9th November 2014, 14:50 | #43 | Link |
I have some problems.
I demux the original file with eac3to and then i use this tool. On My i7-3517 Ivy Bridge, the mfc-video is ok. On Haswell i get a lot of artifacts. What i make wrong ? This commandline i use: C:\Program Files (x86)\BDtoAVCHD>mvcenc "u:\eac3to\video.avc" "u:\eac3to\video.mvc" 999999 c:\eac3to\convert.h264 32699 1 MVCenc v2.2.3. This tool is part of BDtoAVCHD software. Coded by Joel Gali. Intel Media SDK Decoder Info: API LEVEL 1.11 - HW Source Information: - Resolution: 1920x1080 - Frame Rate: 24000/1001 (23.976 fps) Intel Media SDK Encoder Info: API LEVEL 1.11 - HW Target Information: - Resolution: 1920x1080 - Frame Rate: 24000/1001 (23.976 fps) - Codec: AVC, Level: 4.1, Profile: AVC Stereo High - Num Slice: 6 - Num Ref: 4 - GOP: 24-4-0 Open - Buffer Size: 30000 Kbits - Max Bitrate: 60000 Kbps - Bitrate: 32699 Kbps - Tar. Usage: 1 MVCenc [12.2%] 122384/999999 frames, 29.64 fps, 377.45 Kb/s, eta 8:13:27 Last edited by dorati; 9th November 2014 at 14:58. |
9th November 2014, 23:01 | #45 | Link | |
Maybe if you create the ISO structure using BDtoAVCHD and then use the SSIF file works OK with Samsung TV... |
10th November 2014, 20:42 | #47 | Link |
I don't know. The only scenario tested by me is generating ISO structure to play thought standalone Blu-Ray player or compatible SW (Stereoscopic Player, TMT6, etc.) and in this case is NOT used "rebuild SEI and VUI data" option.
But probably muxer requirements are different for Samsung TV. Anyway it seems clear that this is a muxing issue (unrelated to the encoder itself). Though not understand how the TV can correctly play 3D content with only .m2ts as there is important information in other files of the ISO structure (such as the assignation of left/right views to AVC/MVC streams). |
24th November 2014, 11:07 | #49 | Link |
3D Fan
Hello there
Thx for you're great tool. Very useful for re-encoding 3D blurays. There is some problems with some bluray 3D muxed in m2ts on Samsung TVs. I guess that's a bitrate problem. (officially, in the samsung doc, max bitrate is 30Mb/s) This require more testing. With this tool, we can simply re-encode the bluray with lower bitrate, and that's works well. I suggest some more functionnality for BDtoAVCHD, i 'll post in the good thread. |
30th November 2014, 12:18 | #50 | Link | ||
Then I put a sample command lines that can be used for testing: max_bitrate = 30000 buffer_size = 30000 bitrate = 25000 encode: Code:
"C:\Program Files (x86)\BDtoAVCHD\MVCenc.exe" "T:\TEMP\source.avc.h264" "T:\TEMP\source.mvc.h264" 187608 "T:\TEMP\encode.h264" 25000 4 30000 30000 remux: 1. Create a text file called "tsmuxer.meta": Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEG4/ISO/MVC, "T:\TEMP\encode.h264", subTrack=1 V_MPEG4/ISO/AVC, "T:\TEMP\encode.h264", subTrack=2 Code:
"C:\Program Files (x86)\BDtoAVCHD\tsMuxeR\2.x\tsMuxeR.exe" "T:\TEMP\tsmuxer.meta" "T:\TEMP\encode.m2ts" If dorati, Tounet or someone with a Samsung TV proves it and comment the result will be very useful
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 30th November 2014 at 12:23. |
23rd December 2014, 17:45 | #51 | Link |
Tests with TV Samsung
I'm trying to back up a few 3D Blu-Ray disks by making .m2ts files from STREAM .ssib files with TSMuxer, in order to be read on my Samsung TV.
As it has been noticed on forum, some .m2ts files open and display native 3D on Samsung TV whereas others load indefinitly and never open. The question was : is it a problem of bitrate ? The thing is I'm a newbie and can't answer this question : I did a few tests and let you comment them. Here's a first test with Jurassic Park 3D : .m2ts file made directly from .ssib file located into BD STREAM folder does not open on TV Samsung. So I used BDtoAVCHD to re-encode video : I chose BD25 and settings are in attachment Img1.jpg. I mounted the .iso file obtained after BDtoAVCHD had finished running, then selected .ssib file from STREAM folder to run with TSMuxer and obtained the new re-encoded .m2ts file. This new .m2ts file did open on Samsung TV with nice 3D displaying, but when I stopped the video or went fast forward then replayed, a bloody awful pixelation occured and was irreversible. With the same BD, I tried your settings by using command lines (displayed in Img2.jpg and Img3.jpg) : Img2 refers to a target usage of 4, Img3 to a target usage of 1. I then muxed encode.h264 and sound files in TSMuxer to obtain two new .m2ts files. The result was the same as .m2ts obtained from BDtoAVCHD : nice 3D displaying, but pixelation when fast forward................... Here's a second test with a second 3D Blu-ray Titanic : .m2ts file made directly from .ssib file located into BD STREAM folder does open on TV Samsung. But I had a try with BDtoAVCHD to re-encode video and check if there still was this strange pixelation phenomena : I chose BD25 and settings are in attachment Img4.jpg. .m2ts obtained from .iso file with TSMuxer showed exactly the same issue than others .m2ts obtained from BDtoAVCHD : still this bloody pixelation ! So in conclusion : 1- First BD : bitrate < 30000 : need to be re-encoded with BDToAVCHD. 2- Second BD : bitrate > 30000 : don't need to be re-encoded. Re-encoding with BDToACVHD gives a working .m2ts file, but pixelation occurs when playing video fast forward. Could this observed pixelation be explained by the fact I've only got an i5 intel processor ? A friend of mine has got a Thomson 3D TV : all .m2ts files obtained directly from BD STREAM folder .ssib files open without any problems on his TV : it looks as if it was a typical Samsung problem ! Last edited by sergio2; 23rd December 2014 at 17:50. |
27th December 2014, 09:14 | #52 | Link |
Bitrate is not the problem.
Then i was thinking, the problem was 3 reframes. But Avatar has 3 reframes and >30Mbit. Works perfect.... What can be the problem?? At the end, i mux the not working streams with scenarist - not working. So, there must something with the stream, not the mux - i think. But perhaps somebody as a idea. Last edited by dorati; 27th December 2014 at 09:26. |
4th January 2015, 00:09 | #56 | Link |
In fact, pixelation comes from HW encoding !
When I disabled Media SDK (see attach file), SW encoding took 16 hours instead of 1 hour and a half with HW, but at least no pixelation occured after jumping fast forward .m2ts video file. |
4th January 2015, 09:53 | #57 | Link |
Hi sergio2,
Some users have had problems with the combination (HW + 1-2 Target Usage levels). Maybe with T.U level 4 you can use HW. It seems a limitation of some systems. You also can try to update Intel Graphics drivers. Recent drivers comes with 1.11 API level (you're using API level 1.7). Intel Media SDK files are updated by the driver. https://downloadcenter.intel.com/ EDIT => Another thing: to generate the final .m2ts (when you already have ISO / ssif file) probably just have to rename/copy the .ssif file to .m2ts since both have the same structure. No need to re-remux using tsMuxeR again.
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 4th January 2015 at 10:00. |
4th January 2015, 10:26 | #58 | Link |
Thank you for your answer. I already tried HW encoding with T.U = 4. It didn't change anything. I'm afraid of upgrading intel drivers on my ASUS notebook ! This computer was originaly built on Windows 7. I created a Windows 8.1 partition (it's on this partition I ran BDToAVCHD) so that I obtained a dual-boot 7/8.1. When I tried to upgrade Intel driver on Windows 8.1, my notebook displayed a black screen when booting and I don't want to see that again......... I should try to run HW encoding with BDToAVCHD on Windows 7 partition. |
3d blu-ray encoder, mvc encoder, mvcenc |
