20th September 2017, 12:10 | #45801 | Link | |
Sent from my Pixel XL using Tapatalk
20th September 2017, 17:37 | #45806 | Link |
That attachment is going to take forever to get approved. You're better off hosting it somewhere and linking to it.
20th September 2017, 18:01 | #45807 | Link | |
Inviato dal mio ASUS_Z00LD utilizzando Tapatalk
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
20th September 2017, 18:37 | #45808 | Link | ||
madvr: limited gpu: full tv: limited I've read that this is an acceptable config so if someone wants to confirm or deny that for me I'd appreciate it. It seems to be working.
20th September 2017, 18:40 | #45809 | Link | |
Madvr - 0-255 gpu - limited Tv - Low which is 0-255 Everything seems fine , better than the 16-235 I had in MadVr on the old LED philips TV . On my LED TV I had Madvr- 16-235 gpu - limited TV - I didn't have any option to really choose, only Computer/PC Mode or Game Mode which just reduce the lag input but Computer mode couldn't do good in 3D with the gamma or the black, so it made it too dark instead keeping in properly. hard to explain, but Game was the proper for PC/Game Console or anything on the AUTO Working side, or else on Computer just changing a lot things manually and even though it wouldn't work. If you want new drivers to test , maybe if you have also WDDM 2.3 check this which on the Insider /Fast update https://forums.guru3d.com/threads/wi....416859/page-4 Last edited by x7007; 20th September 2017 at 18:45. |
20th September 2017, 18:56 | #45810 | Link | |
As for the drivers, I just got a new insider build pushed to me yesterday so I'm guessing it's got the latest insider driver already. I don't want to mess with it as I tried to downgrade it manually and it failed. Yes, I can force the issue but I'm just not in the mood to mess with driver issues right now. That's a distinct possibility for the source of my problem, however.
20th September 2017, 19:04 | #45811 | Link |
_
Everything.
Asmodian's thread explains options (thank him for this initiative), it does not mean you have to enable them all. Another thing Asmodian should be sorry of ! xD Soften is the opposite of sharpen so you don't want to enable both. Some eyes prefer sharpen images, other eyes prefer soften images. These settings can improve images in some videos, but do the opposite on others so I advise you to disable everything first. Then, if you have a lot of time, you can try these settings ONE BY ONE. Maybe you'll like one of them. Careful though, they can be bad for some videos. But sorry, no shortcut for you, you'll need time. The easiest path is obviously to enable nothing, it won't mean image will be bad. Image post-processing (or calibration) is over-hyped IMO but that's because I noticed judder (the real enemy) more easily than a pixel 50;86;211 instead of 48;82;220. And thanks for the [IMG] effort. Appreciate that. |
20th September 2017, 19:05 | #45812 | Link |
Everything other than video playback will show crushed blacks and clipped whites but if you're only using that machine for madVR it's OK (even though less optimal than RGB Full).
20th September 2017, 19:18 | #45813 | Link |
Yea, it's primarily used for video playback. I would like to properly solve the issue and allow FULL across the board. I did just check, and the new insider driver is installed. No idea if that's the issue or not. Hence why I want to check it on the PS4 or XB1 and see if I get the same ghosting issue with that particular title. I've never really had an issue with 3D like this before. The fact that 2D works fine and 3D doesn't worries me a little cause I know the Panasonic plasma is fast enough.
20th September 2017, 19:49 | #45814 | Link | |
And disabled 'soften edges' refinement. Enabled are 'sharpen/crispen edges', 'enhance detail', 'LumaSharpen and A.Sharpen' and 'anti-ringing'. Settings for chroma, i. downscaling/upscaling are good?
20th September 2017, 21:09 | #45815 | Link | |
I forgot to say that of course if I select EVR-CP the issue goes away, so clearly a MadVR issue. I've done more tests today and this issue seems to be only present with HDR content. It only happens if HDR is set to "Let MadVR decide" or to HDR Passthrough. If I select one of the SDR conversion options, the picture is fine. FSE/Windowed doesn't make any difference. What's very weird is that even when MPC-BE is windowed (not full screen), the magenta tint is on the whole desktop, not only on the player's window. Hopefully Madshi can reproduce and fix.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 20th September 2017 at 21:57. |
20th September 2017, 22:07 | #45816 | Link |
This sounds like your display having a bad HDR mode, if madVR sends it the HDR metadata it looks wrong?
My system passes HDR to my TV correctly using an almost identical GPU.
madVR options explained |
20th September 2017, 22:25 | #45817 | Link | |
Also I select the HDR mode manually, so it has nothing to do with the metadata. I get the same magenta screen with HDR content if the display mode is HD/Rec709 or HDR/BT2020, it makes no difference. It's just that in that mode, MadVR sets the whole desktop (not just the player's window) to black and magenta. It's not a subtle calibration issue, it's a completely wrong mode. When you say it works with your TV, did you test specifically for the mode I reported, and with the HDR settings I mentioned? HDR passthrough with MadVR works fine here, except in 4K60 RGB 8bits, and only when MadVR isn't doing a conversion to SDR.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 20th September 2017 at 22:37. |
20th September 2017, 22:34 | #45818 | Link |
21st September 2017, 01:51 | #45819 | Link | |
screenshot
21st September 2017, 05:06 | #45820 | Link |
MadVR crashes when play HEVC whit D3D11
MadVR tends to crash when playing a HEVC video, using D3D11 (native / copy-back).
This does not happen using EVR. Crash report: https://mega.nz/#!Ew8ymaqA!cq0nTDN6M...Fsy36k6ePHSaZM PC specs: Windows 10 CU X64 Intel Core i5-4210U / Intel HD 4400 MadVR 0.92.3 LavFilters 0.70.2.74 |
