9th April 2023, 13:21 | #801 | Link | ||
Hi, Gravitator!
It seems vvencapp reported an error message of your sample file: Quote:
I encoded your sample file on my FFmpeg VVCEasy command, but three duplicated frames: Quote:
9th April 2023, 13:39 | #803 | Link | |
Why it doesn't help?
I know why ticks per second could be quite moderate difficult, but I hope Multicoreware x266 encoder doesn't need ticks per second necessary, so we should wait a little bit to get x266 encoder in H2 2023. Here is the transcoded from your matroska sample file to Y4M report: Quote:
- Martin Eesmaa Last edited by MartinEesmaa; 9th April 2023 at 13:51. |
9th April 2023, 13:59 | #806 | Link |
Oh ok, I see the rawvideo does not have problems, but Y4M does only some errors for some reasons of frame rate per second.
I looked issue for reference: https://github.com/fraunhoferhhi/vvenc/issues/252. This could be bug for Fraunhofer HHI VVC encoder. Maybe I encoded your sample file to libx264 with matroska container without duplicates frames, but encoding to raw bitstream reports duplicate frames. So I think VVC matroska is not finished yet. I think Fraunhofer HHI VVC encoder is experimental I'd say, but I recommend we wait for Multicoreware x266 encoder or just make issue/discussion to vvenc github repository. - Martin Eesmaa Last edited by MartinEesmaa; 9th April 2023 at 14:06. |
9th April 2023, 14:29 | #807 | Link |
They are already treating > https://github.com/fraunhoferhhi/vvenc/pull/255
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB. |
16th April 2023, 21:56 | #810 | Link |
chipsandcheese compared HEVC, AV1, VVC....interesting read.
Codecs for the 4K Era: HEVC, AV1, VVC and Beyond |
17th April 2023, 08:38 | #811 | Link | |
Artem S. Tashkinov
What? What version did they use? From 2 years ago? From https://github.com/fraunhoferhhi/vvenc/wiki/Usage Code:
--qp,-q 32 Quantization parameter (0..63) |
17th April 2023, 09:19 | #812 | Link |
QP and CRF is not the same. CRF will modify the QP to compensate for frame complexity, providing similar "perceived" quality for all frames, while keeping bitrate in check.
Constant QP is the simplest compression mode you can think of, really, as you don't do any rate-control at all.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 17th April 2023 at 09:21. |
22nd May 2023, 11:21 | #814 | Link |
Artem S. Tashkinov
A native VVC decoder has been submitted to FFmpeg: https://www.mail-archive.com/ffmpeg-...eg.org/#147681
There's a number of objections, so it's not yet a done deal. |
31st May 2023, 12:55 | #816 | Link |
Film grain synthesis in VVC would probably be based on the H.274 Film grain characteristics SEI.
Given HEVC supports it, I assume VVC will as well.
LG C2 OLED | GitHub Projects |
29th June 2023, 23:39 | #818 | Link | |
5th July 2023, 19:59 | #820 | Link |
That would be wonderful. At the moment the decoder/encoder is still missing. You can mux a VVC stream from e.g. a MP4 container into a MKV container. But converting the VVC stream into any other format fails. Same for converting any video stream into VVC.
