19th November 2003, 00:15 | #81 | Link |
Simply me
I use Microsoft Visual C++ to compile filters.
You probably can compile them with some flavour of MS .net but I've no experience with this (Hopefully someone else can comment) You can't use any known free compiler, so unfortunately you'll have to fork out some money to start. regards Simon
http://www.geocities.com/siwalters_uk/fnews.html |
26th January 2004, 17:03 | #82 | Link |
I'm having trouble with this sample code. The code compiles fine but I can't load the finished DLL. So far, it seems to be caused by the avisynth.h file. I'm testing with Avisynth 2.5.0, is that the reason?
I'm using MSVC 5.0. P.S. Thanks for the excellent example, it has been VERY helpful. |
26th January 2004, 21:55 | #83 | Link |
Simply me
AFAIK you need MSVC 6 or later to make Avisynth filters
regards Simon
5th February 2004, 04:43 | #84 | Link |
First I would like to thank everyone who have worked on the SimpleSample. It is helping a lot. However, considering that I don't own MASC 6, would it be possible to have a SimpleSample with the C interface using the YV12 color space?
15th February 2004, 07:30 | #85 | Link |
the dumbest
Hello everyone,
Iīm trying to make my first avisynth filter and I have a big stupid problem.I just canīt figure out how to define a destination frame with 2x the original width and height.I've been looking into many filter sources but, no way I can't understand how the new dimensions are set. Anybody could help me? Take note I'm really dumb about coding C++ and using Avisynth code. Thanks. |
15th February 2004, 15:58 | #86 | Link |
Simply me
See if the stuff in this thread helps - if not - come back
http://forum.doom9.org/showthread.ph...435#post392435 regards Simon
18th February 2004, 03:53 | #87 | Link |
the dumbest
It seems that vi.width = vi.width*2; vi.height = vi.height*2; isnīt working for me.I canīt get a double size.
In fact I used simplesample as framework and changed silly things but nothing happens. Last edited by morsa; 18th February 2004 at 04:21. |
18th February 2004, 08:46 | #89 | Link |
the dumbest
Weīre not talking about scripting but coding in C++.
By this time I'm trying to make an Scale2x implementation for Avisynth for testing purposes (I'm thinking about coupling it with some kind of pre-prosesing filter or a mixture of algos) but I'm really stuck with this problem.I know it may sound trivial for most people here, but the lack of documentation and full examples is driving me nuts! Thank you. P.S: BTW whatīs the use of Subframe?? Last edited by morsa; 18th February 2004 at 12:34. |
19th February 2004, 04:08 | #90 | Link |
Simple Sample
I had used Siwalters simple Sample to develop my transition plugins and am greatful to him. However the example of a square box removes all complexities involved in coding a YV12 frame. I am trying to resize such a frame and find in a hopeless situation as it is becoming more and more approx. Can the YV12 be more lucidly demonstrated
20th February 2004, 07:04 | #91 | Link |
Simply me
@vcmohan
What sort of operation do you want an example of ? regards Simon
20th February 2004, 12:52 | #92 | Link | ||
Retired AviSynth Dev ;)
Re: Simple Sample
Regards, sh0dan // VoxPod |
21st February 2004, 03:26 | #93 | Link | |
21st February 2004, 20:26 | #94 | Link | |
Simply me
The advantage of working in YV12 or YUY2 comes when you just want to manipulate Y values and therefore you don't have to translate from RGB to Y and back again. If your source is YV12 (e.g MPEG-2) or analog YUY2 capture then your filter can run a lot faster beacuse there are less bytes to process. Once you start doing manipulation like your's maybe the speed gains are totally offset by the complexity involved. regards Simon
25th February 2004, 12:38 | #97 | Link |
the dumbest
Could someone show me what's the way to copy YUY2 U and V planes from a source to a 2X destination frame.I lack the experience, can't find an example that works for my dead brain and I'm going nuts........................HeLp
25th February 2004, 20:26 | #98 | Link |
Simply me
You could have a look at my ShowPixelValues filter (which is basically a type of point resize filter)
the code where I translate YUY2 to YUV is here Code:
// Separate Y1 and Y2 values into their own 32bit "pixels" // i.e double 16 130 18 131 becomes 16 130 16 131 18 130 18 131 for (h=0;h < (src_height);h++) { for (w = ((src_width>>6)<<2)-4;w>=0;w-=4) { *(dstp + (w*2) + 7 + (h * dst_pitch)) = *(dstp +w + 3 + (h * dst_pitch)); *(dstp + (w*2) + 6 + (h * dst_pitch)) = *(dstp +(w+2) + (h * dst_pitch)); *(dstp + (w*2) + 5 + (h * dst_pitch)) = *(dstp +w + 1 + (h * dst_pitch)); *(dstp + (w*2) + 4 + (h * dst_pitch)) = *(dstp +(w+2) + (h * dst_pitch)); *(dstp + (w*2) + 3 + (h * dst_pitch)) = *(dstp +w + 3 + (h * dst_pitch)); *(dstp + (w*2) + 2 + (h * dst_pitch)) = *(dstp +w + (h * dst_pitch)); *(dstp + (w*2) + 1 + (h * dst_pitch)) = *(dstp +w + 1 + (h * dst_pitch)); *(dstp + (w*2) + (h * dst_pitch)) = *(dstp + w + (h * dst_pitch)); } } Simon
http://www.geocities.com/siwalters_uk/fnews.html Last edited by Si; 26th February 2004 at 08:40. |
26th February 2004, 08:49 | #100 | Link |
Simply me
>> is the binary shift right operator and << the left one.
So x<<1 == x=x*2 and x>>1 == x=x div 2. and x<<2 == x=x*4 and x>>2 == x=x div 4 etc. therefore x>>6 == x=x div 64. regards Simon
