12th March 2011, 04:05 | #11501 | Link | |
12th March 2011, 05:28 | #11502 | Link | |
Interlaced sources are encoded progressive... deinterlace=off Tested on: Paul McCartney - The Space Within Us 2005 US Tour 1080i/29.970fps BD Rebuilder v0.37.05
DVD Rebuilder user Last edited by Elvis Gratton; 12th March 2011 at 05:46. |
12th March 2011, 15:27 | #11504 | Link | |
Bitter Old Geek
Instead, I removed all check boxes from the audio section under audio settings. I had been trying to use "do not reencode AC3" thinking it would leave the 384kbps alone but instead I was getting no audio at all. With nothing checked, I am at least getting AC3 but it is being reencoded to 640kbps. Maybe, if you can tell me where the setting is you are talking about, I can get it to pass the 384k stream without taking it to 640. However, if not, it still works for me. |
12th March 2011, 15:35 | #11505 | Link | |
Bitter Old Geek
Just an FYI as I saw these comments, the file I asked about yesterday (with the "und" ac3 track) was 1080i. When I ran it through BD-RB, MediaInfo reports the resultant file is progressive. Still reports 29.97fps but "progressive". The file I started with shows 29.97 interlaced. |
12th March 2011, 17:34 | #11506 | Link | |||
The VID_00000.CHP file is correct (based on 30000/1001 FPS as it should be). Here are the command lines getting passed to x264 with my 1080i 29.97fps interlaced source: Quote:
--keyint should be 30 --tff is missing |
12th March 2011, 18:10 | #11507 | Link |
Hi jdobbs,
Here is the inf and log files of the blocky video encode: ----------------------- [12:10:32] BD Rebuilder v0.37.04 (beta) - Source: RAGING_BULL - Input BD size: 34.00 GB - Approximate total content: [02:09:03.819] - Target BD size: 22.95 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:10:32] PHASE ONE, Encoding - [12:10:32] Extracting A/V streams [VID_00000] - [12:56:07] Reencoding: VID_00000 (1 of 1) - [12:56:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 185,666 frames - Bitrate: 19,189 Kbs - [12:56:07] Reencoding: VID_00000, Pass 1 of 1 - [22:12:56] Video Encode complete - [22:12:57] Reencoding audio tracks (if req'd) - [22:12:58] Multiplexing M2TS [22:25:48]PHASE ONE complete [22:25:48]PHASE TWO - Rebuild Started - [22:25:48] Rebuilding BD file Structure [22:57:26] - Encode and Rebuild complete [22:57:26]JOB: RAGING_BULL finished. [Status] LABEL=RAGING_BULL VERSION=v0.37.04 (beta) SOURCE_SIZE=36505282560 SOURCE_VIDEO_SIZE=36505282560 TARGET_SIZE=24641536000 REDUCTION=.675012882299958 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00000] AUDIO=100000000 PGS=111111010000 M2TS_TARGET=24641536000 RATE=19189 NSTART=27000000 NEND=375471840 NSIZE=19052058624 FLINK=0 MLINK=0 |
12th March 2011, 18:27 | #11508 | Link | |
I've been able to repeat this issue, I'm guessing some change I've made recently must have caused it. I'm working on a fix and should have it out soon. Last edited by jdobbs; 12th March 2011 at 19:11. |
12th March 2011, 18:29 | #11509 | Link | |
12th March 2011, 19:03 | #11510 | Link |
If it's being encoded at 29.97 with 1080 resolution, --tff must be there for blu-ray compliance, even if the the original should (by mistake) have been encoded as progressive.
If the original content is progressive (no temporal shift between odd and even fields) it could be encoded with --fake-interlaced, but I am not shure if BD-RB can automatically decide between --tff and --fake-interlaced options. |
12th March 2011, 19:07 | #11511 | Link | |
The "--fake-interlaced" is used within BD-RB when the source has been deinterlaced, but the format is such that progressive isn't allowed (such as 720x480). That way the output of the deinterlacing can use the efficiency associated with progressive encoding but still be included in a BD (within specifications). BD-RB makes no attempt to try and find progressive content within an interlaced stream (other than IVTC) -- in fact I can't think of any reliable way that it could be done even if I wanted to. Last edited by jdobbs; 12th March 2011 at 19:35. |
12th March 2011, 19:13 | #11512 | Link |
Well, isn't that the issue we're discussing? Specifically that interlaced 29.97i (30000/1001) FPS concerts get encoded as progressive?
It seems there are several of us who have all found the same issue. Every tool I've tried report the video stream as interlaced (eac3to, TSmuxer, & DGdecNV). Visual inspection shows it's interlaced. Even BD-Rebuilder recognizes it's interlaced. I don't see any ambiguity on whether or not it is interlaced. Edit: I see you edited the post that you were able to duplicate the issue, so it seems we're all on the same page now. Last edited by Stereodude; 12th March 2011 at 19:16. |
12th March 2011, 19:14 | #11513 | Link | |
I KNOW THERE IS AN ISSUE. I'M WORKING IT!!!!! Repeatedly telling me what I already know is only pissing me off. Last edited by jdobbs; 12th March 2011 at 19:34. |
12th March 2011, 19:19 | #11514 | Link | |
Sorry... |
12th March 2011, 19:23 | #11515 | Link | ||
How about this post from yesterday? (#11501) Quote:
12th March 2011, 19:29 | #11516 | Link |
Well, I've found what is causing it... an If/then/else statement that is not acting correctly. The problem is that it appears to be written correctly, but for some reason it isn't hitting the "else" when the "if" is false -- weird... I'll figure it out.
[Edit] Ok. I've fixed it. You'll see it in the next release. Last edited by jdobbs; 12th March 2011 at 19:50. |
12th March 2011, 20:11 | #11517 | Link | |
No one wanted to teach you anything. But at times it is helpful to learn if other people experience a similar problem, or if it's only a local issue here. No offense. |
12th March 2011, 20:22 | #11518 | Link |
Does anyone know of some good free software for reporting pulldown and field order in VC-1 interlaced sources? I have a routine that is scanning the picture header and I want to verify that some of the fields are being read correctly (I wrote it a long time ago, and I can't seem to find my reference material).
[Edit] Never mind. I found my reference... Last edited by jdobbs; 12th March 2011 at 20:36. |
12th March 2011, 21:09 | #11519 | Link | |
Video ID : 1 Format : VC-1 Format profile : AP@L3 Codec ID : WVC1 Codec ID/Hint : Microsoft Duration : 1h 55mn Bit rate : 27.7 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.445 Stream size : 22.4 GiB (98%)
DVD Rebuilder user Last edited by Elvis Gratton; 12th March 2011 at 21:11. |
