if the source is HDR it will use a gamma 2.2 3D LUT without HDR it will use what ever gamma you like 3D LUT. |
3rd November 2020, 20:18 | #60589 | Link |
They all work mate and you can make them all look ok depending on your brightness and gamma settings but if your process flow has to convert from limited to full and back again it degrades the picture slightly each time, now whether this will be noticeable to the human eye these days is another matter with high res screens but I prefer to keep my processing path clean and free from unnecessary conversions.
3rd November 2020, 21:33 | #60590 | Link | |
I notice that you are outputting 60hz YUV 444. Are you playing 24hz material at 60hz and can I ask how you accomplish this? I currently playback all content at its native rate 24hz (or otherwise) MadVr Limited -> HTPC 24hz RGB Full 8-bit -> RS600 Limited. Also worth noting I use madvr to perform dynamic tonemapping for HDR content. Thank you for your contributions to this thread! |
3rd November 2020, 21:50 | #60591 | Link |
I used madVR's smooth motion to watch 24Hz material at 60Hz.
madVR options explained |
3rd November 2020, 21:55 | #60592 | Link |
Really appreciate the snap response!! Should be easy enough to try this out again.
I was doing the same thing a few years back and I think I was watching one of the Star Wars prequels at 60hz + smooth motion that made me go back to native 24hz. Do some films just respond better to being presented at 60hz than others? The movie was a 1:1 blu-ray rip upscaled to 2160p 60hz with smooth motion. |
3rd November 2020, 22:23 | #60593 | Link |
Smooth motion is not for everyone, I have an OLED where I like smooth motion but it is theoretically less ideal than a perfectly matched refresh rate.
For me, switching refresh rates every time I start a video and trying to tune custom refresh rates simply isn't worth it. I like the look of smooth motion and it is very robust so it seems like the best option to me. Now that I can run 120 Hz using smooth motion is not even a question for me anymore (always).
3rd November 2020, 23:24 | #60594 | Link | |
First for the calibration tab I create a BT.709 3DLUT with bt.1886 for SDR.Then what do I do to achieve tone mapping with Madvr(pixel shaders) on my bt.709 TV? Last edited by Damien147; 3rd November 2020 at 23:47. |
4th November 2020, 02:53 | #60595 | Link |
right click on your TV/AVR name -> create profile group with calibration only -> profile 1 "duplicate profile" -> name one SDR one HDR -> click on "Profile Group 1" - add in profile auto select rules:
if (HDR = true) "HDR" else "SDR" load the SDR 3D LUT in SDR and the 2.2 in HDR. BTW. why bt 1886? |
4th November 2020, 06:28 | #60596 | Link |
Question - I've decided to set up a few different HDR profiles to toggle between different contrast recovery settings. I've set up Ctrl+C in the profile group name as the keyboard shortcut but for some reason pressing Ctrl+C does nothing and I'm unable to toggle between them. Do I need to set up auto select rules for toggling to work?
My HT: JVC X790R | 120" CineWhite | madVR 169 RTX 2070S | mpv 0.36.x | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe | 4 x ADX Maximus w/ Dayton Audio SA230 | 40" HDTV w/ MoviePosterApp Last edited by *MidnightWatcher*; 4th November 2020 at 06:36. |
4th November 2020, 08:51 | #60597 | Link | |
So basically with AMD cards using Madvr tone mapping, I will always see with BT.709 color space, despite having loaded a 3dlut in SDR DCI-P3 is that you saying? Last edited by stefanelli73; 4th November 2020 at 08:59. |
4th November 2020, 10:53 | #60598 | Link |
the slot has nothing to do with it AMD can tell the screen to switch to BT 2020 (or better it doesn't work)so either you manual change the color space on the TV which is generally fine. if you don't need BT 709 for your desktop and your device can do it.
@*MidnightWatcher* i don't use profiles personally i know you can toggle through them if they all of the same hot key so try to give the profile itself the hotkey. and control+c could be used (alot is used...). |
4th November 2020, 12:47 | #60600 | Link |
The problem is precisely that with my projector a BENQ 5700 I can get the BT.2020 color space, only if it locks a signal in HDR, otherwise always in BT.709, unfortunately it does not act in the same way as SONY or JVC projectors where you can choose either one or the other
