Old 19th November 2018, 22:51   #6521  |  Link
Zathor
Ah, ok. It should not harm at all if the input filter is returning a 8 bit video.
Old 20th November 2018, 08:26   #6522  |  Link
@Betsy25:
It has always been recommended not to install MeGUI inside of a directory which is guarded by the UAC, it won't have permissions to write files there. The legacy of pre-Vista development.
Old 23rd November 2018, 03:04   #6523  |  Link
doomleox999
Why MeGUI x64 keeps asking me to update AviSynth plugins even though they are up to date?
I'm also having this problem:
The only workaround I found is to add "ConvertBits(16)" to the end of the script.
doomleox999 is offline   Reply With Quote
Old 23rd November 2018, 09:19   #6524  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
New bug with 2891 and AVISynth Script Creator. Now, even though I have "Nvidia Resizer" unchecked when using DGIndexNV, it is still doing a source resize in the script, along with the resize filter I asked for. Example:
LoadPlugin("C:\Program Files (x86)\MeGUI_x86\tools\dgindexnv\DGDecodeNV.dll")
DGSource("D:\Princess Bride old\Princess Bride.dgi",fieldop=0, resize_w=1120, resize_h=608)
#deinterlace
crop(2, 16, -2, -24)
Spline36Resize(1120,608) # Spline36 (Neutral)
LoadPlugin("C:\Program Files (x86)\MeGUI_x86\tools\avisynth_plugin\UnDot.dll")
Undot() # Minimal Noise
The bolded part should not be there with the Nvidia Resizer option unchecked. This behavior just started with 2891
Lyle_JP is offline   Reply With Quote
Old 24th November 2018, 14:59   #6525  |  Link
pommesmatte
I'm also seeing this. And I don't even use resize anywhere.
I crop in Avisynth and the resulting file has the correct playback aspect ratio BUT the wrong Pixel height.
Workaround for me this far is either removing the resize options manually from the script or do the cropping in DGIndexNV.
By the way: Why AVS Script Creator (optinally) doesn't put the cropping parameters in the DGSource statement? Wouldn't that be the far better procedure?
pommesmatte is offline   Reply With Quote
Old 24th November 2018, 16:09   #6526  |  Link
Zathor
Originally Posted by doomleox999 View Post
[B]Why MeGUI x64 keeps asking me to update AviSynth plugins even though they are up to date?
Thanks for the report. Could you please upload a full log (I do need the "Versions" part)? Also what happens if you update the plugins? Will it always come back? If yes, please upload your AutoUpdate.xml
Link to the bug report: https://sourceforge.net/p/megui/bugs/936/
EDIT: fixed (see bug report)
Also update to 2891 which should fix the color space issue.
Old 24th November 2018, 19:52   #6527  |  Link
Zathor
Currently working on that while fixing the resize bug. In my eyes this cannot be optional as the cropping must happen before the resize so it must be in the DGSource() call ==> if resize is enabled with DGSource, also the cropping has to happen there. Only issue is that for AVS cropping mod2 is fine while DGSource() does need mod4 so I have to increase to the next mod4 value = overcropping.
Old 24th November 2018, 22:10   #6528  |  Link
Zathor
2893 [OneClick]             fixed fatal error in some cases (regression of 2882). bug #937
2892 [AVS Script Creator]   added an option in the profile to use the DGIndexNV crop & resize filter if possible
                            if resize with DGIndexNV is enabled also cropping will be done that way (mod4 is forced for crop values)
                            fixed always applying the resize parameters to DGSource() (regression of 2891)
Old 24th November 2018, 23:55   #6529  |  Link
pommesmatte
Awesome! Works great thus far!
EDIT: There seems to be a bug left with the overcropping. The crop uses mod4 (134,138,142...), but if e.g. 138 top and bottom is chosen, in DGSource it becomes 140, but in the resulting video stream, there is a black border left on the bottom.
Maybe something to do with those 1088 height thing?
Old 25th November 2018, 00:15   #6530  |  Link
doomleox999
I'm using MeGUI x64. It doesn't let me update to 2891. Should I use MeGUI x86? Is there any difference perfomance wise? I have a 64 bits system so I thought I should use MeGUI x64 to, let's say, encode faster, is that the case?
After updating, the problem comes back the next day. Is this what you need?
Old 25th November 2018, 00:22   #6531  |  Link
pommesmatte
You have to switch the update server to "development".
x64 is faster on x64 systems.
Old 25th November 2018, 10:15   #6532  |  Link
Zathor
Switch to the development server (in Options\Settings\Extra Config).
I still do recommend the x86 version as not all filters are available as x64 versions. However if x64 works for you, then you can continue to use it.
That problem has been fixed already, but it will take up to 60 hours before your client gets the new config data from the update server. Also depending on what you do have there, one final update may be required.
Old 25th November 2018, 16:44   #6533  |  Link
doomleox999
Thanks for your answers. I did as you say and it works now. However, I have a problem with the development server update, some settings are different or they just disappeared:
Will this be fixed? Should I return to the stable servers? This development update will eventually be in the stable servers right?
Old 25th November 2018, 18:15   #6534  |  Link
Could you please avoid yelling? There is no need to write everything in bold.
Old 25th November 2018, 19:43   #6535  |  Link
Zathor
[B]Thanks for your answers. I did as you say and it works now. However, I have a problem with the development server update, some settings are different or they just disappeared:
I got tired of these questions where the settings have been gone to (let us have new ones...):
2894 [Main]                 moved menu items:
                            - "options\update" to "tools\update"
                            - "options\settings" to "options"
                            - "workers\settings" to "options"
                            - "workers\overview" to "view\worker overview"
And yes, this will be at some point also applied to the stable branch.
Old 25th November 2018, 19:46   #6536  |  Link
LeMoi
The problem is that you have to go to Doom9 forum and this topic to know about changelog before an update.
Maybe you should find a way to display changelog in the updater window, so that we know what has changed before we agree to the update?
LeMoi is offline   Reply With Quote
Old 25th November 2018, 19:49   #6537  |  Link
Zathor
To read the changelog after the update has been done should be sufficient (help\changelog).
Old 27th November 2018, 01:18   #6538  |  Link
doomleox999
I get that message whenever I load an mkv file to One Click Encoder and I have selected mp4 as output. Is there any way to disable that?
Old 27th November 2018, 16:49   #6539  |  Link
Glarioo
dgindexnv
Cannot use dgindexnv anymore after an update yesterday.
Old 27th November 2018, 18:37   #6540  |  Link
Zathor
Something must be in your MKV which cannot be muxed into a MP4 by MeGUI.
