26th April 2005, 11:18 | #81 | Link |
i have a problem the filter working.
whenever i use FFT3DGPU() in avs, avisynth gives me unrecognized exception error and crashes vdub(or vdubmod) with a memory reference error (....xxxxxxx can not be read"). i'm using P4 2.8e Win2k3 Ent. ATI 9500Pro(firmhacked to 9700) Catalyst 0.48 (Aug, 2004) firm patch can cause the problem? i tried to install the driver both with original (recognized as 9700) and edited (forced to 9500Pro) ini settings but got the same error. btw i have no problem with fft3dfilter or catalyst for other uses. |
26th April 2005, 12:30 | #83 | Link |
XviD User
@tsp
I'm actually using a FX5200 card unfortunately which gave me about 6-8fps. 60% of the CPU usage was kernel and the other 20% green. I suspect the high kernel usage could explain the mouse cursor sluggishness? I'll be trying my other box with a Radeon 9700 Pro in the next 48hrs to see how it compares. Thanks again!
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
26th April 2005, 14:28 | #84 | Link |
MacAddict: I also get shuttering when the framerate drops below 8 fps on my geforce 6800GT (although I have to use this setting to get is so low: fft3dGPU(mode=1, bt=3, sigma=10,usefloat16=false) )
the shuttering is reduced when decreasing the number of commands the GPU process at once but the speed is reduced by ~50%. I don't know if I should at it as an option(it could be cool if it only was enabled when the mouse was used. I just have to find a way to detect that) |
30th April 2005, 11:27 | #86 | Link | |
1st May 2005, 16:44 | #87 | Link |
FrEEwilL: Could you try this version. It will generate a text file called FFT3dGPU_log.txt in c:\. If you could post the content of this file I could see where it craches.
MacAddict: Any luck with the Radeon 9700 Pro? |
3rd May 2005, 12:02 | #88 | Link |
@tsp, i've tried test version and got the following,
when loading from the default avisynth plugin dir, w/ or w/o LoadPlugin() Code:
AvisynthPluginInit2 Code:
AvisynthPluginInit2 Create_fft3dGPU FFT3dGPU Constructor |
3rd May 2005, 12:58 | #89 | Link |
FrEEwilL: thanks I have created a new test version that will generate a more detailed report. You can get it here.
If you could post the new log when loaded from the default avisynth plugin dir and from an external dir. |
6th May 2005, 12:44 | #90 | Link |
@tsp, here is a log ('ext_log') when loading from the external dir.
when loading from the default dir, two logs are created. one is in plugin dir and the other is in the root of c: the former contains the first 2 lines of the following and the latter is same as 'ext_log' except for the numbers in memory address. Code:
AvisynthPluginInit2: AvisynthPluginInit2 Addfunction done CREATE_fft3dGPU FFT3dGPU constructor address: 1c84ee8 imgp: 0 hr: 1 GetDevice pDevice :0 RegisterClassEx create window Creating D3D d3dpp: 12c2ec ZeroMemory Setup d3dpp Creating D3Ddevice... |
6th May 2005, 18:56 | #91 | Link |
FrEEwilL: ok I have a new test version ready here. It it will again produce a logfile in c:\ so if you could repeat the procidure and post the logfile and include the the adress that couldn't be read. You could also try to set NVPerf=true.
Another thing that could be wrong if you are using windows 2003 server is that directx acceleration is disabled as default. I don't know if you have enabled it or having problem with other non-fullscreen directx accellerated applications/games, also you need directx 9.0 (I think directx8.1 is the default installed). I don't know if you also have windows xp/2000/98 installed and could try it in these OS's instead. |
6th May 2005, 19:47 | #92 | Link | |
XviD User
mpeg2source("D:\DIvX RIPs\Test Clips\xxxx\xxxx.d2v",idct=6) crop(4,64,712,352) fft3dGPU(bt=1) LanczosResize(672,272) Undot() Limiter()
6th May 2005, 20:21 | #93 | Link | |
XviD User
Anyone with advice yet on clean DVD movie sources?
7th May 2005, 19:41 | #94 | Link |
I am using fft3dGPU 0.42 and can't help getting the following error;
"Only pixelshader 2.0 or greater is supported." Well I have an Nvidia Geforce2 Ti 64MB card. Could it be that this is an old card and that fft3dGPU doesn't work with old cards? At least fft3d.dll works with my card, but that is sooooo slow |
7th May 2005, 23:25 | #95 | Link |
dragonfly: Yes a geforce 2 is to old. You will need at least a geforce fx 5200 or a Radeon 9500 that is a card with full support for DirectX 9 not just compatible with directx 9 but thanks for testing the supported pixelshader code
The following cards will not work: Nvidia: TNT TNT2 Geforce 256 GeForce2 Ultra, Ti, Pro,MX,Go and GTS Geforce3 Ti 200, Ti 500 GeForce4 Ti, MX, Go Ati: Radeon 7xxx Radeon 8xxx Radeon 92xx Matrox: G2xx G4xx G5xx maybe Parhelia The following should work: Nvida Geforce FX 5xxx Geforce 6xxx Ati: Radeon 9500 Radeon 9550 Radeon 9600 Radeon 9700 Radeon 9800 Radeon Xxxx where x means any digit. MacAddict: When testing the speed of the different setting remember to encode to Xvid while doing it. There are a bigger difference in speed between the various setting when using a less cpu demanding codec(like Huffyuy) or no codec compaired to Xvid and other demanding codecs. |
7th May 2005, 23:45 | #97 | Link |
@tsp
Thanks for the quick and detailed reply. I guess I have to purchase a new card @LordIntruder I almost never play games on my pc, so I don't know much about DirectX and the support for it on my card. So when the error came I did some research and found out that pixel shaders are used in DirectX. But wasn't sure if my card supported the right DirectX in hardware. Thanks for your reply. Slowly I get to know the world of Doom9! |
8th May 2005, 00:19 | #98 | Link |
AviSynth plugger
Tsp,
Some time ago I read some Dr. Kokaram articles where he describe FFT processing with old good Geforce2 GPU (with NVidia SDK - may be too complex for programming?).
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
8th May 2005, 23:38 | #99 | Link |
Fizick: I don't think it will be easy to make a version working on directx 7.0 hardware(geforce2/radeon 7xxx) because it doesn't have programmable shaders so it's only posible to add or subtract textures also it doesn't support floating point math (this is first includes in directx 9) only 8 (maybe 16) bit precision integers. It is posible to do integer fft but I don't know how fast it would be on directx 8 hardware.
Another thing if you would like to know how to do convolution in the frequency domain take a look at the varialble blur source code. |
9th May 2005, 13:27 | #100 | Link | |||
AvisynthPluginInit2: AvisynthPluginInit2 Addfunction done CREATE_fft3dGPU FFT3dGPU constructor address: 1c94ee8 imgp: 0 hr: 1 GetDevice pDevice :0 RegisterClassEx create window Creating D3D depending on what program is used to load the script (vdub,vdubmod, mpc, zp, wmp...) i don't get memory reference error box any more. vdub just crashes(disappear) silently _when i switch application focus_. only mpc gave one _when i'm closing_ (it works if i just keep it open) Code:
The instruction at "0x01fb1177" referenced memory at "0x0229a6c8". The memory could not be "read". Quote:
everything has been set properly and dx 9.0b is installed. to re-verify, i ran dxdiag and all of d3d/ddraw tests passed successfully. Quote:
because currently i'm using a soft-raid mirror set (along with hardware stripe sets), which is supported only on the server family. |
