9th August 2021, 06:54 | #4321 | Link |
I had the following issue when I was trying to build a plugin in Linux.
My plugin relied on an external library, libcolord, to search for a certain variable. Connection to libcolord was made by creating a reference to a singleton maintained by libcolord. In VS Editor where plugins are unloaded between preview attempts, the second time of creating the reference could always trigger an error "GLib-GObject-WARNING **: cannot register existing type ". I ended up moving the reference outside the plugin and built it as a standalone shared library, loaded with dlopen in my plugin without ever calling dlclose, and the problem seems to be solved. May I know if it's a feature of VS? From what I understand, when the plugin is unloaded, nothing from the scope could survive. |
10th August 2021, 04:26 | #4322 | Link |
so, i followed the posted link by l33tmeatwad. thanks so much for that! i'd been looking for detailed instructions for quite some time and those were very thorough. very helpful!
there were quite a few warnings that came up when i was copy/pasting commands but i figured they were, hopefully, non-critical. other than that there were only a couple of issues. first, this is the series of commands i followed for vapoursynth itself: Code:
cd $HOME/.installs git clone https://github.com/vapoursynth/vapoursynth.git cd $HOME/.installs/vapoursynth git checkout R54 ./autogen.sh ./configure make make install sudo make install sudo ldconfig the only other thing was this: Code:
sudo cp hasvsfunc/havsfunc.py /usr/local/lib/python3.*/dist-packages/ Code:
sudo cp havsfunc/havsfunc.py /usr/local/lib/python3.*/dist-packages/ i am having one issue, i think. i haven't gotten far enough to know anything about what i'm doing but i get this error at the bottom of VSEdit: Code:
Failed to initialize VapourSynth environment! thanks again for that guide. it was really helpful! babag |
10th August 2021, 04:35 | #4323 | Link |
Did you remove the site-packages folder before trying to make a symbolic link? Debian based Linux python installs use dist-packages and not site-packages, so if the directory was created before and not deleted stuff like VapourSynth will install there and thus not be loaded. If the actual directory exists simply copy all those files over and delete the site-packages folder then use the instructions to create a symbolic link to redirect anything trying to look or copy to that folder.
10th August 2021, 05:09 | #4324 | Link |
thanks for the quick reply, l33tmeatwad! i confess, though, that i don't know what any of the response means. i'd need more detail to be able to follow. i can sort of get the gist but not enough to be able to act on it. fwiw, i followed the instructions in your link very literally.
thanks again, babag |
10th August 2021, 13:29 | #4325 | Link |
So basically where you installed it before the VapourSynth install created /usr/local/lib/python3.*/site-packages, one of the errors you probably got was trying to create the symbolic link in step two because the folder exists already. A symbolic link is a kind of shortcut that points to something else. What you need to do is move everything inside of site-packages into dist-packages, delete the site-packages folder, then use these commands to point site-packages to dist-packages:
cd /usr/local/lib/python3.* sudo ln -s dist-packages site-packages |
10th August 2021, 19:09 | #4326 | Link |
hey! that's awesome! thanks. the error is gone. now on to being confused by other things.
i copied something from someplace, possibly your site, and am getting a new error in vsedit. here's the code i have: Code:
from vapoursynth import core video = core.lsmas.LWLibavSource(r'/home/babag/Documents/Projects/Buddies_97/2377.mov').text.ClipInfo() video.set_output() Code:
Failed to evaluate the script: Python exception: No attribute with the name lsmas exists. Did you mistype a plugin namespace? Traceback (most recent call last): File "src/cython/vapoursynth.pyx", line 2242, in vapoursynth.vpy_evaluateScript File "src/cython/vapoursynth.pyx", line 2243, in vapoursynth.vpy_evaluateScript File "/home/babag/Documents/Projects/Buddies_97/VS_Test-01.vpy", line 3, in video = core.lsmas.LWLibavSource(r'/home/babag/Documents/Projects/Buddies_97/2377.mov').text.ClipInfo() File "src/cython/vapoursynth.pyx", line 1891, in vapoursynth._CoreProxy.__getattr__ File "src/cython/vapoursynth.pyx", line 1754, in vapoursynth.Core.__getattr__ AttributeError: No attribute with the name lsmas exists. Did you mistype a plugin namespace? babag |
11th August 2021, 00:33 | #4327 | Link |
Assuming you compiled the plugin, did you move it to the /usr/local/lib folder to /usr/local/lib/vapoursynth? Almost all plugins will install to the regular lib directory. If any don't work after moving you can always move it back and create a symbolic link instead.
11th August 2021, 04:48 | #4328 | Link |
i think this is the relevant set of commands that i followed:
cd $HOME/.installs git clone https://github.com/l-smash/l-smash.git cd l-smash ./configure --enable-shared make lib sudo make install-lib Code:
/usr/local/lib/liblsmash.a /usr/local/lib/liblsmash.so /usr/local/lib/liblsmash.so.2 thinking i should link the above three files into the /usr/local/lib/vapoursynth directory but will wait confirmation of that before i do something stoopid. thanks, babag Last edited by BabaG; 11th August 2021 at 05:04. |
11th August 2021, 05:28 | #4329 | Link |
No, that's just l-smash, the dependency for L-SMASH-Works so it's in the correct directory.
11th August 2021, 07:48 | #4330 | Link |
L-SMASH Works had new ver
https://github.com/AkarinVS/L-SMASH-Works |
11th August 2021, 15:08 | #4331 | Link | |
12th August 2021, 08:51 | #4333 | Link |
Most likely a false positive. You can upload and check the file on virustotal.com
Btw R54 is the latest stable version.
12th August 2021, 12:36 | #4335 | Link |
Professional Code Monkey
False positives all the way. All shitty antivirus software detects standard installers as viruses. Uninstall whatever shitty antivirus trial your new laptop came with and use the built in microsoft defender which doesn't make this kind of mistake.
12th August 2021, 12:41 | #4336 | Link |
It appears there are some false positives on Virus Total, someone should probably follow-up with whatever's detecting it to have it removed. Weirdly, the second result only shows up for the 64-bit installer.
SecureAge APEX - Malicious Qihoo-360 - Win32/Heur.Generic.HyoDv9kA |
12th August 2021, 12:44 | #4337 | Link |
While in microsoft edge I did not have an option except to report it is safe, in Chrome it downloaded. On execution microsoft defender gave a no go banner but a path to bypass it was there. So I could execute it. I am having MCaffe anti virus also pre loaded. I think it may be superfluous.
12th August 2021, 15:40 | #4338 | Link | |
Pig on the wing
12th August 2021, 18:55 | #4339 | Link | |
thanks, babag |
