17th January 2023, 15:01 | #181 | Link |
CTools HBD rewrite
Not sure this is the right place to ask but since Ceppo is out of doom9 (at least since 10 months ago) I think forking his plugin would be in ok. Also I have not yet recieved a reply from Asd-g if he/she wants to modify/fork CTools.
The question is about the source code and how to modify it for HBD. I also see that it has no specific code for avx, avx2, avx512 etc. but as I am not even familiar with C++ or programming I leave that for now. Here is my no-knowledge attempt to modify CDegrain. type.h-file: Code:
//type.h #ifndef AVS_TYPES_H #define AVS_TYPES_H // Define all types necessary for interfacing with avisynth.dll #include <stdint.h> #include <stdbool.h> #ifdef __cplusplus #include <cstddef> #include <cstdarg> #else #include <stddef.h> #include <stdarg.h> #endif // Raster types used by VirtualDub & Avisynth typedef uint32_t Pixel32; typedef uint16_t Pixel16; //? typedef Pixel16 Y_PLANE; typedef Pixel16 U_PLANE; typedef Pixel16 V_PLANE; //? typedef uint14_t Pixel14; typedef Pixel14 Y_PLANE; typedef Pixel14 U_PLANE; typedef Pixel14 V_PLANE; // typedef uint12_t Pixel12; typedef Pixel12 Y_PLANE; typedef Pixel12 U_PLANE; typedef Pixel12 V_PLANE; // typedef uint10_t Pixel10; typedef Pixel10 Y_PLANE; typedef Pixel10 U_PLANE; typedef Pixel10 V_PLANE; // typedef uint8_t BYTE; typedef uint10_t BYTE; typedef uint12_t BYTE; typedef uint14_t BYTE; typedef uint16_t BYTE; // Audio Sample information typedef float SFLOAT; #endif //AVS_TYPES_H Code:
#pragma once #include <cmath> #include <windows.h> #include "avisynth.h" class CDegrain : public GenericVideoFilter { int radius; int nt; int thr; int blksize; PClip dClip; public: CDegrain(PClip _child, int _radius, int _nt, int _thr, int _blksize, PClip _dClip, IScriptEnvironment* env); PVideoFrame __stdcall GetFrame(int n, IScriptEnvironment* env); }; void CDegrain_Y(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize); void CDegrain_YUV420(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize); void CDegrain_YUV422(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize); void CDegrain_YUV444(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize); |
17th January 2023, 15:03 | #182 | Link |
CTools HBD, part 2
CDegrain.cpp:
#include "CDegrain.h" CDegrain::CDegrain(PClip _child, int _radius, int _nt, int _thr, int _blksize, PClip _dClip, IScriptEnvironment* env) : GenericVideoFilter(_child), radius(_radius), nt(_nt), thr(_thr), blksize(_blksize), dClip(_dClip) { if (!vi.IsY() && !vi.IsYUV420() && !vi.IsYUV422() && !vi.IsYUV444()) { env->ThrowError("CDegrain: supported colorspaces are Y, YUV420, YUV422, YUV444!"); } else if ((vi.IsYUV420() || vi.IsYUV422()) && blksize < 2) { env->ThrowError("CDegrain: YUV420/YUV422 min. blksize is 2!"); } else if (radius < 0 || radius > 7) { env->ThrowError("CDegrain: radius values must be in the [1, 7] range!"); } } PVideoFrame __stdcall CDegrain::GetFrame(int n, IScriptEnvironment* env) { int i; PVideoFrame dst = env->NewVideoFrame(vi); PVideoFrame src[15]; for (i = 0; i < radius; i += 1) { src[i] = child->GetFrame(max(n - radius + i, 0), env); } src[radius] = child->GetFrame(n, env); for (i = 0; i < radius; i += 1) { src[i + radius + 1] = child->GetFrame(min(n + i + 1, vi.num_frames - 1), env); } PVideoFrame den[15]; if (!dClip) { vi.IsY() ? CDegrain_Y(src, src, dst, nt, thr, radius, blksize) : NULL; vi.IsYUV420() ? CDegrain_YUV420(src, src, dst, nt, thr, radius, blksize) : NULL; vi.IsYUV422() ? CDegrain_YUV422(src, src, dst, nt, thr, radius, blksize) : NULL; vi.IsYUV444() ? CDegrain_YUV444(src, src, dst, nt, thr, radius, blksize) : NULL; } else { for (i = 0; i < radius; i += 1) { den[i] = dClip->GetFrame(max(n - radius + i, 0), env); } den[radius] = dClip->GetFrame(n, env); for (i = 0; i < radius; i += 1) { den[i + radius + 1] = dClip->GetFrame(min(n + i + 1, vi.num_frames - 1), env); } vi.IsY() ? CDegrain_Y(src, den, dst, nt, thr, radius, blksize) : NULL; vi.IsYUV420() ? CDegrain_YUV420(src, den, dst, nt, thr, radius, blksize) : NULL; vi.IsYUV422() ? CDegrain_YUV422(src, den, dst, nt, thr, radius, blksize) : NULL; vi.IsYUV444() ? CDegrain_YUV444(src, den, dst, nt, thr, radius, blksize) : NULL; } return dst; } void CDegrain_Y(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize) { int i; unsigned char* dstp; dstp = dst->GetWritePtr(PLANAR_Y); const unsigned char* srcp[15]; const unsigned char* denp[15]; for (i = 0; i < 15; i += 1) { srcp[min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); denp[min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); } int dst_pitch; dst_pitch = dst->GetPitch(PLANAR_Y); int src_pitch[15]; int den_pitch[15]; for (i = 0; i < 15; i += 1) { src_pitch[min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_Y); den_pitch[min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_Y); } int height = dst->GetHeight(PLANAR_Y); int row_size = dst->GetRowSize(PLANAR_Y); int64_t BSY = 0; int64_t BSX = 0; BSY += min(1, height % blksize); BSY += height / blksize; BSX += min(1, row_size % blksize); BSX += row_size / blksize; auto SUM = new int[BSY * BSX][15]; memset(SUM, 0, BSY * BSX * 15 * sizeof(int)); int BX, BY; int pixel_sum[2]; int x, y, a, b, temp; //DIFFERENCE for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { temp = abs(denp[i][x] - denp[radius][x]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; } } for (i = 0; i < radius * 2 + 1; i += 1) { denp[i] += den_pitch[i]; } } //BLENDING for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] = 0; pixel_sum[1] = 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] += SUM[BY * BSY + BX][i] <= thr ? 1 : 0; pixel_sum[1] += SUM[BY * BSY + BX][i] <= thr ? srcp[i][x] : 0; } dstp[x] = int(pixel_sum[1] / static_cast<float>(pixel_sum[0]) + 0.5f); } } dstp += dst_pitch; for (i = 0; i < radius * 2 + 1; i += 1) { srcp[i] += src_pitch[i]; } } } void CDegrain_YUV420(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize) { int i; unsigned char* dstp[3]; dstp[0] = dst->GetWritePtr(PLANAR_Y); dstp[1] = dst->GetWritePtr(PLANAR_U); dstp[2] = dst->GetWritePtr(PLANAR_V); const unsigned char* srcp[3][15]; const unsigned char* denp[3][15]; for (i = 0; i < 15; i += 1) { srcp[0][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); denp[0][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); srcp[1][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_U); denp[1][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_U); srcp[2][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_V); denp[2][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_V); } int dst_pitch[3]; dst_pitch[0] = dst->GetPitch(PLANAR_Y); dst_pitch[1] = dst->GetPitch(PLANAR_U); dst_pitch[2] = dst->GetPitch(PLANAR_V); int src_pitch[3][15]; int den_pitch[3][15]; for (i = 0; i < 15; i += 1) { src_pitch[0][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_Y); den_pitch[0][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_Y); src_pitch[1][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_U); den_pitch[1][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_U); src_pitch[2][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_V); den_pitch[2][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_V); } int height = dst->GetHeight(PLANAR_Y); int row_size = dst->GetRowSize(PLANAR_Y); int64_t BSY = 0; int64_t BSX = 0; BSY += min(1, height % blksize); BSY += height / blksize; BSX += min(1, row_size % blksize); BSX += row_size / blksize; auto SUM = new int[BSY * BSX][15]; memset(SUM, 0, BSY * BSX * 15 * sizeof(int)); int BX, BY; int pixel_sum[3]; int x, y, a, b, temp; //DIFFERENCE for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { temp = abs(denp[0][i][x] - denp[0][radius][x]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; } if (!(y % 2) && !(x % 2)) { for (i = 0; i < radius * 2 + 1; i += 1) { temp = abs(denp[1][i][x / 2] - denp[1][radius][x / 2]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; temp = abs(denp[2][i][x / 2] - denp[2][radius][x / 2]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; } } } for (i = 0; i < radius * 2 + 1; i += 1) { denp[0][i] += den_pitch[0][i]; } if (!(y % 2)) { for (i = 0; i < radius * 2 + 1; i += 1) { denp[1][i] += den_pitch[1][i]; denp[2][i] += den_pitch[2][i]; } } } //BLENDING for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] = 0; pixel_sum[1] = 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] += SUM[BY * BSY + BX][i] <= thr ? 1 : 0; pixel_sum[1] += SUM[BY * BSY + BX][i] <= thr ? srcp[0][i][x] : 0; } dstp[0][x] = int(pixel_sum[1] / static_cast<float>(pixel_sum[0]) + 0.5f); // Continues in next post. |
17th January 2023, 15:04 | #183 | Link |
if (!(y % 2) && !(x % 2)) { pixel_sum[0] = 0; pixel_sum[1] = 0; pixel_sum[2] = 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] += SUM[BY * BSY + BX][i] <= thr ? 1 : 0; pixel_sum[1] += SUM[BY * BSY + BX][i] <= thr ? srcp[1][i][x / 2] : 0; pixel_sum[2] += SUM[BY * BSY + BX][i] <= thr ? srcp[2][i][x / 2] : 0; } dstp[1][x / 2] = int(pixel_sum[1] / static_cast<float>(pixel_sum[0]) + 0.5f); dstp[2][x / 2] = int(pixel_sum[2] / static_cast<float>(pixel_sum[0]) + 0.5f); } } } dstp[0] += dst_pitch[0]; for (i = 0; i < radius * 2 + 1; i += 1) { srcp[0][i] += src_pitch[0][i]; } if (!(y % 2)) { dstp[1] += dst_pitch[1]; dstp[2] += dst_pitch[2]; for (i = 0; i < radius * 2 + 1; i += 1) { srcp[1][i] += src_pitch[1][i]; srcp[2][i] += src_pitch[2][i]; } } } } void CDegrain_YUV422(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize) { int i; unsigned char* dstp[3]; dstp[0] = dst->GetWritePtr(PLANAR_Y); dstp[1] = dst->GetWritePtr(PLANAR_U); dstp[2] = dst->GetWritePtr(PLANAR_V); const unsigned char* srcp[3][15]; const unsigned char* denp[3][15]; for (i = 0; i < 15; i += 1) { srcp[0][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); denp[0][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); srcp[1][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_U); denp[1][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_U); srcp[2][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_V); denp[2][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_V); } int dst_pitch[3]; dst_pitch[0] = dst->GetPitch(PLANAR_Y); dst_pitch[1] = dst->GetPitch(PLANAR_U); dst_pitch[2] = dst->GetPitch(PLANAR_V); int src_pitch[3][15]; int den_pitch[3][15]; for (i = 0; i < 15; i += 1) { src_pitch[0][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_Y); den_pitch[0][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_Y); src_pitch[1][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_U); den_pitch[1][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_U); src_pitch[2][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_V); den_pitch[2][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_V); } int height = dst->GetHeight(PLANAR_Y); int row_size = dst->GetRowSize(PLANAR_Y); int64_t BSY = 0; int64_t BSX = 0; BSY += min(1, height % blksize); BSY += height / blksize; BSX += min(1, row_size % blksize); BSX += row_size / blksize; auto SUM = new int[BSY * BSX][15]; memset(SUM, 0, BSY * BSX * 15 * sizeof(int)); int BX, BY; int pixel_sum[3]; int x, y, a, b, temp; //DIFFERENCE for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { temp = abs(denp[0][i][x] - denp[0][radius][x]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; } if (!(x % 2)) { for (i = 0; i < radius * 2 + 1; i += 1) { temp = abs(denp[1][i][x / 2] - denp[1][radius][x / 2]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; temp = abs(denp[2][i][x / 2] - denp[2][radius][x / 2]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; } } } for (i = 0; i < radius * 2 + 1; i += 1) { denp[0][i] += den_pitch[0][i]; denp[1][i] += den_pitch[1][i]; denp[2][i] += den_pitch[2][i]; } } //BLENDING for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] = 0; pixel_sum[1] = 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] += SUM[BY * BSY + BX][i] <= thr ? 1 : 0; pixel_sum[1] += SUM[BY * BSY + BX][i] <= thr ? srcp[0][i][x] : 0; } dstp[0][x] = int(pixel_sum[1] / static_cast<float>(pixel_sum[0]) + 0.5f); if (!(x % 2)) { pixel_sum[0] = 0; pixel_sum[1] = 0; pixel_sum[2] = 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] += SUM[BY * BSY + BX][i] <= thr ? 1 : 0; pixel_sum[1] += SUM[BY * BSY + BX][i] <= thr ? srcp[1][i][x / 2] : 0; pixel_sum[2] += SUM[BY * BSY + BX][i] <= thr ? srcp[2][i][x / 2] : 0; } dstp[1][x / 2] = int(pixel_sum[1] / static_cast<float>(pixel_sum[0]) + 0.5f); dstp[2][x / 2] = int(pixel_sum[2] / static_cast<float>(pixel_sum[0]) + 0.5f); } } } dstp[0] += dst_pitch[0]; dstp[1] += dst_pitch[1]; dstp[2] += dst_pitch[2]; for (i = 0; i < radius * 2 + 1; i += 1) { srcp[0][i] += src_pitch[0][i]; srcp[1][i] += src_pitch[1][i]; srcp[2][i] += src_pitch[2][i]; } } } void CDegrain_YUV444(PVideoFrame(&src)[15], PVideoFrame(&den)[15], PVideoFrame& dst, int nt, int thr, int radius, int blksize) { int i; unsigned char* dstp[3]; dstp[0] = dst->GetWritePtr(PLANAR_Y); dstp[1] = dst->GetWritePtr(PLANAR_U); dstp[2] = dst->GetWritePtr(PLANAR_V); const unsigned char* srcp[3][15]; const unsigned char* denp[3][15]; for (i = 0; i < 15; i += 1) { srcp[0][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); denp[0][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_Y); srcp[1][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_U); denp[1][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_U); srcp[2][min(i, radius * 2)] = src[min(i, radius * 2)]->GetReadPtr(PLANAR_V); denp[2][min(i, radius * 2)] = den[min(i, radius * 2)]->GetReadPtr(PLANAR_V); } int dst_pitch[3]; dst_pitch[0] = dst->GetPitch(PLANAR_Y); dst_pitch[1] = dst->GetPitch(PLANAR_U); dst_pitch[2] = dst->GetPitch(PLANAR_V); int src_pitch[3][15]; int den_pitch[3][15]; for (i = 0; i < 15; i += 1) { src_pitch[0][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_Y); den_pitch[0][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_Y); src_pitch[1][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_U); den_pitch[1][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_U); src_pitch[2][min(i, radius * 2)] = src[min(i, radius * 2)]->GetPitch(PLANAR_V); den_pitch[2][min(i, radius * 2)] = den[min(i, radius * 2)]->GetPitch(PLANAR_V); } int height = dst->GetHeight(PLANAR_Y); int row_size = dst->GetRowSize(PLANAR_Y); int64_t BSY = 0; int64_t BSX = 0; BSY += min(1, height % blksize); BSY += height / blksize; BSX += min(1, row_size % blksize); BSX += row_size / blksize; auto SUM = new int[BSY * BSX][15]; memset(SUM, 0, BSY * BSX * 15 * sizeof(int)); int BX, BY; int pixel_sum[4]; int x, y, a, b, temp; //DIFFERENCE for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { temp = abs(denp[0][i][x] - denp[0][radius][x]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; temp = abs(denp[1][i][x] - denp[1][radius][x]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; temp = abs(denp[2][i][x] - denp[2][radius][x]); SUM[BY * BSY + BX][i] += temp > nt ? 255 : temp; } } for (i = 0; i < radius * 2 + 1; i += 1) { denp[0][i] += den_pitch[0][i]; denp[1][i] += den_pitch[1][i]; denp[2][i] += den_pitch[2][i]; } } //BLENDING for (y = 0; y < height; y += 1) { BY = y / blksize; BY += y % blksize ? 1 : 0; for (x = 0; x < row_size; x += 1) { BX = x / blksize; BX += x % blksize ? 1 : 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] = 0; pixel_sum[1] = 0; pixel_sum[2] = 0; pixel_sum[3] = 0; for (i = 0; i < radius * 2 + 1; i += 1) { pixel_sum[0] += SUM[BY * BSY + BX][i] <= thr ? 1 : 0; pixel_sum[1] += SUM[BY * BSY + BX][i] <= thr ? srcp[0][i][x] : 0; pixel_sum[2] += SUM[BY * BSY + BX][i] <= thr ? srcp[1][i][x] : 0; pixel_sum[3] += SUM[BY * BSY + BX][i] <= thr ? srcp[2][i][x] : 0; } dstp[0][x] = int(pixel_sum[1] / static_cast<float>(pixel_sum[0]) + 0.5f); dstp[1][x] = int(pixel_sum[2] / static_cast<float>(pixel_sum[0]) + 0.5f); dstp[2][x] = int(pixel_sum[3] / static_cast<float>(pixel_sum[0]) + 0.5f); } } dstp[0] += dst_pitch[0]; dstp[1] += dst_pitch[1]; dstp[2] += dst_pitch[2]; for (i = 0; i < radius * 2 + 1; i += 1) { srcp[0][i] += src_pitch[0][i]; srcp[1][i] += src_pitch[1][i]; srcp[2][i] += src_pitch[2][i]; } } } |
17th January 2023, 20:26 | #184 | Link |
I once asked Pinterf if there was a good example for coding for AVS+ colorspace stuff, [I cant find the posts, but], see here reply suggested Average plugin :-
https://github.com/pinterf/Average/releases/tag/0.95
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 17th January 2023 at 21:26. |
18th January 2023, 00:35 | #185 | Link | |
Harassing the ChatGPT bot to spit out CUDA optimizations of CTools and hbd support. One can only dream I guess. Edit: here I paste what the bot did. Gibberish or usable? Cdegrain_cuda.cpp: https://pastebin.com/cCsNN3Uh Cdegrain.h (cuda): https://pastebin.com/HDy5wS10 AvisynthpluginInit_cuda.cpp: https://pastebin.com/VRAQhgri types_cuda.h: https://pastebin.com/SCnCWY3N minmax_cuda.h: https://pastebin.com/0MTCE2pB cpuid_cuda.h: https://pastebin.com/Ndu6wSJu Alignment_cuda.h: https://pastebin.com/xdh1hNM2 Ctemporalsoften_cuda.cpp: https://pastebin.com/d4bBPxD2 Last edited by anton_foy; 18th January 2023 at 14:05. |
18th January 2023, 22:47 | #186 | Link |
I got the notification for this CDegrain stuff, glad someone found uselful my work and wants to improve it. BTW, it was not for the argument on github iyeah I was pissed, I admit it) that i leaved but because I'm tring to get a degree in philosophy in 1 year and I'm giving 3 exams for month, I also left my job, so I can't let myself get obsessed by my encoding obsession otherwise or I want be able to reach my goal. I won't answer to any replay to protect myself from the ipnoting power of avisynth.
19th January 2023, 00:38 | #188 | Link | |
Thanks for letting me/us improve your code. |
23rd January 2023, 20:23 | #189 | Link |
I have a good news, to get a degree I need to do only 2 exams and write the thesis. So if someone mods CSharpen or a simple plugin like that I can rewrite CTools for HBD (when I want to relax to not think about philosophy) but is not something that I will do in a few days. Also, I have no knowlodge of optimization and stuff, and unless someone makes me an easy tutorial to get started, someone else will have to do the optimization.
Hope that helps. |
23rd January 2023, 22:30 | #190 | Link | |
From old avisynth to avs+ I was thinking the change is yv12 becomes YUV420, YV16 - YUV422, yv24 - YUV444, Y8 - Y. Then call bitspercomponent and probably use bitLshift when need of scaling 0-256. Someone who really knows this please correct me. |
23rd January 2023, 22:35 | #191 | Link |
I'm not a programmer, I need working examples to make experiments and learn that way to get the hang of it. Sadly, I have a humanistic CV, so I lack a lot of information about programming.
AND ON STACKOVERFLOW NOBODY CARES ABOUT AVISYNTH; WHYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY of course I'm drunk Last edited by Ceppo; 23rd January 2023 at 22:37. |
24th January 2023, 17:17 | #192 | Link |
I have only 1 exam this month, so I'm making experiments since I'm rusty. Can someone help me figure out why this plugins makes AVSPMOD crash? It's probabily something stupid, but I can't figure it out.
#pragma once #include <avisynth.h> class CReadVideoFrame { public: PVideoFrame frame; const unsigned char* pixel[3]; int pitch[3]; int height[3]; int row_size[3]; CReadVideoFrame(PVideoFrame src) { this->frame = src; this->pixel[0] = this->frame->GetReadPtr(PLANAR_Y); this->pixel[1] = this->frame->GetReadPtr(PLANAR_U); this->pixel[2] = this->frame->GetReadPtr(PLANAR_V); this->pitch[0] = this->frame->GetPitch(PLANAR_Y); this->pitch[1] = this->frame->GetPitch(PLANAR_U); this->pitch[2] = this->frame->GetPitch(PLANAR_V); this->height[0] = this->frame->GetHeight(PLANAR_Y); this->height[1] = this->frame->GetHeight(PLANAR_U); this->height[2] = this->frame->GetHeight(PLANAR_V); this->row_size[0] = this->frame->GetRowSize(PLANAR_Y); this->row_size[1] = this->frame->GetRowSize(PLANAR_U); this->row_size[2] = this->frame->GetRowSize(PLANAR_V); }; }; class CWriteVideoFrame { public: PVideoFrame frame; unsigned char* pixel[3]; int pitch[3]; CWriteVideoFrame(PVideoFrame dst) { this->frame = dst; this->pixel[0] = this->frame->GetWritePtr(PLANAR_Y); this->pixel[1] = this->frame->GetWritePtr(PLANAR_U); this->pixel[2] = this->frame->GetWritePtr(PLANAR_V); this->pitch[0] = this->frame->GetPitch(PLANAR_Y); this->pitch[1] = this->frame->GetPitch(PLANAR_U); this->pitch[2] = this->frame->GetPitch(PLANAR_V); }; }; class SimpleCopy : public GenericVideoFilter { public: SimpleCopy(PClip _child, IScriptEnvironment* env) : GenericVideoFilter(_child) { } PVideoFrame __stdcall GetFrame(int n, IScriptEnvironment* env) { CReadVideoFrame src(child->GetFrame(n, env)); CWriteVideoFrame dst(env->NewVideoFrame(vi)); for (int p = 0; p < 3; p++) { for (int y = 0; y < src.height[p]; y++) { for (int x = 0; x < src.row_size[p]; x++) { dst.pixel[p][x] = src.pixel[p][x]; } dst.pixel[p] += dst.pitch[p]; src.pixel[p] += src.pitch[p]; } } return dst.frame; } }; AVSValue __cdecl Create_SimpleCopy(AVSValue args, void* user_data, IScriptEnvironment* env) { return new SimpleCopy(args[0].AsClip(), env); } const AVS_Linkage* AVS_linkage = 0; extern "C" __declspec(dllexport) const char* __stdcall AvisynthPluginInit3(IScriptEnvironment * env, const AVS_Linkage* const vectors) { AVS_linkage = vectors; env->AddFunction("SimpleCopy", "c", Create_SimpleCopy, 0); return "SimpleCopy"; } |
7th March 2023, 05:40 | #193 | Link | |
I'm enjoying CQTGMC on my live-action DVDs, but it seems to affect nearly every Fox Animation DVD I have, though they are notorious for being poorly encoded (Simpsons, Family Guy, etc) |
15th July 2023, 05:03 | #194 | Link | |
anyway, if Ceppo still care, I came across a source with a stubborn scene that has mouth problem, so I used animeivtc but even the default autoAssufthr1 was not enough so I did use "autoAssuf=true, autoAssufthr1=0.3" so Ceppo may like port the method to CTelecine https://github.com/realfinder/AVS-St...avsi#L290-L307 as mode=7 or as new parameter
See My Avisynth Stuff Last edited by real.finder; 15th July 2023 at 05:09. |
14th October 2023, 15:53 | #195 | Link |
after more tests seems http://avisynth.nl/index.php/IT is the best for field matching mouth problem
also seems Ceppo delete his account in github and also the project go with it so here the archive like for it https://web.archive.org/web/20230118...poTools/CTools
See My Avisynth Stuff |
15th October 2023, 02:34 | #196 | Link |
@real.finder did you test new ideas from Ceppo???
https://forum.doom9.org/showthread.php?t=185104 |
15th October 2023, 03:43 | #197 | Link | |
anyway it seems interesting, but still I hope for a plugin update not only for better Field Matching but also for better VFR and frame properties support Plus HBD
