1st November 2016, 22:19 | #81 | Link |
@pinterf
can you add rgb24 support in MSuper and MAnalyse and MRecalculate? making the support work as if it one colour not treats it as R G B separately
See My Avisynth Stuff |
1st November 2016, 23:43 | #83 | Link | |
Would diff in blue count a teeny weeny bit, in green somewhat more, and in red a helluva lot ?
2nd November 2016, 00:16 | #84 | Link | |
2nd November 2016, 00:26 | #85 | Link |
One would have to have some difference measure, eg convert rgb to luma-y, and measure dif in that.
Or rgb color cube distance. I don't get what you are saying about convert to hex. Perhaps you should elaborate a little on what you want.
2nd November 2016, 00:31 | #86 | Link | |
2nd November 2016, 00:45 | #87 | Link |
Mixing color component together does not help. The base of the whole motion analysis is SAD, pixel values of two frames get subtracted, then we get the absolute value and finally sum them up for 8x8, 16x16, up to 128x128 (vapoursynth mvtools2 port) pixel blocks.
Creating a compound representation of rgb value result us that the component at the lsb side will affect the result for 1/65536 of weight than the component at the msb side 0xff0000 mask (for 8 bits) |
14th November 2016, 02:22 | #88 | Link |
See here Bug in v2.5.11.2 and v2.5.11.20, and v2.5.11.22. Fixed in v2.7.1.22:- http://forum.doom9.org/showthread.php?t=174025
Also, MvTools2 v2.7.1.22 MBlockFps(Blend=False) and MFlowFps(Blend=False) are broken, creates mangled frames at scene change.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th November 2016 at 03:07. |
14th November 2016, 08:55 | #89 | Link |
mvtool2
could you please try this test build (overlap fix only), and report back, though the scenechange problem is not intended to be fixed. http://www.mediafire.com/file/u8pp73...orStainless.7z (test only, not for public) Edit: what do you mean under "mangled", can you provide a test script and a hint where to look at that behaviour, and also, whether older 2.5.xx or 2.6.0.5 versions behave similarly? Last edited by pinterf; 14th November 2016 at 08:59. |
14th November 2016, 10:25 | #90 | Link | |
Overlap fix seems to work ok.
By Mangled I meant that bad frame was produced, did not seem to be blend or correct behavior when Blend=False, ie duplicate previous frame (that is End Of Scene Frame) at scene change. Script testing v2.6.0.5 (frames are so different that synthesized frames should be same as frame prior to them [EDIT: when Blend=false). EDIT: Result Frames 0, 2 and 4 are the original frames with a scene change between each, frames 1 and 3 are synthesized frames at scene change. Code:
Function DoubleRate(clip c,Bool "Blend",Bool "Flow") { # Works OK with MvTools2 v2.6.0.5 c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) bw_2 = MRecalculate(super, chroma = false, bw_1, blksize = 8, searchparam = 1, search = 3) # No Overlap (currently broken for final vectors) fw_2 = MRecalculate(super, chroma = false, fw_1, blksize = 8, searchparam = 1, search = 3) # No Overlap Return (!Flow) \ ? MBlockFps(super, bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), mode=0, Blend=Blend) \ : MFlowFps(super, bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } BLEND=False FLOW=False A=Colorbars.Killaudio.ConvertToYV12.Trim(0,-1) B=A.FlipHorizontal (A++B++A).ShowFrameNumber DoubleRate(Blend=BLEND,Flow=FLOW) BilinearResize(320,240) I=Last.Blankclip(Height=4) StackVertical(Trim(0,-1),I,Trim(1,-1),I,Trim(2,-1),I,Trim(3,-1),I,Trim(4,-1)) Script testing v2.7.1.22 and working for OverLap and without the previous script MRecalculate to step over the Overlap bug (In actual fact v2.6.0.5 puts up error OverLap Must be 0, if function creating MBlockFps used vectors, use Overlap>0). Code:
Function DoubleRate(clip c,Bool "Blend",Bool "Flow") { # for MvTools2 v2.7.1.22 testing c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) Return (!Flow) \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), mode=0, Blend=Blend) \ : MFlowFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } BLEND=False FLOW=False A=Colorbars.Killaudio.ConvertToYV12.Trim(0,-1) B=A.FlipHorizontal (A++B++A).ShowFrameNumber DoubleRate(Blend=BLEND,Flow=FLOW) BilinearResize(320,240) I=Last.Blankclip(Height=4) StackVertical(Trim(0,-1),I,Trim(1,-1),I,Trim(2,-1),I,Trim(3,-1),I,Trim(4,-1)) You can check the behaviour using 2nd script DoubleRate() and look at any scene change, with Blend=True, should create blend at scene change, if false, then should use copy of End of Scene frame for synthesized frame [EDIT: As in first above result]. Thanks pinterf, looking good. EDIT: I dont know if you saw a previous edit from the Interframe thread, here tis:- Quote:
script 1 script 2 (showing 'Mangled frames') EDIT: I've added FLOW=False default to both scripts, so you can also test MFlowFps if set true. EDIT: I spoke too soon, there seems to be a problem at right and bottom edges on real video, also can be seen on frames 1 and 3 of 2nd results. Script producing Code:
Function DoubleRate(clip c,Bool "Blend",Bool "Flow") { # for MvTools2 v2.7.1.22 testing c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) Return (!Flow) \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), mode=0, Blend=Blend) \ : MFlowFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } AvisourcE("F:\v\StarWars.avi") DoubleRate Trim(12744,12746) LanczosResize(400,224) StackVertical(Trim(0,-1),Trim(1,-1),Trim(2,-1)) EDIT: Still occurs if adding Crop(4,4,-4,-4) before call to DoubleRate (get rid of any crud, for padding). EDIT: Still occurs if changing hpad and vpad to 0. EDIT: And a live video scene change (Blend=false) EDIT: What above looks like using v2.6.0.5 and same script but with script1 DoubeRate(Blend=True), Blend=False (as above) should produce 2nd frame same as the 1st frame.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th December 2018 at 01:19. |
16th November 2016, 00:43 | #92 | Link |
Hi StainlessS!
Try this test build please. http://www.mediafire.com/file/aako4w...StainlessS.zip About the bug. er... Guess what: A /256 was somehow changed into /(8*8) for better readability . No, it wasn't really me, but the monkeys. As a side-effect I think I have ported MFlowFPS to native 10-16 bits that can be used with Avisynth+. |
16th November 2016, 03:42 | #93 | Link |
MBlockFPS, have fixed side green border, but bottom green border remains in synthesized frames where not at scene change,
ie at scene change, synthesized frame is duplicate of previous frame (blend=false), or simple 50.0/50.0 blend (Blend=True), so just a problem in synthesized frames that are not at scene change. The Mangled frames at scene change have gone. MFlowFPS, dont see any problems. Unfortunately, I made a bob-boo earlier in other 'Compiler Error ???' thread, I said problem was gone (MSCDetection floating point -1.#IND000), unfortunately, I dont seem to have checked for more than the disappearance of the floating point error, seems that the MSCDetection return clip never spots a scene change, all frames identical Green, which is I think all YUV channels 0. (Both End of Scene and Start of Scene clips fail). Below, code snippet to do detections easily yourself, requires no external plugins (EXCEPT of course MVTools2, which I know you have ). Code:
FN="F:\v\StarWars.avi" BLEND= false FLOW = false ####################### Avisource(FN) #Trim(10000,0) DORG=SelectEvery(1,0,0) # Original Each frame twice DBL =DoubleRate(Blend=BLEND,Flow=FLOW) DORG_S = DORG.Sub("Original, Each frame twice",0) DBL_S = DBL.Sub("Double Rate : Blend="+String(Blend)+" Flow="+String(Flow),1) Return StackVertical(DORG_S,DBL_S) ####################### Function DoubleRate(clip c,Bool "Blend",Bool "Flow") { # for MvTools2 v2.7.1.22 testing c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) Return (!Flow) \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend, mode=0) \ : MFlowFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } Function Sub(clip c,string tit,int Md) { Function SubStrLo(int n,string tit,Int Md) {Return string(n)+"] "+tit+(n%2==0?"":Md==0?" (Duplicate)":" (Synthesized)")} S = "SubTitle(SubStrLo(current_frame,"+Chr(34)+tit+Chr(34)+","+String(Md)+"))" StackVertical(c.BlankClip(height=20).ScriptClip(S),c) } EDIT: Above script, you can scrub through whole movie in eg VDubMod and check-out scene changes, and mod BLEND and FLOW to check other modes. EDIT: Oops, sorry, above script requires Grunt plugin. EDIT: Got rid of Grunt() requirement, script updated.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th December 2018 at 01:23. |
16th November 2016, 15:22 | #94 | Link |
Hi! Found something, another try
http://www.mediafire.com/file/60o8c4...tainLessS2.zip Test build, not a release. The bottom line bug was fixed. The fixes/additions since 2.7.1.22: - new: MBlockFPS 10-16 bit - nSCD2 regression fix - nSCD1 (thCSD1) scale for 10+ bits - MBlockFPS: overlaps working buffers were not copied to the output. - MBlockFPS: overlaps: Right columns were ok for the luma only. - MBlockFPS: overlaps: Blend of bottom rows were operating on somewhere the top rows instead of the last row. There are still visible differences on the edges, because right and bottom lines are simply blended when we use overlaps, but this is the way it works. Last edited by pinterf; 16th November 2016 at 16:08. |
17th November 2016, 14:09 | #95 | Link | |
Script, no requirements. Code:
FN="F:\v\StarWars.avi" BLEND= false FLOW = false ####################### Avisource(FN) DORG = SelectEvery(1,0,0) # Original Each frame twice DBLA = DoubleRateA(Blend=BLEND,Flow=FLOW) DBLB = DoubleRateB(Blend=BLEND,Flow=FLOW) DBLC = DoubleRateC(Blend=BLEND,Flow=FLOW) DORG_S = DORG.Sub("Original, Each frame twice",0) DBLA_S = DBLA.Sub("DoubleRate_A(OLap=0) : Blend="+String(Blend)+" Flow="+String(Flow),1) DBLB_S = DBLB.Sub("DoubleRate_B(NEW, Olap=8) : Blend="+String(Blend)+" Flow="+String(Flow),1) DBLC_S = DBLC.Sub("DoubleRate_C(MRecalc, Olap=8): Blend="+String(Blend)+" Flow="+String(Flow),1) H = DORG_S.Blankclip(Height=4,color=$FFFFFF) LFT = StackVertical(DORG_S,H,DBLB_S) RGT = StackVertical(DBLA_S,H,DBLC_S) V = LFT.Blankclip(Width=4,color=$FFFFFF) Return StackHorizontal(LFT,V,RGT) #.trim(48115,0) ####################### Function DoubleRateA(clip c,Bool "Blend",Bool "Flow") { # Overlap = 0 c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=0, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=0, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) Return (!Flow) \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend, mode=0) \ : MFlowFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } Function DoubleRateB(clip c,Bool "Blend",Bool "Flow") { # for MvTools2 v2.7.1.22 testing c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) Return (!Flow) \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend, mode=0) \ : MFlowFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } Function DoubleRateC(clip c,Bool "Blend",Bool "Flow") { # Works OK with MvTools2 v2.6.0.5 c Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps super = MSuper(pel=2, hpad=16, vpad=16,rfilter=4) bw_1 = MAnalyse(super, chroma = false, isb = true, blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) fw_1 = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24)) bw_2 = MRecalculate(super, chroma = false, bw_1, blksize = 8, searchparam = 1, search = 3) # No Overlap (currently broken for final vectors) fw_2 = MRecalculate(super, chroma = false, fw_1, blksize = 8, searchparam = 1, search = 3) # No Overlap Return (!Flow) \ ? MBlockFps(super,bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend, mode=0) \ : MFlowFps(super, bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend) } Function Sub(clip c,string tit,int Md) { Function SubStrLo(int n,string tit,Int Md) {Return string(n)+"] "+tit+(n%2==0?"":Md==0?" (Duplicate)":" (Synthesized)")} S = "SubTitle(SubStrLo(current_frame,"+Chr(34)+tit+Chr(34)+","+String(Md)+"))" StackVertical(c.BlankClip(height=20).ScriptClip(S),c) } TopLeft, original frames, every other one a duplicate, Top Right, Overlap=0, Bot Left, New version MvTools, Overlap=8 Bot Right, Old, Overlap=8, with MRecalculate. All seems to be working OK, for block/Flow/FPS. Script to show problem in MSCDetection, no requrements. Code:
FN="LowBitrateAnime.AVI" Avisource(FN) Function EndOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { # All Luma Samples set 255 at EOS thSCD1=Default(thSCD1,400) thSCD2=Default(thSCD2,130) sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16) bv=sup.MAnalyse(isb=true, delta=1,blksize=16,overlap=8) Return c.MSCDetection(bv,thSCD1=thSCD1,thSCD2=thSCD2) } Function StartOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { # All Luma Samples set 255 at SOS thSCD1=Default(thSCD1,400) thSCD2=Default(thSCD2,130) sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16) fv=sup.MAnalyse(isb=false,delta=1,blksize=16,overlap=8) Return c.MSCDetection(fv,thSCD1=thSCD1,thSCD2=thSCD2) } EOS = EndOfSceneClip SOS = StartOfSceneClip #return EOS SSS=""" e = EOS.AverageLuma s = SOS.AverageLuma Subtitle(String(current_frame)+String(e,"] EOS=%.1f")+String(s," : SOS=%.1f")) (e!=0.0) \ ? Subtitle("End Of Scene",Size=48,Text_Color=$FF0000,Y=Height/2-24,Align=5) \ : (s!=0.0) ? Subtitle("Start Of Scene",Size=48,Text_Color=$0000FF,Y=Height/2+24,Align=5) \ : NOP return last """ Scriptclip(SSS) EDIT: Oh damn, meant to put the MBlockFPS example up on PhotoBucket instead of MFlowFPS, arh well done now. EDIT: MBlockFPS version EDIT: Above image lost due to Photobucket problem. EDIT: The Blending mentioned in the quote at top of post is shown on Right Hand Edge of lower two (Overlap) images in both image sets (dark edge, sourced from next image coming from rhs).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 30th August 2018 at 11:57. |
17th November 2016, 19:40 | #96 | Link |
I'm not saying I'm ready, this is just a new test build inspired by StainlessS
http://www.mediafire.com/file/k78dcm...tainlessS4.zip There were side effects again, ported some more mvtools2 filters to native 10-16 bits and fixed some bugs. Recent change log
Short status report on the 8+ bit transition: MShow, MDepan are not yet ported to 10-16 bits. You can try the others, e.g. MDegrains for 10+ bits with Avisynth plus. EDIT: MFlow, MFlowInter, MFlowBlur ported, removed from the non-16 bit list. And of course you can freely use 4:2:2 and 4:4:4 formats. (like YV16 and YV24) Last edited by pinterf; 17th November 2016 at 20:58. Reason: MFlow, MFlowInter, MFlowBlur ported |
18th November 2016, 12:25 | #97 | Link |
Thanks pinterf, everything seems hunky dory,
I'll continue to use this version and report if I find any anomalies, again thanx. EDIT: I'll probably be using something like below Code:
Function ChangeFrameRate(clip c,Bool "Blend",Bool "Flow",Int "Num",Int "Den",Int "BlkSize",Int "OverLap") { # Req MvTools2 v2.7.1.22+ for Overlap>0 Blend=Default(Blend,False) # Avoid blends at scene change (copy previous frame) Flow=Default(Flow,False) # If True, Use MFlowFps instead of MBlockFps BlkSize=Default(BlkSize,16) Overlap=Default(Overlap,BlkSize/2) n=Default(num,0) d=default(den,0) valid=(n>0 && d>0) n=(!valid)?c.FramerateNumerator*2:n d=(!valid)?c.FramerateDenominator:d # Default = doublerate super = c.MSuper(pel=2, hpad=BlkSize, vpad=BlkSize,rfilter=4) bv = MAnalyse(super, chroma=false, isb=true, blksize=BlkSize, OverLap=OverLap, searchparam=3, plevel=0, search=3, badrange=(-24)) fv = MAnalyse(super, chroma=false, isb=false, blksize=BlkSize, OverLap=OverLap, searchparam=3, plevel=0, search=3, badrange=(-24)) Return (!Flow) \ ? c.MBlockFps(super, bv, fv, num=n, den=d, Blend=Blend, mode=0) \ : c.MFlowFps(super, bv, fv, num=n, den=d, Blend=Blend) } Function DoubleRate(clip c,Bool "Blend",Bool "Flow") {Return c.ChangeFrameRate(Blend,Flow,c.FramerateNumerator*2,c.FramerateDenominator)}
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th November 2016 at 13:35. Reason: Edited |
18th November 2016, 23:18 | #98 | Link |
Thanks, StainlessS, you were excellent, first class tester. You really deserve a new mvtools3 that can realtime interpolate the two suns of tatooine on a ZX81.
But until then I will just bump the version numbers and make a release soon. Good news for me that finally I have finished porting the last two filters, MDepan and MShow for high bit depth, and also finished the two other DLLs for video stabilizing with Depan (DepanEstimate) and DepanStabilize. |
19th November 2016, 19:46 | #99 | Link |
New release:
Download: MvTools 2.7.5.22 + Depan + DepanEstimate for 32 and 64 bits For general info see readme or the first page of the thread. Have fun. Todo:
