#941 | Link | |
I agree that most codec packs are rubbish. However, I have found K-lite to be very good and I have never experienced any codec conflicts. I find it much less time consuming to get my required codecs through K-lite. Can I ask, why do you say K-lite mega codec pack is crap? What exactly gives it that status? If I can see a valid reason then I certainly will start to acquire my codecs individually. ![]() Last edited by Ryu77; 17th March 2008 at 06:06. |
#942 | Link |
н∂-ƒαиαтι¢
@ Atak
maybe a lil post to let us know there is an update for people who have subscribed to this thread. cheers! UPDATE: still no audio in Blu-ray format with the same sample from previous post ![]() Last edited by ~bT~; 17th March 2008 at 12:31. |
#943 | Link | |
#945 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th March 2008 at 14:30. |
#946 | Link | |
I dont care so should you
FFD should be the only *UPDATED* codec bundle used... and that can be installed from my installer for ripbot and autoMKV... www.stage-x.org here you can find the download links... Enjoy... If you wish to update the ffdshow codecs at anytime just go here http://ffdshow.info/ and download the clsid latest nightly build... (ie the latest build will have the highest build number in clsid genaric builds)... *Edit Ok now you can get the latest installer from my site...
My Installer's || Last edited by Ajax_Undone; 18th March 2008 at 01:10. |
#947 | Link |
@~bT~
Replace Audiorate(audio)<44100?ResampleAudio(audio,48000):audio with this audio=ResampleAudio(audio,48000) TSMuxer does not like AC3 encoded at 44100 Hz
#948 | Link |
@Atak_Snajpera
is it possible to split the ouputed 264/ac3 files by 4 gigs max ? the reason is this : I have a external HD that I want to use to transport the movie to the PS3.. but it's FAT32 (no choice, the PS3 doesn't read NTFS).. If I choose 1DVD as output.. it doesn't fit on the HD (limit 4 gigs) tsmuxer doesn't have the support to split files yet. |
#950 | Link |
I still don't see anything to warrant that the K-lite codec pack is rubbish except very opinionated ideas.
I have been using K-lite for about 6 years now and I have encoded to many formats including mpeg2, mpeg4 sp/asp (h263), AVC/h264, DTS, ac3, aac, mp3... etc. etc. SD/HD, upside down, flip it and reverse it... LOL! Never have I once experienced any problems or conflicts with my encoding applications. I am not claiming to be an expert as there are obviously a lot of people here that are quite switched on. However, I still have enough experience to validate my opinion here. I still can not understand why K-lite is considered crap. You can easily check or uncheck any codec configurations you like. There is also a full direct show control panel that allows you to select which codecs are enabled or disabled. So if any problems occur you can easily rectify this through some tweaking of these controls. The codecs installed are generally vfw or acm, so if you wish to use command line codecs like RipBot264 does then of course K-lite has no effect on that whatsoever. I am completely ready to listen and even accept your opinion. All that I ask for is some reasoning behind these statements. Would that be possible please? ![]() Last edited by Ryu77; 18th March 2008 at 05:32. |
#951 | Link | |
Ok reasoning ---> Un ---> Explained ---> Errors..... 1) The command line does use the codecs that are on the system to decode what ever is being encoded... 2) We can not identify problems you are having in the wares on your computer unless we subject our selves to the madness that is/are Codec packs... 3) K-lite and others configure the codecs in ways that leave much to be desired. (Example) Lets say you have lame for decoding your mp3 but you also have on that same system FFDshow and Fraunhofer or other doing the same. The mp3 because the person had the audacity to install a codec pack plays back choppy Why well to many codecs only one mp3... The same is true for video... 4) The idea behind FFDshow is that you will only need one codec (ie one codec fits all) FFD will decode most any format file you can ever imagine... And more every day... haali is the proverbial mascot of MKV/MP4 it complements FFDshow directly...
My Installer's || Last edited by Ajax_Undone; 18th March 2008 at 06:45. |
#952 | Link | |
"Load Plugin: unable to load "C:\Program Files\RipBot264\tools\AviSynth plugins\BassAudio\Bassaudio.dll" (C:\Users\Aj\AppData\Local\Temp\RipBot264temp\job1\getinfo.avs, line3) Any Idea ?? |
#953 | Link | ||||
It's all good. You obviously have your opinion and I'll have mine. Ajax, all your points are completely valid for somebody that doesn't know how to configure codecs correctly. See, the difference is that I don't use K-lite as a lazy way of configuring everything automatically. Instead I see it as an efficient way of obtaining most of the codecs I need as I am quite dedicated to my career and I simply don't have the time to download everything one by one. With some careful installation and configurations, I have found that there will be no confilcts occuring. I was looking for solutions not ways to exploit any weaknesses that RipBot264 may have had. Nothing is perfect. Note: My very first opening sentence thanked Atak for creating this software. I would really like to make amends here. If I can back track a little bit... The problem I had was not with Atak's opinion of K-lite, he is certainly entitled to that. It was the way he said it. He should have known that since I was the person that suggested K-lite that I would take offence. Who wouldn't to this?... "DO NOT INSTALL THIS SHIT!!!!! CODEC PACKS ARE FOR LAMERS AND NOOBS!". Now to answer your post... Quote:
I would much rather make friends here as I believe that we all have something to offer that someone else doesn't. Working together we can surely achieve more. My point was never to try to prove anyone wrong or inferior. I have better virtues than that. I was simply disappointed that Atak didn't consider his words before he spoke them. I guess I had higher expectations of him as I felt that he did a very good job of putting RipBot264 together. I thought a person of his intelligence would have a larger vocabulary to choose from. Since then I have realised that his English isn't 100%, so I find that I could easily put all this in the past. However, ever since I made my "K-lite" post, I seem to have been defending my reasons for using the K-lite mega codec pack, which was besides the point. My point seems to have been lost in a different argument now. I hope we can move past this and start focusing on ways to improve all this software which we all love and know so well. ![]() ![]() ![]() Last edited by Ryu77; 18th March 2008 at 08:41. |
#956 | Link |
Fighting spam with a fish
It's called interlacing, hombre. You have to de-interlace to get it back to "normal". There are billions of ways to do it, so for more info just look into the avisynth options.
FAQs:Bond's AVC/H.264 FAQ Site:Adubvideo Zsmooth - Cross-platform smoothing for Vapoursynth |
#957 | Link | |
I appreciate it. I usually have this problem with music show too. |
#958 | Link | |
Do you get 3 progressive (clear and smooth) frames followed by 2 interlaced frames (like the photo you posted)? If you do, then you need to apply inverse 3:2 pulldown. |
#960 | Link | |
