10th October 2008, 21:57 | #24 | Link |
SubtitleCreator's Co-Dev
Ok, I had a look at your problem.
First, you should have carefuly read the title of this guide. The method described in this guide is usable ONLY FOR ASSDRAW ASS files. This is because this method will generate one SUP bitmap per frame which is not the good method for normal text subtitles but only for animations. Otherwise the "black frames" problem comes from the fact that you didn't adapt the AviSynth script. The script given in the guide doesn't last long enough for your subtitles to display. This is an AviSynth problem and you should learn how AviSynth scripts work first (see www.avisynth.org for a good reference). You should have adapted the first line of the script like below: Code:
video=BlankClip(width=720,height=573,fps=25,length=10000) Cheers Manusse Last edited by manusse; 10th October 2008 at 22:18. |
11th October 2008, 14:26 | #25 | Link |
Didn't look the length. I know it's not the best way for Not Draws Subtitles, but I don't know a way of pasting a Draw with other subs that it's not Having them in the same Script. I don't have problems with the Size of the Sup, with this it should work.
Thx. |
11th October 2008, 23:22 | #26 | Link | |
Cheers Manusse |
8th December 2008, 19:33 | #27 | Link | |
8th December 2008, 22:32 | #28 | Link | |
Otherwise, SC is not able to directly support ASS now. One day it could but it's not on top of our priorities even if it's on the TODO list. Cheers Manusse |
