Old 23rd May 2010, 23:02   #41  |  Link
mp3dom
If you add the transfer characteristics/color primaries/colormatrix (to bt709) you also need (or, it's better) to add also the videoformat 'ntsc' if you're encoding at 30/60/23.98/24 fps. The pro-encoders do this (you can not add the information, but if you add them also the NTSC video format is specified). I haven't tested it, but probably for 25/50 fps the 'pal' video format is added.
mp3dom is offline   Reply With Quote
Old 3rd June 2010, 10:01   #42  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by laserfan View Post
Thanks shon3i for the charts.
Question: I've been using --keyint 24 and 15000/15000 for all "BD"-on-DVD work, and given my bitrates are typically in the low 3500-7000 range should I really be using --keyint 48 instead to minimize "pulsing" at GOP changes?
yes will work for all scenario ... and GOP 48 vs GOP 24 produce ~2% better compression efficiency.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
Old 3rd June 2010, 15:08   #43  |  Link
laserfan
Aging Video Hobbyist
Thanks a lot for this--while I'm unlikely to notice this type of improvement, I have changed my default to 48 keyint and the results work in my player!
Old 4th June 2010, 12:49   #44  |  Link
MadMonkey57
Duh!
MadMonkey57's Avatar
Originally Posted by MadMonkey57 View Post
And what about --min-keyint ? Does it have to be set with regards to --keyint or x264 default (auto) is blu ray compliant ?
Anyone ?
MadMonkey57 is offline   Reply With Quote
Old 4th June 2010, 13:08   #45  |  Link
rack04
Anyone ?
I don't know whether it needs to be set but I error on the side of caution. If I know that something needs to be set I don't rely of a default/preset/tune to set it for me.
rack04 is offline   Reply With Quote
Old 4th June 2010, 13:38   #46  |  Link
MadMonkey57
Duh!
I agree. That's why I always set --min-key-int to 2 (which most of us use) for my 23.976p encodes.
Still I am wondering for other encodes especially 50p and 25i...
Old 4th June 2010, 15:29   #47  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Just leave default x264 setting. From revision r1537 x264 automaticly calculate min-keyint with keyint/10. so with Shot GOP min-keyint will be 2 with long 4, wich is just fine.
btw i am currently work to complete this stuff, be patient few more days with all need explanations
shon3i is offline   Reply With Quote
Old 4th June 2010, 16:06   #48  |  Link
MadMonkey57
Duh!
All right.Thanks.
Old 4th June 2010, 18:57   #49  |  Link
Sharc
--fake-interlace or --tff?
Will --fake-interlaced produce blu-ray compliant 576 encodes
of a progressive PAL DVD source? Or do I have to set --tff?
Old 4th June 2010, 19:05   #50  |  Link
kieranrk
--fake-interlaced should work. You will need --pic-struct of course.
kieranrk is offline   Reply With Quote
Old 4th June 2010, 19:48   #51  |  Link
Sharc
Thanks, and for reminding me of the --pic-struct.
Old 10th June 2010, 05:18   #52  |  Link
kieranrk
I wrote a simple guide for the most common Blu-Ray scenarios. See my sig.
Old 10th June 2010, 22:20   #53  |  Link
Lyris
Much appreciated, Kieran, good to know my tests have been BD compliant.
Can you advise me (and others) here - are the following encode settings also good?
16:9 "NTSC" 720x480 Secondary Video stream
I know the max bit rate here is quite conservative, that is my intention.
x264 --bitrate 3000 --pass 1 --preset veryslow --weightp 0 --bframes 3 --me umh --merange 24 --partitions all
--subme 10 --trellis 2 --rc-lookahead 60 --direct auto --ref 6 --nal-hrd vbr --vbv-maxrate 4000 --vbv-bufsize 6000
--level 3.2 --keyint 24 --b-pyramid strict --slices 1 --aud --colorprim "smpte170m" --transfer "smpte170m"
--colormatrix "smpte170m" --sar 40:33 infile.avs -o outfile.avc
x264 --bitrate 3000 --pass 2 --preset veryslow --weightp 0 --bframes 3 --me umh --merange 24 --partitions all
Standard Definition Primary video (for bonus features, etc)
I gather that since 23.976fps is not allowed for SD material on BD, we need to add some sort of 3:2 pulldown flag. Is the way X264 does this BD compliant?
Lyris is offline   Reply With Quote
Old 10th June 2010, 22:40   #54  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Everything look good to me. Just advice about vbv, keep both value near each other. You can use --keyint 48 aslo.
Yes but need to be interlaced aslo. If you sourtce is 23.976p you can use fake interlaced with 3:2 pulldown.
Old 11th June 2010, 04:19   #55  |  Link
kieranrk
I'm not 100% sure that will pass some verifiers. It's a very strict interpretation of the spec.
Old 11th June 2010, 06:55   #56  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
As long is 29.97i should pass, but if someone send me a sample i can verify
EDIT: i create my own 23.976p sample, encoded using fake interlaced and puldown 32 to produce 29.97i stream, but this file will not pass mui generator.
Old 11th June 2010, 08:50   #57  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Maybe just forget about fake interlaced and only use pulldown??
Derek
These are all my personal statements, not those of my employer :)
Old 11th June 2010, 08:57   #58  |  Link
mp3dom
23.98p to 29.97i via 3:2 pulldown is allowed. Probably the fake-interlaced is not needed in this case.
Old 11th June 2010, 08:57   #59  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Derek
it's ok for secondary video, but for primary 720x480 must be interlaced (or fake interlaced)
Old 11th June 2010, 09:16   #60  |  Link
mp3dom
Doesn't the pulldown already flag the stream as interlaced?
