Old 25th February 2016, 22:10   #1561  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
As the error message says:
The Vapoursynth process terminated abnormally. This means Vapoursynth or one of your Vapoursynth-Plugin's just crashed.
-1073741819 = 0xC0000005 = STATUS_ACCESS_VIOLATION
So this is a problem with Vapoursynth or, more likely, one of the Vapoursynth plug-in's involved. Might as well be a hardware issue though...
Old 25th February 2016, 22:14   #1562  |  Link
2-perf
It's a problem with Vapoursynth or, more likely, one of the Vapoursynth plug-in's involved. Might also be a hardware issue though...
Thanks LoRd_MuldeR. I'll post in the VapourSynth forum.
2-perf is offline   Reply With Quote
Old 27th February 2016, 19:00   #1563  |  Link
djesteban
djesteban's Avatar
I tested this on my side out of curiosity. Tested with two .mov file, one encoded in DNxHD and the other one in ProRes.
I have the same issue than 2-perf where it will crash sometimes on 1-pass startup but mostly on 2nd pass, I would say and easy 8-9 times out of 10.
Seems definitively related to vapoursynth mishandling either .mov containers or the two codecs above... or both. Anyways, there's also ffms2 in the equation here so it could also be part of the issue, but I doubt it.
Encoding a h264 file causes no issue/crash at all.
djesteban is offline   Reply With Quote
Old 7th March 2016, 11:51   #1564  |  Link
SuLyMaN
Thank you Lord Mulder for this software
SuLyMaN is offline   Reply With Quote
Old 18th March 2016, 17:24   #1565  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.67
https://github.com/lordmulder/Simple...ases/tag/v2.67
Version 2.67 [2016-03-17]
* Updated x265 to version 1.9+96
* Fixed detection of 64-Bit VapourSynth in certain cases
Old 10th April 2016, 13:58   #1566  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.68
https://github.com/lordmulder/Simple...ases/tag/v2.68
Version 2.68 [2016-04-09]
* Updated build environment to Visual Studio 2015 with Update-2
* Updated x265 to version 1.9+106
Old 28th April 2016, 15:11   #1567  |  Link
RTW47
Rome Total War
RTW47's Avatar
vapoursynth input - still gives me troubles with x64 Python 3.5.1 and x64 vapoursynth R31 installed, on Windows 7 SP1;
v2.68.1018 --console as expected shows that 64-bit vapoursynth was successfully detected, unfortunately after selecting add job: I still get "VapourSynth is not/available!" message.
- additionally prefering 64-Bit source in the preferences - not helping;
edit:. trying update to 1024 build via web updater returns SendRequest Error;
edit1:. now noticed that if I just "Ignore&Continue", - everything works without actual problem;
RTW47 is offline   Reply With Quote
Old 28th April 2016, 18:58   #1568  |  Link
LoRd_MuldeR
Software Developer
Argh, there was a stupid mistake in one of the checks, so it was testing for Avisynth flag where it actually should be testing for VapourSynth flag
Should be fixed by now:
https://github.com/lordmulder/Simple...c98e1f76e206ff
Please try new TEST version:
https://sourceforge.net/projects/mul...8.exe/download
Works for me
(Probably a short server outage on SF.net)
Old 29th April 2016, 12:53   #1569  |  Link
RTW47
Rome Total War
RTW47's Avatar
I can confirm that test build works properly.
Old 29th April 2016, 14:38   #1570  |  Link
szabi
Hi
Since update to version 2.69 this error occurs:
error: LoadPlugin: unable to load "C:\My Program Files\MeGUI\tools\lsmash\LSMASHSource.dll", Module not found. Install missing library?
I tried it and this avs script works correctly with megui and virtualdub.
What reason makes launcher to fail pluginload?
bye
szabi is offline   Reply With Quote
Old 29th April 2016, 17:22   #1571  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by szabi View Post
Hi
This is an Avisynth error, not Simple x264 Launcher error
Note that Simple x264 Launcher is pretty much just a GUI that launches x264/x265 + Avs2YUV/VSPipe for you. So probably just coincidence that the issue happened to start after the v2.69 update. The real problem must be in Avisynth!
Anyway, one possible reason that comes to my mind:
Maybe your plug-in (LSMASHSource.dll) is 32-Bit and with VirualDub you are using 32-Bit Avisynth, so all is fine, but with Simple x264 Launcher you are trying to use 64-Bit Avisynth? Or the other way around.
[EDIT]
Another possible reason:
Maybe LSMASHSource.dll has a dependency on another DLL. And, when working with VirualDub, that DLL is picked up from VirualDub directory, or from whatever happens to be the "current" directory when you launch VirualDub. But when working with Simple x264 Launcher that other DLL can no longer be loaded, because it's neither in the avs2yuv.exe directory nor in whatever happens to be the "current" directory when you launch Simple x264 Launcher.
It's a very common pitfall with Avisynth plug-in's that have dependencies on other DLL's. Putting those other DLL's into the Avisynth plug-in directory, alongside the plug-in DLL, is not going to work! They must be in one of the directories where the host application (e.g. VirualDub or avs2yuv.exe) will be able to pick them up! One solution is to put the required DLL into "System32" directory. Then it can always be found. But, when doing so, be aware of DLL Hell problem...
Old 29th April 2016, 17:26   #1572  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.70
https://github.com/lordmulder/Simple...ases/tag/v2.70
Version 2.70 [2016-04-29]
* Fixed potential VapourSynth error, when Avisynth is not installed
* Some installer improvements
Thanks for confirming.
Old 29th April 2016, 18:22   #1573  |  Link
szabi
[EDIT]
Hi
I try to figure out what cause it, until that megui going to be used instead of your program which i prefer more.
However before update this issue did not exist.
bye
Old 29th April 2016, 18:52   #1574  |  Link
LoRd_MuldeR
Software Developer
Please confirm again that the issue still exists with latest version. If so, downgrade to the "old" version (v2.68), but do not touch anything else. Does that resolve the issue?
Old 30th April 2016, 07:06   #1575  |  Link
szabi
Hi
You were right the problem comes not from simple launcher.
It comes from megui. It was used to create script.
Megui does something what I do not see.
I reinstall it. Since that script works only with megui nothing else.
Until that I use ffms for indexing which works with simple.
Sorry for that I made a false conclusion.
bye
Old 30th April 2016, 14:22   #1576  |  Link
LoRd_MuldeR
Software Developer
Again, I suggest you do this:
  1. Figure out if the plugin DLL that won't load is 32-Bit or 64-Bit. You can use this tool, to check the "bitness" (see example here). If it is 32-Bit, can only work with 32-Bit Avisynth and thus only with 32-Bit programs; if it's 64-Bit, can only work with 64-Bit Avisynth and thus only with 64-Bit programs. The Simple x264 Launcher supports both "variants" of Avisynth – provided they are installed on your system – by using either 32-Bit or 64-Bit version of Avs2YUV. If both "variants" of Avisynth are installed, you can choose the preferred one in the preferences (this clearly has no effect, of only one "variant" is installed). Make sure it uses the version that matches the "bitness" of your plugin-in DLL!
  2. Use this tool to figure out if your plug-in DLL has some additional dependencies. You need the 32-Bit version of the tool for 32-Bit plug-in DLL, and the 64-Bit version for 64-Bit DLL. If it shows any dependencies other than standard Windows DLL's, then these additional DLL's will need to be in a path where they can be found when the plug-in DLL's get loaded into the Avs2YUV process – otherwise loading of the plug-in DLL is going to fail due to missing dependency!
Old 1st May 2016, 11:32   #1577  |  Link
szabi
Hi
Many thanks for your help and I apologize for my awkward situation.
Something happened with Microsoft Visual C++ 2015 Redistributable x86 which needed by L-SMASH.
It had to be reinstalled.
Somehow megui worked without it but simple did not.
I must say again thanks and sorry for it.
bye
Old 8th May 2016, 20:44   #1578  |  Link
LoRd_MuldeR
Software Developer
Here is a new TEST version with experimental NVEncC (NVidia GPU encoding) support:
This requires a NVIDIA Kepler/Maxwell based GPU with driver 358.xx or higher!
Old 8th May 2016, 21:39   #1579  |  Link
Zetti
Why is there no option to select x86 or x64 when i choose to use NVEncC??
Zetti is online now   Reply With Quote
Old 8th May 2016, 21:53   #1580  |  Link
LoRd_MuldeR
Software Developer
There is. Isn't it?
