Old 14th March 2022, 21:37   #81  |  Link
kolak
Originally Posted by PCU View Post
FFV1 is supported by Voukoder, x265 does not support HW acceleration and I'll have to pay for MYUV for full version!
But I think it all ends in MYUV!
Try encoding ffv1 UHD 60p in realtime...
Old 14th March 2022, 21:41   #82  |  Link
kolak
Originally Posted by Zarxrax View Post
You can use DNxHR or Prores. They are perceptually lossless and probably faster than even Magic YUV. Can encode in FFMPEG and at least one of them should be supported in premiere. Nothing to buy.
They are not necessarily faster than MagicYUV, but you need good disk for lossless.
Old 20th March 2022, 00:15   #83  |  Link
Balling
Guys, do you think this claim is true?:
x264 cannot actually achieve lossless. It's lossless setting is close but ProRes422 is generally a little better quality, faster rendering, and smaller. MagicYUV is another possible option.
It cannot achieve lossless in high10 profile. But there is high444 that does give you lossless even in 10 bit. But i think av1 lossless should be better, in aomenc.
Balling is offline   Reply With Quote
Old 21st March 2022, 10:42   #84  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Also, if you're gonna encode in prores, you should use the -vendor apl0 flag otherwise some players might bitch about it not being an Apple Compliant encoded file.
By the way, as Kolak said, they're not necessarily faster than other codecs AND they're NOT lossless, so... are you really sure you wanna go that route?
And by the way, if you must choose between DNxHR and Apple ProRes, go the DNxHR route, so that at least you're gonna pick the "less evil" between the two given that Apple is artificially trying to block FFMpeg encoded files from playing on their players / devices while AVID is not.
Old 21st March 2022, 20:39   #85  |  Link
kolak
Ffmpeg ProRes is rather slow.
Apple code is quite fast, but best is M1 hardware chip inside new Macs. This can do way pass 1000fps when decoding+encoding (simultaneously) HD ProRes, so very impressive.
Old 23rd July 2022, 16:39   #86  |  Link
PatchWorKs
PatchWorKs's Avatar
Sorry to revive this 3ad, but I need your help to optimize FFMPEG encoding parameters.
I need to losslessy encode a set of 14500+ 32bits 2K BMPs (~137Gb) in order to build the final compositing and (re)encoding.
I've tested the following cmdline, but my NLE - Vegas Pro 19 - handle it bad (wrong colors, unplayable):
ffmpeg -hwaccel auto -framerate 25 -i SEQ1_%06d.bmp -vcodec libx265 -x265-params lossless=1 SEQ1_x265.mp4
...any suggestion ?
Thanks in advance to anyone that will help.
Hybrid Multimedia Production Suite will be a platform-indipendent open source suite for advanced audio/video contents production.
Official git: https://www.forart.it/HyMPS/
PatchWorKs is offline   Reply With Quote
Old 23rd July 2022, 19:44   #87  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I assume that when you say bmp 24bit you mean RGB24.
What's the input colormatrix, primaries and transfer?
If you shot in BT709 SDR Full PC Range RGB24 8bit, try this:
ffmpeg.exe -framerate 25 -i "SEQ1_%06d.bmp" -pix_fmt yuv444p -vcodec libx265 -color_primaries 1 -color_trc 1 -colorspace 1 -x265-params lossless=1 -an -y "SEQ1_x265.mp4"
Otherwise just use the great FFAStrans with the Image Sequence Monitor and output to a sane mezzanine file for NLE like DNX or Apple ProRes and the filter_builder will take care of everything for you automatically.
Old 24th July 2022, 16:21   #88  |  Link
kolak
...any suggestion ?
Sounds like Vegas can’t decode lossless h265.
Are you sure it can. What about playback in player which you know it can?
I would use something like MagicYUV etc of instead of h265.
Old 25th July 2022, 10:56   #89  |  Link
PatchWorKs
PatchWorKs's Avatar
Yes, sorry, you're right.
Works like a charm, thanks !
Just a curiosity: this command line produces smaller files than the other... it's caused by the wrong colorspace ?
Thanks for your great support !
Old 25th July 2022, 11:03   #90  |  Link
PatchWorKs
PatchWorKs's Avatar
Now works, was the wrong commandline.
I evaluated MagicYUV but I still don't understand how use it from commandline...
Old 25th July 2022, 15:19   #91  |  Link
poisondeathray
Why don't you just import the image sequence directly in vegas?
-pix_fmt yuv444p (8bit YUV444) is not a lossless transform from 8bit RGB24
Old 25th July 2022, 22:12   #92  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Perfect. I'm glad to hear that.
YUV by definition is easier to compress than RGB.
I know that you're Italian, so you can read a document I wrote about those things years ago (in Italian): link
Go to page 56-57 and you'll see the whole YCbCr YUV / RGB thing.
Old 9th August 2022, 15:09   #93  |  Link
Balling
bgr. BMP is always using BGR.
Old 9th August 2022, 15:31   #94  |  Link
Balling
...any suggestion ?
Use true lossless (if you have nvidia gpu see next):
ffmpeg.exe -framerate 25 -i "SEQ1_%06d.bmp" -color_primaries 1 -color_trc 1 -c:v libx264rgb -preset veryslow -color_primaries 1 -color_trc 1 -qp 0 "SEQ1_x265.mp4"
Or use normal lossless Nvidia coder.
ffmpeg -framerate 25 -i "SEQ1_%06d.bmp" -color_primaries 1 -color_trc 1 -c:v hevc_nvenc -preset p7 -tune lossless -pix_fmt gbrp output.mp4
Use normal ffmpeg from here https://github.com/BtbN/FFmpeg-Build...gpl-shared.zip or the command for nvidia will not work, since rgb (gbrp, anyway) was added recently. Also, RGB does not technically support 420 (except in JPEG), so requires 444 chroma, which is supported since Turing on HEVC and AVC (hevc_nvenc and h264_nvenc).
Old 10th August 2022, 11:43   #95  |  Link
tormento
Acid fr0g
tormento's Avatar
Please notice that DGDecNV now supports 4:4:4 chroma. With HW accelerated HEVC lossless, it's a perfect match to use with intermediate files.
@turment on Telegram
Old 10th August 2022, 17:04   #96  |  Link
Balling
This is not chroma, this is rgb (using gbrp).
