18th December 2021, 09:34 | #8361 | Link | |
Exactly. My entire command line goes like this: Code:
VSPipe -c y4m "f:\jobs\test.vpy" - | x265 --y4m --input - --lossless --preset ultrafast --input-depth 10 --output-depth 10 --crf 10 --colorprim 9 --transfer 16 --colormatrix 9 --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1)" --max-cll "0,0" --frames 211420 --chromaloc 2 --aq-mode 3 --output "f:\video\test.hevc" Code:
x265 [info]: tools: strong-intra-smoothing lslices=8 deblock [73.4%] 155199/211420 frames, 1.97 fps, 1008625.25 kb/s, eta 7:54:32 Code:
y4m [info]: 3840x2072 fps 24000/1001 i420p16 unknown frame count
Gorgeous, delicious, deculture! |
18th December 2021, 09:58 | #8362 | Link |
Pig on the wing
This is because it cannot get the amount of frames from the piped stream.
18th December 2021, 13:30 | #8363 | Link | |
Pig on the wing
Is it actually so that increasing the TU depth only affects compression and that in fact, at least in CRF mode, it can potentially lead to lower detail retention? I've always thought that it is one component which retains detail since it possibly splits into smaller pieces when needed. Or is CTU itself already the major thing in detail retention?
19th December 2021, 02:52 | #8364 | Link | |
limit-tu 0 with tu-inter 4 and tu-intra 4 would be great, but also slow.
madVR options explained |
19th December 2021, 12:25 | #8365 | Link | |
Pig on the wing
Blade Runner 2049 --tu-inter-depth 4 --tu-intra-depth 4 CTU 64 limit-tu 4 - 4847,24 kbps - 19.57 limit-tu 3 - 4634,72 kbps - 19.54 limit-tu 2 - 4766,69 kbps - 19.61 limit-tu 1 - 4328,30 kbps - 19.82 limit-tu 0 - 3970,48 kbps - 20.15 CTU 32 limit-tu 4 - 5329,45 kbps - 19.29 limit-tu 3 - 5325,54 kbps - 19.28 limit-tu 2 - 5289,30 kbps - 19.31 limit-tu 1 - 5092,24 kbps - 19.40 limit-tu 0 - 5128,37 kbps - 19.47 Based on a snippet of ~2000 frames, the average QP is much higher the less TU recursion is limited. I've also found out earlier that the combination of CTU 64, rskip 2 and limit-tu 0 is very much b0rked.
20th December 2021, 00:16 | #8366 | Link |
Shouldn't you compare at the same size? Lower CRF if a setting decreases the size, or better, compare settings with 2-pass so the bitrates are the same.
Are you assuming a setting retains more detail based on how it affects size at the same CRF? It is always possible to make a file bigger and retain more detail.
20th December 2021, 06:16 | #8367 | Link |
Pig on the wing
I'd expect this setting to be one which doesn't require varying CRF since it's more like affecting the number of iterations. My question more or less rises from the fact that in x265 development, the focus in some parameters seems to be compressing more and more instead of detail retention. TU depth is one of those I cannot just understand well enough.
22nd December 2021, 23:27 | #8368 | Link | |
It changes the number of configurations tried, but only one is picked in the end. What "best" means when selecting the best option might not be the one with the highest detail retention, but it could also be that the other options simply don't compress as well. Unless you compare visually at the same size, I don't see how you can come to any conclusion.
27th December 2021, 14:18 | #8369 | Link |
Pig on the wing
Can anyone explain why --no-sao and --selective-sao 0 are two different things? What is the encoder doing when --selective-sao 0 is applied but SAO is still enabled? I was doing some testing with --selective-sao 1 and made a comparison encode with --selective-sao 0. I then noticed that it produced a larger file than when --no-sao is used..
--selective-sao 1 - 6635.40 kbps, avg QP 21.72 --selective-sao 0 - 6816.47 kbps, avg QP 21.62 --no-sao - 6641.23 kbps, avg QP 21.72 EDIT: hmm, apparently --selective-sao + --sao is the same as "old --sao".
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 27th December 2021 at 14:26. |
3rd January 2022, 21:43 | #8370 | Link | |||
In my experience, the higher tu depths can be really helpful with low-noise content with sharp edges, like animation, graphics, and text. They don't do much with grainy/noisy content because so much of the energy of potential TUs is in randomly distributed pixels. This is particularly of grain that has a lot of per-pixel variance. More natural grain that isn't per-pixel randomization is better. |
3rd January 2022, 21:48 | #8371 | Link | |
--selective-sao just turns off SAO for specified classes of frames. The only one that really matters is --selective-sao, which only applies SAO to I and P frames. SAO wasn't designed for bidirectional prediction and provides almost no benefit to B and b frames. So --selective-sao 2 is an essentially free minor speed boost. This is pretty orthogonal to the detail preservation/ringing suppression features of SAO, and has little or no visual impact on how SAO operates in x265. I'd love to have an --sao-parameters that could actually tune the SAO parameters; x265 just uses fixed SAO parameters, so we really only can control in being on/off. An --adaptive-sao would be even better. I don't know of any actual research done in this area, though. |
4th January 2022, 06:34 | #8372 | Link | |
Pig on the wing
I've now settled for using --selective-sao 1. SAO has a too strong effect on P-frames to my liking, it clearly removes detail. I-frames are affected only very slightly, which I believe is the real intent of the functionality. Even though they are not to be blindly trusted, distortion related metrics like MDSI and GMSD show improvement in the whole GOP with value 1 compared to other values, or --no-sao. So I think using it only in the first frame of the GOP is most beneficial.
4th January 2022, 19:19 | #8373 | Link | ||
4th January 2022, 20:07 | #8374 | Link |
Pig on the wing
The source is Fellowship of the Ring EE, frames 140330-141401 in this case. Some static scenes with closeups and panning motion.
https://drive.google.com/file/d/1SnS...ew?usp=sharing --no-sao https://drive.google.com/file/d/1pp2...ew?usp=sharing --selective-sao 1 https://drive.google.com/file/d/13wD...ew?usp=sharing --selective-sao 2 This is the MediaInfo output. --preset slower as the base, then some additional touches. CRF 18, very slight denoising in the script, I'm also doing the green tint fix with a GIMP curve. Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 44 s 711 ms Bit rate : 6 508 kb/s Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.177 Stream size : 34.7 MiB (98%) Writing library : x265 3.5+21-30cbfda6a:[Windows][GCC 11.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x800 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=5 / keyint=480 / gop-lookahead=0 / bframes=10 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=0 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=4 / rdoq-level=1 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=1 / limit-modes / me=3 / subme=4 / merange=26 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=6 / selective-sao=1 / no-early-skip / rskip / rskip-edge-threshold=0.020000 / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / splitrd-skip / rdpenalty=0 / psy-rd=1.80 / psy-rdoq=5.00 / no-rd-refine / no-lossless / cbqpoffs=-3 / crqpoffs=-3 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.35 / pbratio=1.25 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=64 / max-luma=940 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0 / conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
5th January 2022, 02:21 | #8375 | Link | ||
I created a comparison screenshot from your video, hopefully, you won't mind: https://slow.pics/c/JyWTHIUA Please, everyone, look at comparison 6: Frame number 908. Which one is slightly better here & why? @Boulder, Could you provide another test with --limit-sao? Same start & end runtime video. But I found this one: https://amefs.net/en/archives/1470.html According to him: Quote:
5th January 2022, 06:51 | #8376 | Link |
Pig on the wing
The differences in motion are very subtle. However, in frame-by-frame comparison, to me the areas with edges look very slightly better with --selective-sao 1.
Here's --selective-sao 1 --limit-sao: https://drive.google.com/file/d/1zYP...ew?usp=sharing
5th January 2022, 22:09 | #8377 | Link | |
5th January 2022, 22:15 | #8378 | Link |
Also, I believe --limit-sao is supposed to be just a performance improvement via early exit, and shouldn't change the look of SAO. But stuff can have unanticipated impacts! Have you seen a material difference with it on versus off?
