4th February 2004, 21:00 | #21 | Link |
Life's clearer in 4K UHD
Just as a side question....
Can somebody explain to me why it is that all these kinds of tools display different bitrate sizes for the same encode? Cheers
4th February 2004, 21:52 | #23 | Link | |
4th February 2004, 22:40 | #24 | Link |
Yep,
I have to admit this has always been a bit of an annoyance for me. Okay I understand that many encodes are now 2pass VBR but I would have thought that once the audio stream bitrate (in kbps) has been identified (and deducted from the overall file size), calculating the 'average' video stream bitrate should be quite straight forward! I guess things would become more difficult if both the video and audio streams are variable. As maybe the only way to accurately determine the average bitrate of the entire file would be to de-mux the streams out of their container. And calculate the average bitrate of each stream against each streams file size! But I'm no programmer or software designer. Just an end user! Cheers
4th February 2004, 23:18 | #26 | Link | |
As I finished writing my previous post I realized that I had not taken the encodes 'overhead' into consideration! Maybe we could do with a tool to measure this as well Cheers
4th February 2004, 23:51 | #28 | Link |
Yep it must be difficult,
By running a 'video only' file that I encoded at 627kbps, through various 'info' tools, the following results came up: - AVIcheck = 652kbps Gspot = 654kbps MediaInfo = 657kbps Video ToolBox = 657kbps May I ask. Will it be your intension to add the capability to analyse 'audio only' streams, such as Mp3, AAC, AC3, DTS, WAV (in mono, 2Ch, 6Ch)? Cheers
5th February 2004, 00:22 | #30 | Link | |
Just a thought! Cheers
8th February 2004, 20:53 | #34 | Link |
VideoToolbox has just been updated to v0.8.0.35
Web Site : http://www.katarncorp.com/?vtb Change log : Code:
---------------------------- VTB v0.8.0.35 [08/02/2004] ---------------------------- + QuickTime Support + Indonesian language file + [MPEG] : Added support for "mpe" file extension @ [CodecDB] : More explicit AAC codec names for Matroska @ [MPEG] : Format detection # [MPEG] : Duration detection on small files # [MKV] : Resolution detection |
8th February 2004, 21:27 | #35 | Link |
It works great...
...Having said that I do have some thoughts! When identifying AAC streams with SBR 'Spectral Band Replacement' it would probably be less confusing to identify them as being "AAC HE (High Efficiency)" instead of using the term "AAC Low Complexity with Spectral Band Replacement" Great to see Quickime file identification. Cheers
15th February 2004, 23:37 | #37 | Link |
New version !
---------------------------- VTB v0.8.1.36 [15/02/2004] ---------------------------- + Danish language file + Dutch language file @ Install Script @ Codec database # [AVI] Codec (FourCC) detection |
15th April 2004, 11:30 | #39 | Link |
New version : http://www.kcsoftwares.com/?vtb
15th April 2004, 11:38 | #40 | Link | |
I see that this is v0.9.0.39. In what way is it different fron the previous version? Cheers
