Old 13th November 2022, 00:49   #19701  |  Link
guest
Originally Posted by kingpin View Post
I found an issue with RipBot264 :
1. If the File name contains this symbol " – " (it's called En-dash as per
Google), then ripbot doesn't detect the Audio of the video file.
It says "No Audio" .
2. But If I remove the " – " from the file name, it starts
detecting the Audio.
Screenshots are attached as proof...Please fix this.
I bet you signed up, just to comment on this known problem.
You'll probably find that there are many other symbols/characters that will cause issues.
I doubt that it can be "fixed" within RipBot, however, you've already figured out how to work around this, so just go with that, and edit any file names with these symbols...easy peasy.
And, BTW, FYI, because you're new here, any attachments take "forever" to be approved, you would be a lot better off to use site's like "Imgur" or similar to post screenshots, etc.
Old 13th November 2022, 16:30   #19702  |  Link
kingpin
Thanks for the Info. Yes, I am new here.
First, I was like, maybe it doesn't support some audio types or maybe something is wrong with these video files, so I tried to process them using other softwares then Ripbot. Then after a month of this, suddenly I figured out it was because of "File Name" ... I was like what a waste..lol.
Is there a section where I can find all the known issues ??
Also thanks for the "Imgur" tip, I will use that.
kingpin is offline   Reply With Quote
Old 14th November 2022, 01:00   #19703  |  Link
guest
Hello, again,
You're welcome
So even though you're new to the forum, how long have you been using RipBot ??
Are you using Atak's original build's, or are you trying Pauly Dunne's ??
The latter is very update, & has many, many filtering options, I can fully recommend it.
As for a section on "known issues", sadly there really isn't one, and searching this thread looking for specific info is pretty time consuming.
Fortunately though, there aren't too many issues with RipBot, but there's ALWAY's room for improvement.
There is some info on the builds & some feedback comments here:-
https://www.videohelp.com/software/R...tory#changelog
and here:-
https://www.videohelp.com/software/RipBot264
Good luck.
Old 14th November 2022, 02:59   #19704  |  Link
guest
Time for another update...
Here we go yet again...
There has been a few new components become available in the 24 hours or so..
https://www.mediafire.com/file/c5tzr...11-22).7z/file
So for the ppl that use my build, simply unpack, and overwrite ALL the files & folders, they will find their own "home".
And here's a twist, Atak had released an autoupdate, updating several components, BUT they are STILL not the latest available
So if anyone downloaded & installed the update package, for Atak's version, I posted a few days ago, you might have to repeat the process, IF you've allowed the autoupdate, if not, then it's not a problem.
Also, for those using Atak's build, there are some files in this update, that you can copy over.
eg:- MKVToolNix, MPC & x265, but that's ALL !!!!
PS:- I had a problem with the autoupdate download for Atak's version, there was/is a network problem somewhere, and I could not get it to download, even manually, and I still MANY times. (ffmpeg)
http://atak-snajpera.5v.pl/ripbot264update, doesn't reflect the latest version numbers & dates...
Old 14th November 2022, 16:09   #19705  |  Link
gabbett1
Originally Posted by Pauly Dunne View Post
OK, well that is pretty much exactly the same as the first error msg you posted, so at least it's consistent !!!
Are you having problems with other demuxing ???
Maybe there is something wrong with this particular file.
Would you be able to upload a sample ??
May I suggest that you run this thru MKVToolNix, and remove all the stuff you don't want with that, THEN see what RipBot does, OR you could run only the video track thru RipBot and mux it back with ToolNix, later,
Use ToolNix to demux the video track, then import it into RB.
So it looks like it's any newer movie that it's having trouble demuxing. Not sure what to do.
gabbett1 is offline   Reply With Quote
Old 15th November 2022, 00:53   #19706  |  Link
guest
Hi gabbett,
I recall another user was having an issue with something very similar to this, and I think he found a workaround...
Have a look here, and several posts after it...might help.
https://forum.doom9.org/showthread.p...82#post1972082
I think you will find that it's a problem with eac3to, not RipBot.
Old 15th November 2022, 15:23   #19707  |  Link
Ryushin
Ryushin's Avatar
If you are pulling in a 4K UHD ripped source then you will have to use the eac3to that comes with Atak's build. The newer versions of eac3to don't seem to work. It could be there is a new command line option that isn't being used by RB that is causing the error. Either way, rolling back to RB's eac3to version allows it to work fine.
Old 15th November 2022, 17:07   #19708  |  Link
gabbett1
No, I'm not doing 4K UHD disks.
Old 16th November 2022, 00:45   #19709  |  Link
guest
I downloaded Pauly's and I am getting this error now.
eac3to v3.34
command line: "C:\Users\Plex Server\Desktop\Dunne Ripbot\Tools\eac3to\eac3to.exe" "D:\Rip\BULLET_TRAIN" 1) 2: "C:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "C:\Temp\RipBot264temp\job1\audio_1_English.dtsma.w64" -down16 -dcadec 10: "C:\Temp\RipBot264temp\job1\10_subtitles_English_1080.sup" 11: "C:\Temp\RipBot264temp\job1\11_subtitles_English_1080.sup" 12: "C:\Temp\RipBot264temp\job1\12_subtitles_Chinese_1080.sup" 13: "C:\Temp\RipBot264temp\job1\13_subtitles_Chinese_1080.sup" 14: "C:\Temp\RipBot264temp\job1\14_subtitles_French_1080.sup" 15: "C:\Temp\RipBot264temp\job1\15_subtitles_Korean_1080.sup" 16: "C:\Temp\RipBot264temp\job1\16_subtitles_Portuguese_1080.sup" 17: "C:\Temp\RipBot264temp\job1\17_subtitles_Spanish_1080.sup" 18: "C:\Temp\RipBot264temp\job1\18_subtitles_Thai_1080.sup" 19: "C:\Temp\RipBot264temp\job1\19_subtitles_French_1080.sup" 20: "C:\Temp\RipBot264temp\job1\20_subtitles_English_1080.sup" 21: "C:\Temp\RipBot264temp\job1\21_subtitles_Chinese_1080.sup" 22: "C:\Temp\RipBot264temp\job1\22_subtitles_Korean_1080.sup" 23: "C:\Temp\RipBot264temp\job1\23_subtitles_Portuguese_1080.sup" 24: "C:\Temp\RipBot264temp\job1\24_subtitles_Spanish_1080.sup" 25: "C:\Temp\RipBot264temp\job1\25_subtitles_Thai_1080.sup" 1: "C:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="C:\Temp\RipBot264temp\job1\demuxlog.txt"
M2TS, 1 video track, 7 audio tracks, 16 subtitle tracks, 2:06:32, 24p /1.001
1: Chapters, 17 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: AC3, English, 5.1 channels, 384kbps, 48kHz, -8ms
5: DTS Master Audio, French, 5.1 channels, 16 bits, 48kHz
Just re-visiting this post, now I know my eyesight isn't that good anymore, but where is the actually error ??
One thing I've just noticed is the version number of eac3to, I'm pretty sure that Pauly's should be v3.36 ??
And if you're not ripping UHD disc's, you must be getting them another way (won't say what way that is), but of course they would have been ripped to start with.
Did any of my suggestions work, meaning running it thru MKVToolNix first ??
Would you able to upload a sample of the movie you're having trouble with ??
You can do this with MKVToolNix if you want, just load the file, then go to the "Output" tab, choose the "splitting" option, and select or add the length or size you want it split to, then run it until it's completed at least one "chunk", then you can stop it.
Upload to Mediafire or similar.
Anyway, the choice is yours, if you have found a "workaround", then you're set to go, with future problems.
Cheers
Old 16th November 2022, 00:47   #19710  |  Link
guest
The mystery deepen's...
Problem is, he gets the same error with either Atak's or Pauly's, but I've just noticed an eac3to version discrepancy...(see my post, above)
Old 16th November 2022, 05:17   #19711  |  Link
gabbett1
Cheers
I don't know about the error. I'm not a code person. I just linked what the ripbot error displayed. I don't even know what version of eac3to I have. I'm assuming it came with the ripbot zip folder originally because I don't remember installing it. I did try to download a newer version. That did nothing. Assuming I even installed it properly.
I'm ripping Blueray's, not UHD's.
I really would prefer to fix my issue than to have some other workarounds. That's what I got this software for. It was an all in one.
Old 16th November 2022, 05:55   #19712  |  Link
guest
OK, so there shouldn't be problem with Bluray's, then.
Yes, eac3to DOES come with RipBot, and if you want to update it yourself, you need get the download, https://www.videohelp.com/software/eac3to (unpack it, and then copy it into the "eac3to" folder inside RipBot, under the "Tools" folder, overwriting everything in there.)
What are you using to rip the disc's ??
What version of Windows are you running ??
Just trying to help
Old 16th November 2022, 11:13   #19713  |  Link
darkio
How ripbot264 correct colorimetry when upscaling dvd contents to 720p/1080p contents?
mediainfo report itu bt 601 after conversion from NTSC dvd for color matrix, transfer and colorprim.
I've forced in custom box x265 --colorprim bt709 --transfer bt709 --colormatrix bt709 but red is over satured.
No change in auto script from ripbot, no color conversion.
darkio is offline   Reply With Quote
Old 16th November 2022, 11:28   #19714  |  Link
guest
Not 100% sure how to interpret what you want here...
You asked about LUT's 12 months or so ago, you could use a LUT, maybe.
https://forum.doom9.org/showthread.p...99#post1951599
Or under the Avisynth settings, go to the "Colours" setting, click on the and choose "ON", then a "Tweak" option will appear, where you can manually change the appropriate option, and test.
There's also an "ON (3DLUT)", where you can import a LUT.
Old 16th November 2022, 11:40   #19715  |  Link
darkio
yes you are right I asked for the luts about a year ago and it works very well, of that I am very happy.
What I ask now instead is how does ripbot264 correct the colorimetry after a dvd to hd conversion.
log file report:
1.26.0
Fixed: Correct colorimetry for DVD sources (ntsc->smpte170m,pal->bt470bg)
ok, sound is good, let's try!
After upscaling conversion, do not convert to itu bt 709 Rec. https://en.wikipedia.org/wiki/Rec._709, color space is the same of source.
Old 16th November 2022, 12:38   #19716  |  Link
guest
log file report:
1.26.0
I'm pretty sure that RipBot does not this "automatically", you'd probably have to create a special custom filter, or use a suitable LUT.
Other than that, there is only the Colours setting I mentioned in the previous post.
Old 16th November 2022, 13:01   #19717  |  Link
darkio
HD itu 709 rec. example from mediainfo:
Color range : Limited
Colori primari : BT.709
Caratteristiche trasferimento : BT.709
Coefficienti matrici : BT.709v
SD content:
Colori primari : BT.601 NTSC
Caratteristiche trasferimento : BT.601
Coefficienti matrici : BT.601
Lut are unnecessary for colorimetry correction.
I'm asking conversion from bt 601 (smtpe170m/bt470bg) to itu 709 Rec. after upscaling. http://avisynth.nl/index.php/ColorMatrix
It seams ripbot simply "copy" source information in to converted dest. file.
When you use ripbot to convert uhd disk (hdr) to standard video (sdr), it can convert hdr signal itu bt 2020 rec to normal signal into itu bt 709 rec. When using dvd upscaling ripbot do not convert colorapace.
Old 16th November 2022, 13:06   #19718  |  Link
guest
Yes, that is correct, and unless you can create your own special custom script that could do this conversion, you're out of luck, I'm afraid.
Old 16th November 2022, 13:21   #19719  |  Link
darkio
I'm hope atak fix this issue as soon as possible!
However, avisynth can do colormatrix conversion.
Thanks for your reply, friend.
edit: tmpgenc mast. work 7 can import ripbot264 avs file and transform colormatrix into itu bt 709.
[IMG][/IMG]
Old 16th November 2022, 13:39   #19720  |  Link
guest
I'm sure it can be done, I will have a look at it soon, and see what I can find.
You're welcome.
EDIT:- Good 'ole TMPGENC, I used to use that all the time, back in the day (earlier versions of cause.)
I think I may have found something that might do the job, I'll get back to you.
