31st March 2022, 19:37 | #2821 | Link |
_
1)
Plug a TV to PC with HDMI Plug AV receiver to PC with HDMI -> Play sound on AV receiver and image on TV WITHOUT DUAL MONITORS (in Windows > Display settings or GPU Drivers Control Panel) And obviously I don't want to use the HDMI out from AV receiver. 2) Plug a monitor to PC with Display Port (for example) Plug AV receiver to PC with HDMI -> Play sound on AV receiver and image on Monitor WITHOUT DUAL MONITORS Rest assured it's not a mad demand. It has been asked for years from various people. I was hoping it would come with years. |
31st March 2022, 20:04 | #2822 | Link | |
at this point i take this personal. and while i'm at it how do i disable the video processing for web browser? |
31st March 2022, 21:10 | #2823 | Link | |
Something Else
I did try an app to prevent mouse spanning to next display but it was just simpler to arrange both displays diagonally without the app. I also tried duplicating displays which actually worked and got rid of the dual monitor issue but I found out I could not use HDR. My guess is that it duplicates to the lowest display so for my my soundbar uses HDMI 2.0 and my display is 2.1. I hope there is a solution for this annoying problem.
"We all began as something else"
4th April 2022, 14:41 | #2824 | Link |
A long time ago (I don't remember exactly, but something like two/three years I think) I opened an improvement suggestion on Insider Hub for exactly this (using secondary display interfaces and their hardware features but without them being included in the user desktop), without much hope of achieving anything with MS being MS, and to my surprise they actually added it *but* concluded this is something only professionnals need (e.g. doctors using a pro app that displays radio scans on a secondary display), and so they restricted this feature to Windows for Workstations...
6th April 2022, 15:17 | #2826 | Link |
I'm on the driver below with my new RTX and 4K60.
I'm using DisplayPort for the first time and finding I cannot get Full Range 0-255. It's only allowing me Limited Range color. Is this normal for DisplayPort or an issue with the driver (or cable)? 512.15-desktop-win10-win11-64bit-international-dch-whql.exe Works fine at 1080P, it just greys out the Output Dynamic Range with 4K60. Switch from DisplayPort to HDMI and it works fine. ATMOS and 4k60 passes through the DisplayPort so I'm not understanding why the dynamic range is getting greyed out. Last edited by CZ Eddie; 6th April 2022 at 17:51. |
8th April 2022, 10:20 | #2827 | Link |
passive DP to hdmi can only do about 9 gbit/s close to HDMI 1.4.
or with other words because it can't do more to do it in RGB so with full range it would need double the bandwidth like present on HDMI 2.0 or native DP 1.2. there are active DP to HDMI converter but they a bit iffy. GPU with 2 HDMI connector are not that rare just make sure they also have the HDMI version you want. |
13th April 2022, 16:37 | #2828 | Link |
But full range and limited range only change the reference values used for black/white, the video bandwidth used is the same in both cases.
26th April 2022, 15:59 | #2830 | Link |
Figures. I have my HTPC's disconnected at the moment awaiting a TV upgrade. I'll update them all later tonight I guess.
27th April 2022, 23:01 | #2834 | Link |
I couldn't fit 77" in my current place, hence I only got the G1 in 65" last year, but smaller place also means sitting closer, so its still quite an experience.
28th April 2022, 01:44 | #2835 | Link |
The C8 got moved to my bedroom. And the G2 is in my living room. Both are mounted to an echogear that pulls out 22" from the wall.
4th May 2022, 18:57 | #2836 | Link |
Haven't visited in a long time. What the latest consensus regarding which Win10 driver for the RTX 2070S works best with madVR?
My HT: JVC X790R | 120" CineWhite | madVR 169 RTX 2070S | mpv 0.36.x | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe | 4 x ADX Maximus w/ Dayton Audio SA230 | 40" HDTV w/ MoviePosterApp |
