25th December 2016, 18:30 | #2321 | Link |
Professional Code Monkey
So what do people want me to support? For the first time ever it's now kinda possible for me to support both 3.5.x and 3.6.x but I'll have to compile twice as many modules and modify the installer a bit.
Opinions? Obviously only officially supporting the latest Python is generally the least amount of effort.
26th December 2016, 18:07 | #2325 | Link |
Run "avfs.exe scriptname.vpy". It can be found in the directory where VapourSynth was installed.
3rd January 2017, 16:13 | #2326 | Link |
I'm Siri
how to make a global plugin initializing list for all functions in your module:
class get_core: def __init__(self): self.core = vs.get_core() self.xxx = self.core.xxx.xxx self.yyy = self.core.yyy.yyy def f1(src): core = get_core() clip = core.xxx(src) del core return clip def f2(src): core = get_core() clip = core.yyy(src) clip = core.xxx(clip) del core return clip Last edited by feisty2; 3rd January 2017 at 16:16. |
4th January 2017, 21:36 | #2327 | Link |
Here's a test build with python 3.6 support. There are no other notable changes. Should work, I guess.
5th January 2017, 20:57 | #2328 | Link |
would be nice if SubText would also support .srt subtitles (https://github.com/HomeOfVapourSynth...on/VSFilterMod seems to be Windows only),...
6th January 2017, 18:51 | #2329 | Link | |
unsigned int
Buy me a "coffee" and/or hire me to write code! |
7th January 2017, 06:21 | #2332 | Link |
Vapoursynth Core Library Error
Hi...I installed Python 3.6.0 and it is working fine.
However when I try to install "VapourSynth-R35" it shows an error... "At least one version of the core library has to be installed"... I am newbie to python... Pl. guide how to install core library. Thanks |
7th January 2017, 17:20 | #2335 | Link |
R36 test2
Changes: Code:
r36: added misc filters to included vapoursynth plugins fixed several edge cases when specifying color values for blankclip and addborders, inf and nan are now always rejected and floating point values can be any finite value vspipe will now properly report floating point formats in y4m instead of incorrectly making them look like integer, for example C420ps and C420ph will be used to mark single and half precision respectively avfs will now reject scripts that don't have an avs or vpy extension to avoid pointless error mounts fixed blankclip handling of color for compat formats added sample type to vspipe info output improved a few installer error messages when python can't be found now uses python 3.6 in windows fixed potential crash when two clips are added together (Kamekameha)
11th January 2017, 05:18 | #2336 | Link |
Pig on the wing
Does there exist a filter (64-bit) for tackling a weird telecine pattern?
I have some material which seems to have a pattern "pppccpppccpppccpppccpppccppppcc" where p is a non-combed frame and c is a combed frame. VIVTC cannot tackle this one because the pattern is not constant enough.
11th January 2017, 08:26 | #2337 | Link |
At least it seems to be regular... usually it's advisable to count the number of equivalent fields to name the pattern, and to look at them as a Bob() result to identify blends. And I would suspect blends for your case, it sounds like blended PAL speed-up rather than Telecine.
Maybe you can provide a short prominent sample? |
11th January 2017, 08:40 | #2338 | Link |
Pig on the wing
I didn't check very thoroughly, at first I thought the material just needed a regular IVTC and then noticed the odd jumps when there's the 4:2 pattern. DGIndexNV shows NTSC and no percentage for FILM so it's hard telecined. It would probably look really ugly when played back on a DVD player..
I'll get you a sample later today when I get back from work.
11th January 2017, 17:08 | #2340 | Link |
Pig on the wing
Here's a testclip.
https://drive.google.com/open?id=0Bz...3VVaUt3YlZjQTg I probably need to do the TFM and TDecimate magic in Avisynth, save to a lossless AVI and do the rest in Vapoursynth with that clip. Tough job, but possible to automate.
