29th August 2017, 16:48 | #21 | Link | |
https://forum.doom9.org/showpost.php...3&postcount=18 Morphdupes_MI https://forum.doom9.org/showpost.php...7&postcount=20 https://forum.doom9.org/showpost.php...7&postcount=21 (split script) Filldrops3 https://forum.doom9.org/showpost.php...92&postcount=1 Filldrops3 could very easily and effectively be incorporated . It would also have little impact on performance seeing as the mvanalyse has already been done. Last edited by burfadel; 29th August 2017 at 16:57. |
31st August 2017, 22:18 | #23 | Link |
Soul Architect
I haven't looked into it further. If I want to use MFlowInter, then I can't simply call FrameRateConverter and benefit from its features.
I'll also looking into increasing SkipOver from 120 to something like 210. Highly animated scenes get skipped and it breaks the smoothness. Also using DCT=4 for MRecalculate is a good idea.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 31st August 2017 at 22:59. |
31st August 2017, 22:50 | #24 | Link |
Animated sources are difficult, ideally you need to incorporate using MCompensate, or MFlow and then use correction masks. MFlow does a great job most of the time, and makes up for it by adding it's own special effects at scene changes. Then you need the scene detection function... The good thing about using any of that is it can be used for normal scenes as well. Use normal clip for MAnalyse, use that for compensation, then use a super of that for MRecalculate. Or a variation on that principle.
1st September 2017, 09:59 | #25 | Link |
From the latest changelog in mvTools2:
Fix: [DCT 8x8@8bit] safe multithreading for integer DCT (8x8 block size, 8 bit video): assembly had a single working buffer. Does this fix the MT problems? If I got it correctly, your block size recommendations are for 4:3. What blocksize would you chose for 1080p? |
1st September 2017, 13:59 | #26 | Link | ||
Soul Architect
As per documentation, default block sizes are, based on height 0-359: 8 360-749: 12 750-1199: 16 1200-1699: 24 1600-2160: 32 |
2nd September 2017, 04:26 | #27 | Link |
Soul Architect
Version 1.1 is released!
What's new: - Added InterpolateDoubles function to replace double frames with interpolated frames using FrameRateConverter - Added DctRe parameter to specify DCT for MRecalculate - DCT now also applied for MRecalculate by default - Preset Normal now uses DCT=4 for MRecalculate. Old Normal is now Fast and old Fast is now Faster. - Presets Slow and Slower also now use DCT=4 for MRecalculate - SkipOver default treshold increased from 120 to 210 - BlendOver default treshold increased from 60 to 65 - SkipOver now specified for thSCD2 of MMask. Previously, scene changes would cause 2 adjacent frames to be skipped. Specifying thSCD2 causes only 1 frame to be marked for scene change. - Updated Avisynth headers in DLL - StripeMask: renamed trh parameter to thr I also just did some tests with Stripes="Skip" and it's not practical for real videos, it often gives very weird results. I might remove it in next version. I'm also open to feedback to improve InterpolateDoubles.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 2nd September 2017 at 05:01. |
2nd September 2017, 05:50 | #28 | Link |
Soul Architect
There is one issue with using DCT=4 for MRecalculate: it causes masks to be MUCH weaker, and thus pretty much disables artifact masking!
Would MFlowBlur be useful in that script? Would it be possible to use MFlowBlur instead of frame blending for artifact masking?
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 2nd September 2017 at 05:58. |
2nd September 2017, 06:33 | #29 | Link |
It's possible, I was thinking that myself for mClean. For video temporal quality is much more important than single frame comparisons, particularly those where people have to zoom in or look hard to determine the difference. If there is fast motion it should be perceptively better. With motion analysis derived results, like an arm moving fast you get that opaque overlay look which is particularly noticeable in animation. MFlowBlur may make this area 'heavier' which wouldn't be good as it will make the arm look unnaturally fat momentarily. If you can detect that there is motion opaqueness caused by MFlowFPS, you can mask this and return the good detail from the previous or next frame. This will likely make the arm appear thinner. If you then apply MFlowBlur, you should get a smooth, and perceptively be motion artifact free assuming the source was free of this.
I'd say it would be difficult to implement! The temporal quality should be much higher though, and spatial comparisons should be more favourable as well. |
2nd September 2017, 10:10 | #31 | Link |
I believe it recreates existing frames based on the motion vector data of previous and next frames provided by MAnalyse. I was just thinking that if you ran MFlowBlur or Mcompensate before MflowFPS, and work out the clip stuff (super,superfilt) based on this, it could produce good results? I think it all comes down to experimenting with the functions.
2nd September 2017, 17:41 | #32 | Link | |
Soul Architect
I asked Chainik about it
I also tried it. Takes the source clip and kind of blurs/distorts it. It's not generating any in-between frames. Useless.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 2nd September 2017 at 20:50. |
2nd September 2017, 18:06 | #33 | Link |
Soul Architect
OK after testing the mask of MRecalculate with DCT=4, overall, MAnalyze gives a much weaker mask with DCT=4 than with DCT=0. DCT=4 and DCT=1 give the same mask. If you do MAnalyze with DCT=0 and MRecalculate with DCT=4, you get the same mask as if MAnalyze was done with DCT=4.
Thus, with the latest release, presets Slow/Slower that were already using DCT=4 will behave similarly but with slightly better quality. Preset Normal will have much lower artifact masking because of MRecalculate. For artifact masking, perhaps some adjustment could be made to take this mask strength discrepancy into consideration. This however can cause issues for scene change detection if masks are too weak. In terms of mask strength discrepancy, here's what I'm talking about MAnalyze DCT 0, 1, 2, 3, 4 MAnalyze+MRecalculate DCT 0, 1, 2, 3, 4
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 2nd September 2017 at 20:28. |
2nd September 2017, 21:32 | #34 | Link |
MysteryX,
I was experimenting with frame interpolation on some animation today and noticed FrameRateConverter (both versions 1.0 and 1.1) tends to lose the plot during fade-outs. I haven't fiddled with settings too much yet so I don't know if there's an adjustment that'd fix it, although it seems to be the sort of thing that probably shouldn't happen by default. There's three MKVs in the zip file I've linked to if you'd care to look. "12fps.mkv" is simply a section of the original DVD cropped and resized and decimated to 12fps. It's for reference. "FrameRateConverter.mkv" is the result of adding FrameRateConverter(24,1) to the script after resizing, and "Interframe.mkv" is the result of adding Interframe(cores=1, NewNum=24, NewDen=1). FrameRateConverter seems to do a better job than Interframe aside from the fade-outs. If you look at the grey area near the middle of the picture a bit after frame 120 and step through the frames one at a time as it fades out, you'll see the shadow over the grey area appears to move up and down. A similar thing happens a little later as the girl fades out and the shot of the earth behind her distorts a little in the direction it's moving. It appears FrameRateConverter might be mistaking the fading-out for movement. Cheers. 12fps-24fps.zip (3.3MB) Edit: For the record I tried manolito's earlier version of the script here and the fade-out problem was far worse. I must have saved StainlessS's DoubleRate script at some stage so I tried it and the effect was reduced, although still present. Thanks. Last edited by hello_hello; 2nd September 2017 at 21:56. |
3rd September 2017, 00:44 | #35 | Link |
Soul Architect
I've now adjusted the masks to look similar with different DCT values. Still need to do some testing.
hello_hello, for anime, use Preset="slow". With DCT=4, the fade out is good. There's a bit of a warping effect at 239-242. When the lady fades out, the mask is too weak to skip that, but on fade in, I get a Skip value of 46. Set BlendOver=40. I think it's a good idea to set BlendOver to a lower value for anime. Perhaps I could add a preset "Anime" that changes BlendOver/SkipOver values, but that would require more testing. I'll release this version with re-adjustments to the masks and we'll see from there what settings need to be tweaked for anime. Also, if you double the frame rate, use FrameDouble=true instead of NewNum to preserve source frames. I'm editing the script to set FrameDouble to true if NewNum is double the frame rate. |
3rd September 2017, 03:46 | #36 | Link |
Soul Architect
Version 1.2 is ready!
What's new: - Mask strength now adjusted to produce similar artifacts masking with different DCT values - Removed Stripes parameter as Skip isn't practical - Added Stp parameter, whether to detect and blend stripes - Changed MaskTrh default from 100 to 120 - Changed BlendOver default from 65 to 70 - If NewNum is twice the clip's frame rate, set FrameDouble to true by default to preserve source frames You can test preset="anime" to see which settings work best. This new preset hasn't yet been tested and is likely to be tweaked. |
3rd September 2017, 07:46 | #37 | Link | |
I did a few tests, and for me the clip looks best with a block size of 32 (happens often with anime). DCT=1 did not make much difference, though. Using blksize=32 fixes the fluttering grey shadow completely, but when the planet enters the window, the first couple of frames have distorted movement. I think that this is far less visible than the grey shadow, it only can be detected by stepping through the frames. Cheers manolito |
3rd September 2017, 16:50 | #38 | Link | |
3rd September 2017, 17:41 | #39 | Link |
Thanks for the info MysteryX and manolito.
I haven't had a chance to play around more yet. Probably not until tomorrow, but I was wondering..... I didn't give any thought to it at the time, but would frame interpolation work better at higher resolutions? I resized first, thinking it'd be faster: TDecimate(mode=2, rate=12, Input="D:\ep1.txt") crop(14, 4, -14, -4) Spline36Resize(704,396) FrameRateConverter(24,1) I'll use FrameDouble=true next time, but would it make much difference if I put FrameRateConverter before the cropping and resizing? It's a PAL DVD so there's 720x576 resolution to begin with, even if there's not 720x576 worth of picture detail as such. Cheers. |
3rd September 2017, 18:55 | #40 | Link | |||
Soul Architect
I've just re-encoded a very difficult and animated video with this version. Quality is considerably improved. Output file size is also considerably different: 209mb instead of 205mb. |
