2nd December 2014, 20:22 | #1641 | Link | |
2nd December 2014, 20:48 | #1643 | Link | |
If chapters already exist, then chapters are made from the chapter data within the MKV/MP4. I'm not meaning making chapters FOR the movie..I'm meaning make chapters for Chapters Menu. A generic menu.
2nd December 2014, 20:55 | #1644 | Link | |
If I decided to do a PRO version, one of the things I'd considered was a lot of extended authoring capability. You know, a way to edit/customize menus, etc. -- that might be something I could consider there. Last edited by jdobbs; 2nd December 2014 at 21:00. |
2nd December 2014, 21:04 | #1645 | Link |
It was clear to me ( ), but...I can, upon reading it from less distraction...2nd is more so. It's cool. If you're willing...only a hope. Otherwise, the program has surpassed all of my past expectations.
18th December 2014, 03:57 | #1647 | Link |
It's been previously requested by me (and IIRC seconded), the ability to right-click a VID and like "Blank this item", select "Do not reencode this item".
I like to do this with discs where the movie fits fine untouched on a BD25 with a few GB left over that I can compress the menus and bonus features into. (I remember doing this often with DVD Shrink back in the day). Since it currently isn't possible (and I don't think on the 'To Do List'), I have on occasionally manually created this sort of disc by generating 2 discs, one with the untouched feature, and one re-encoded using a custom disc size then manually putting the two discs together. The only drawback is that any custom size less than a BD25 has its max bitrate capped at 15mbps (AVCHD spec), even if strict isn't used. That's a shame since I copy it into a BD25 disc later. Is there currently a way (hidden feature or something) to have BD-RB use full BD specs for discs under BD25 or at least when using a custom output size? |
18th December 2014, 17:23 | #1648 | Link |
@Jdobbs:
- Would it be possible to add a menu entry under "Help" or something to open the log? Kind of like IMGBurn can, but open it directly in the associated program. IMGburn just opens the folder. That way if the user wants to open the log, (s)he doesn't have to go dig to the working folder to find it. It can be accessed from within bdrb - Would it be possible to add a menu entry under "Help" or something to erase the saved log - Would it be possible to add erasing functionality to the "log" tab; reason for this is that i often run multiple encodes after another (but don't always use the batch), so after 1 job finishes i manually navigate to the 2nd one, do what needs to be done (blanking wise) then launch it. However, then the log tab still shows the previous encode info. Personally, i'd rather only have the log tab show the log for the current encode. So it sort of starts with a "fresh" tab every job. Oh and something i've been wondering lately. Whats the difference between having "verbose status reporting" enabled and disabled? |
18th December 2014, 17:30 | #1649 | Link | |
19th December 2014, 00:52 | #1653 | Link | |
But then what is the purpose of 'Custom Target Size'? Each disc size can already be adjusted manually by the hidden BDXX_Size=. I would think Custom Size would function in a manner that BD specs are applied unless 'Strict AVCHD' is enabled and then AVCHD limits engaged. Of course the problem there is Strict AVCHD applies to movie-only rebuilds. I don't know how useful a hidden option like CUSTOMTARGET_MAXBITRATE=n would be to other people. Mind you I was only asking because I thought there might already be such an option. Of course, I only really just need the ability to not re-encode specific VIDs. So that would have my preference for an added feature. Edit: @Sharc - Even at lower average bitrates, the ability to peak higher can still improve quality. I think practicality doesn't enter into it, just AVCHD specs. Last edited by DoctorM; 19th December 2014 at 00:56. |
19th December 2014, 01:55 | #1654 | Link |
I don't agree at all.
Custom Target Size has any of a few thousand possible uses. The hidden options you mention are for advanced users, and are hidden for a reason. They aren't meant to be changed except when someone wants to "stretch" or "limit" the target a little. Strict AVCHD is meant for a specific group of players that have limitations in the file structure they will accept. It just makes sense that when someone creates a disc to fit on something smaller than 8.5GB -- you can assume it is BD-5/9 since there is no BD-R smaller than BD-25. Last edited by jdobbs; 19th December 2014 at 02:58. |
19th December 2014, 05:56 | #1655 | Link |
Please forgive Jdobbs, but that's not entirely accurate. There are mini BD-R 7.5GB discs. Those would fall under an interesting set of circumstances(Their disc speed would handle higher bitrates). But those are rather expensive. Who would backup movies to HD cam Discs? Frankly, most my backups end up on hard drives. Only my more precious backups end up on reliable BD-R.
19th December 2014, 17:02 | #1656 | Link | |
20th December 2014, 00:27 | #1658 | Link | |
I hesitate though... the majority of people who create self-inflicted problems don't understand enough to know that it is self-inflicted. But they think they do (Toilet-Duck comes to mind). They just tell their friends and post in forums that BD-RB creates a disc that skips, freezes, and has problems. They always seem to leave out the "I set a hidden option that caused it" part. Last edited by jdobbs; 20th December 2014 at 00:32. |
20th December 2014, 06:28 | #1659 | Link | |
