15th December 2022, 14:24 | #8861 | Link | |
Pig on the wing
15th December 2022, 14:38 | #8862 | Link |
Unfortunately, readthedocs is not yet up to date.
15th December 2022, 22:24 | #8863 | Link |
I was using --scenecut-aware-qp 3 in my scripts, and now with the new version i have a FLAW error, "invalid argument", but according the --fullhelp it's stil a valid argument...
Edit : Has anyone else tested to check if --scenecut-aware-qp 3 is still working after these commits ? For me this release is broken somewhere, all my encoding scripts are not running anymore.
My github. Last edited by jpsdr; 16th December 2022 at 09:41. |
16th December 2022, 17:54 | #8864 | Link | |
Last edited by benwaggoner; 16th December 2022 at 18:14. Reason: Hit Send prematurely |
16th December 2022, 18:04 | #8865 | Link | |
There is now a sample file here: https://bitbucket.org/multicoreware/..._qp_config.txt Its from https://mailman.videolan.org/piperma...er/013560.html |
16th December 2022, 19:20 | #8866 | Link | |
Perhaps there will be a way to specify different parameters for different frame ranges? |
16th December 2022, 21:25 | #8867 | Link |
Looking at the docs for the new file on BitBucket, it can get a lot more complicated that sample, so I can see why they used a file for it even if it's still static values.
(docs/rEST/cli.rst, and you have to click "Open Raw" in the little menu next to the "Edit" button since the fancy markdown version you see by default is ancient. Search for masking-strength.) |
16th December 2022, 21:54 | #8868 | Link |
You can specify the different QP adjustments per window, and there are 6 windows now.
So the file is useful for that, but hardly IMO. My CLI for example is already 1000 characters, so it wouldn't bother me.
LG C2 OLED | GitHub Projects |
17th December 2022, 12:17 | #8871 | Link |
I thought there was an option to activate an automatic filling of this file with different options for each scene but the need to put them by hand from what I understand
ex : --scenecut-aware-qp 3 --masking-strength 500,2,0,200,-1,-1 in the file scenecut_qp_config.txt. so we have to manually enter all the options per scene? |
17th December 2022, 13:33 | #8872 | Link |
I have, just for testing, replaced :
OPT("scenecut-aware-qp") p->bEnableSceneCutAwareQp = x265_atoi(value, bError); Code:
OPT("scenecut-aware-qp") p->bEnableSceneCutAwareQp = atoi(value); Code:
x265 [FLAW]: invalid argument: scenecut-aware-qp = 3
My github. |
17th December 2022, 15:41 | #8873 | Link |
Pig on the wing
Do we still need quietvoid's patch (probably a new version of it) to make the functionality work in CRF mode?
19th December 2022, 02:12 | #8874 | Link | |
20th December 2022, 09:59 | #8875 | Link |
Ok, i think i understand my mistake.
I thought the new patch offered the possibility of having an external file to configure the scenecut-qp stuff. But not, it's a necessity ! For just using --scenecut-aware-qp 3 i have to create an external file, acces it with --scenecut-qp-config and put --scenecut-aware-qp 3 inside it... I will in my mod version restore the possibility of being able to just put --scenecut-aware-qp directly in command inside a script without the necessity to have an external file just for it (and make all my encoding scripts working again...)
My github. |
20th December 2022, 19:29 | #8877 | Link |
What i ment, it's that now you can't anymore just put --scenecut-aware-qp 3 directly in the command line, you have to put it in an external file. There is probably a lot of others possibilities with this new patch (i didn't dig to see what it's doing because i'm not using these stuff), and having the possibility of using an external file for a lot of zone description is a good thing of course, but for someone like me who was just using --scenecut-aware-qp 3, it breaks all my encode script, and to have to add an extra file just to put one command inside...
My github. Last edited by jpsdr; 20th December 2022 at 19:31. |
20th December 2022, 22:06 | #8878 | Link |
x265 v3.5+75
https://www.mediafire.com/file/w8xufft0b475b1t |
20th December 2022, 23:15 | #8879 | Link | |
