26th November 2019, 06:31 | #81 | Link | |
Gesendet von meinem H8324 mit Tapatalk |
12th December 2019, 20:50 | #83 | Link |
I've just uploaded release 0.77 - please try it.
This release includes a few fixes I've done during the last month and maybe your problem is already covered by one of them. In case it still crashed send me the new report and I'll check the code. |
7th April 2020, 21:16 | #84 | Link | |
2020-04-02 14:31:20 # 0 # [I] main / / ############################################################################# 2020-04-02 14:31:20 # 0 # [I] main / / ----------- BlurayTestAndDecrypt 0.77 ----------- 2020-04-02 14:31:20 # 0 # [I] SETTINGS / _STG_CreateOrUpdate / Created ini file >D:\BlurayTestAndDecrypt_0.77\BlurayTestAndDecrypt.ini< 2020-04-02 14:31:20 # 1 # [E] common_log / CMLOG_SetLogDirectory / new logdir invalid >< 2020-04-02 14:31:20 # 1 # [I] main / / Read settings from file >D:\BlurayTestAndDecrypt_0.77\BlurayTestAndDecrypt.ini< 2020-04-02 14:31:20 # 74 # [I] main / / >> Mode >5< 2020-04-02 14:31:20 # 74 # [I] main / / >> DecryptDest >D:\< 2020-04-02 14:31:20 # 75 # [I] bluray_udf / _UDF_Read_MetadataExtendedFileEntry / ++++ Extended File Entry ++++ 2020-04-02 14:31:20 # 75 # [I] bluray_udf / _UDF_Parse_FileSetDescriptor / ++++ File Set Descriptor ++++ 2020-04-02 14:31:20 # 140 # [I] main / / List of files being processed: 2020-04-02 14:31:20 # 140 # [I] main / / Detected File >D:\BlurayTestAndDecrypt_0.77\BIRDMAN.iso< 2020-04-02 14:31:20 # 140 # [I] main / / ############################################################################# 2020-04-02 14:31:20 # 140 # [I] main / / 1/1 - Decrypt - ISO2ISO >D:\BlurayTestAndDecrypt_0.77\BIRDMAN.iso< 2020-04-02 14:31:20 # 141 # [I] main / CheckAndCreateOutputDir / Decrypt OutputDir: D:\ 2020-04-02 14:31:20 # 141 # [I] main / DecryptIso2Iso / UDF - OpenISO 2020-04-02 14:31:20 # 141 # [I] bluray_udf / _UDF_Read_MetadataExtendedFileEntry / ++++ Extended File Entry ++++ 2020-04-02 14:31:20 # 141 # [I] bluray_udf / _UDF_Parse_FileSetDescriptor / ++++ File Set Descriptor ++++ 2020-04-02 14:31:20 # 203 # [I] main / DecryptIso2Iso / Details about ISO File: UDF Revision : 0250 VolumeName : BIRDMAN 2020-04-02 14:31:20 # 203 # [I] main / DecryptIso2Iso / Initialize Disc now 2020-04-02 14:31:20 # 203 # [I] main / Bluray_InitDisc / VolumeName: BIRDMAN 2020-04-02 14:31:20 # 204 # [I] main / Bluray_InitDisc / DiscID: 27245C62EC935F097FC4E4058BA76407E70CEFA2 2020-04-02 14:31:20 # 204 # [I] main / Bluray_InitDisc / Disc is AACS protected - init necessary AACS values 2020-04-02 14:31:20 # 205 # [I] main / Bluray_InitDisc / Use default AACS-KeyDB file instead >C:\Users\Main\AppData\Roaming\aacs\keydb.cfg< 2020-04-02 14:31:20 # 205 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\Main\AppData\Roaming\aacs\keydb.cfg< opened! 2020-04-02 14:31:20 # 219 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\Main\AppData\Roaming\aacs\keydb.cfg< in memory now 2020-04-02 14:31:22 # 2406 # [I] bluray_keydb / _ParseMem / Removed duplicates for >0< discids from file >C:\Users\Main\AppData\Roaming\aacs\keydb.cfg< 2020-04-02 14:31:22 # 2407 # [I] main / Bluray_InitDisc / VUK >1854B56CA4681135A82C5276BAB03915< available in KeyDB entry for disc 2020-04-02 14:31:22 # 2407 # [I] main / Bluray_InitDisc / VUK: >1854B56CA4681135A82C5276BAB03915< 2020-04-02 14:31:22 # 2407 # [I] main / Bluray_InitDisc / EncryptedUnitKeyCount >1< 2020-04-02 14:31:22 # 2408 # [I] main / Bluray_InitDisc / UnitKeyCnt: 1 2020-04-02 14:31:22 # 2408 # [I] main / Bluray_InitDisc / >>> UnitKey: 8ADA030B54AC77C9DE0036497AAA8262 2020-04-02 14:31:22 # 2408 # [I] main / Bluray_InitDisc / Check if disc is BD+ protected 2020-04-02 14:31:22 # 2409 # [I] bluray_aacs / BRAACS_IsBDplusProtected / Directory >\BDSVM< does exist and there is at least 1 .svm file in the folder >\BDSVM\BACKUP\< - disc is BP+ protected 2020-04-02 14:31:22 # 2409 # [I] main / Bluray_InitDisc / Disc is BD+ protected! 2020-04-02 14:31:22 # 2421 # [I] main / Bluray_InitDisc / BD+ details - Date 2014.12.19 Gen 254 2020-04-02 14:31:24 # 4002 # [I] main / ErrorHandler / A program error was detected: Error Message: Invalid memory access Error Code: -1073741819 Code Address: 1979164744 Target Address: 1 Sourcecode line: 1192 Sourcecode file: U:\PUREBASIC\Bluray-Test\BlurayTest.pb |
20th April 2020, 21:11 | #85 | Link |
Released 0.79 - it hopefully fixes the problem reported above (I introduced this bug 2018 ... ) and also changes the way the keydb file is opened: shared readonly, so it's not a problem any longer when the file is also opened in another application in parallel.
21st April 2020, 02:56 | #86 | Link |
That update did the trick. Thanks a ton!
I'm having an issue now with regular usage. Upon getting past that error, I try to advance to decrypting the disc. However, each and every playlist on the disc quickly errors out with the following message: Code:
ERROR! bluray_aacs-BRAACS_AutoDetectUnitKey - Decryption failed with all possible UnitKeys! >1< ERROR! Couldn't get correct UnitKey! ERROR! Processing of file >E:\BDMV\STREAM\00xxx.m2ts< failed! EDIT: This issue is happening with my retail copy of Birdman (the initial release in the red case). I tried again with Slumdog Millionaire and didn't have any issues. Last edited by bleakassassin; 21st April 2020 at 03:05. |
26th August 2020, 14:51 | #87 | Link |
I have a PAL BluRay from "Pokémon Origins" here. I successfully ripped it with MakeMKV, which lists AACS v63 for the disc.
Just today I read about your program here and decided to test it. But when usind Mode 2 the BluRays ID can't be found in the keydb.cfg (I did download the mentioned file via the information in https://forum.doom9.org/showthread.php?t=176924 and also updated it according to the thread). Now I wonder how often that keydb.cfg might be updated and what is the best way to do so. |
1st February 2021, 12:51 | #90 | Link | |
I'm trying to copy some of my Bluray discs to an iso image using Mode 6 (or Mode 7 according to the first post). Unfortunately some of them have special characters (e.g. ":") in their title, which results in an error message like: Quote:
Any ideas to avoid/fix this? Thanks in advance, VCL1918 |
10th August 2021, 20:28 | #91 | Link | |
15th March 2022, 08:24 | #92 | Link |
I have successfully extracted an .iso using your tool and am trying to use Mode 5 to repair the bdplus (BD+ Gen 7). I have what I believe is the correct convtable in that the filename of the .bin matches my MediaKey. Specifically, the convtable filename is in the format MediaKey_TITLE.bin in the file path %APPDATA%\Roaming\bdplus\convtab\. However, your tool gives me an error of "No matching file found." How exactly does your tool distinguish a convtab "matching file"?
19th March 2022, 23:02 | #93 | Link | |
"conv_tab_"+sDiscId+"*.bin" So I guess you're already failing in this situation. Please try renaming your file and report what happens next |
21st July 2022, 10:09 | #94 | Link |
With all cached BD+ tables from https://forum.doom9.org/showthread.php?t=176924 I cannot de-BD+ my Simpsons BluRay. It tells me, that it couldn't find any fitting FixUpTable.
Now I was told, the files inside the conv directory would be named after the MK number, not after the DiscID. So I can't use the cached BD+ tables from the thread then? Does one have to convert/rename them somehow? |
21st July 2022, 10:31 | #95 | Link | |
25th April 2023, 12:09 | #97 | Link |
Published release 0.94 with a few fixes and a few new features:
use RDK for BusDecryption when @Candela posted it's message https://forum.doom9.org/showthread.php?t=184373 it's been the first time for me to hear from the ReadDataKey at all. I started to add the on-the-fly decryption in BTAD and finished it a couple of weeks ago and did not notice any problems in the meantime, so I think its ready for primetime create BD+ FUT tables with 'mediakey' in name I wasn't really aware that the files created by BTAD did not match the filenames expected by libbdplus... so I changed it so the filenames are correct now Additionally I tried XREVEAL and I like it. For an unknown reason it's expecting the BD+ FUT tables in a different directory than libbdplus - so I added the check if XREVEAL is installed and if it is, the FUT file is also created in it's specific directory. Finally it's working well for me option for auto-update It's enabled by default and using the same mechanism as FindVUK - in case a new release is available on the server it get's downloaded and updated. Can be disabled in the ini-file if desired. A few additional changes are listed on the first post in this thread - and as always it's possible I've introduced new bugs or changed other things without mentioning |
15th May 2023, 16:08 | #99 | Link |
I have a BluRay here (Resident Evil Degeneration) which is... strange. When I make an encrypted backup with DVDFab, it just rips the BluRay. When I try to make a decrypted backup though, DVDfab fails after 0.55% with a read error.
When I make an decrypted backup with MakeMKV (which doesn't rip to ISO but to the folder structure) I don't get that problem. When I use BTAD on the image of the encrypted backup, it also stops after 0.55% with this: Code:
16:49:16 - ++ DECODE ++ Pct > 0.54%< StartBlock >00086176< BlockLen >00000723< File >\BDMV\STREAM\00003.m2ts< 16:49:16 - ++ COPY ++ Pct > 0.55%< StartBlock >00086899< BlockLen >00000013< 16:49:16 - ++ DECODE ++ Pct > 0.55%< StartBlock >00086912< BlockLen >00000240< File >\BDMV\STREAM\00071.m2ts< 16:49:16 - ++ COPY ++ Pct > 0.55%< StartBlock >00087152< BlockLen >00000016< 16:49:16 - ++ DECODE ++ Pct > 0.55%< StartBlock >00087168< BlockLen >00000270< File >\BDMV\STREAM\00504.m2ts< Filename >\BDMV\STREAM\00504.m2ts< Size GB > 0.00< Progress >1/1< 16:49:16 - ERROR! Unencrypted unit has errors! - stop now FindVUK doesn't even try any UnitKeys on the file, stopping at this: Code:
17:06:36 - Decrypted first unit of file >D:\BDMV\STREAM\00502.m2ts< with UnitKey >2< 17:06:36 - Decrypted first unit of file >D:\BDMV\STREAM\00503.m2ts< with UnitKey >3< A side note: BTAD blocks access to the keydb.cfg even if it's already done ("Press Escape to exit" is shown). Another question: are .ssif files encoded on a 3D BluRay? I only noticed BTAD isn't touching them. Last edited by Bahamuth; 15th May 2023 at 17:17. |
15th May 2023, 20:05 | #100 | Link | |
Hi! Have you tried to make an encrypted backup with BTAD? Does this work fine and does the check at the end succeed? What to you mean with "FindVUK stops" - basically FindVUK only checks if the discovered keys are valid, so as soon as each key has been successfully tested against a single file it's happy as it knows the keys are valid. Locking of keydb: you're right - will change it in an upcoming release. And SSIF files are not really separate files on the disc but instead only references to other m2ts files - when you calculate the sum of all files on the disc you'll notice that it won't fit on the disc at all So when the M2TS files are decoded, the SSIF is automatically decoded as well. (as far as I remember the SSIF files are the 3d files) |
