Old 21st April 2019, 16:55   #55861  |  Link
tp4tissue
tp4tissue's Avatar
Lots of possibilities.
List your entire hardware + software chain
Then load a video where you see the green tint into MPC + Madvr, pause movie, PRESS, Ctrl-J,
Take a screen shot of the OSD readout.
Ghetto | 2500k 5Ghz
Old 21st April 2019, 16:57   #55862  |  Link
Charky
Dumb question but... have you considered that maybe VLC is the one doing something wrong with the colours and you are so used to it that anything else looks weird ?
Just asking, cause that wouldn't be a first
Charky is offline   Reply With Quote
Old 21st April 2019, 17:28   #55863  |  Link
tp4tissue
tp4tissue's Avatar
Hahahaha. that's insulting to the VLC team. They're competent people and do a good job
Ghetto | 2500k 5Ghz
Old 21st April 2019, 17:36   #55864  |  Link
Originally Posted by Klaus1189 View Post
What is the benefit in detail of checking this compatibility mode?
the full screen optimization makes overlays work better.
it supposed to make FSE less exclusive and more like WFS.
using it can have all kinds of effects. from massively improving performance in some games and system to literally breaking presentation.
my HTPC starts to flicker like crazy with it disabled my desktop works flawless with it and FSE changes are faster.
so in short use it at your own risk.
Old 21st April 2019, 20:39   #55865  |  Link
toki
I hope I'm getting this down a little better now. I have had to make some comprimises and tinkering to the profile selections. I had them as blasted as possible on the 1080 and it really does use some processing power at the end of the day, so it's just been going through recommendations and trying to get it as natural while still keeping the quality that I want. I just can't believe the 1660ti isn't doing quite as much as I thought it might. I am actually kind of disappointed with it at this point. I doing that "blasting" of settings on a 1050. Even though it was on a 1080p resolution I was still able to use pretty maximum settings, where this one I'm having to compromise and tinker. And don't even get me started on the whole drivers deal going on that I've had the joy of experiencing once starting with this card.
toki is offline   Reply With Quote
Old 21st April 2019, 23:36   #55866  |  Link
tp4tissue
tp4tissue's Avatar
I think it has to do with the fact that madvr relies on the # of cuda cores, more so than Overall card performance.
So while 1660ti would be ~ 1070/1080, those cards still have higher cuda count .
I'm not sure. just guessing.
Ghetto | 2500k 5Ghz
Old 21st April 2019, 23:47   #55867  |  Link
coolgit
Is there anyone on here who has an AMD RX 570 card. I need a copy of the DXVA checker decoder device to cross-check with mine. I wanted to see whether HEVC_VLD_Main is available or not.
Cheers.
coolgit is offline   Reply With Quote
Old 22nd April 2019, 03:33   #55868  |  Link
tp4tissue
tp4tissue's Avatar
I don't think you need to check, it's pretty certain 570 supports hevc main.
Ghetto | 2500k 5Ghz
Old 22nd April 2019, 03:41   #55869  |  Link
djesteban
djesteban's Avatar
Is madvr still going to be developed/supported after the envy release?
I tried searching the thread for this info but couldn't find an answer.
Cheers
djesteban is offline   Reply With Quote
Old 22nd April 2019, 03:56   #55870  |  Link
SamuriHL
SamuriHL's Avatar
Yes. They are separate things.
Old 22nd April 2019, 04:35   #55871  |  Link
Warner306
As you've discovered, it takes far more processing power to output to 2160p compared to 1080p. The 1660 Ti should still provide 1070 level performance, which is not bad, but not in the same ballpark as a true 4K card like the GTX 1080 Ti.
Old 22nd April 2019, 06:18   #55872  |  Link
coolgit
I need facts not 'pretty certain'. Only hevc main10 is showing. All files plays with dxva2cb in lav filter except for hevc main.
Old 22nd April 2019, 06:52   #55873  |  Link
https://cdn2.techbang.com/system/ima...png?1492501244
not my card not my image.
and why do you ask this in the madVR thread?
https://forum.doom9.org/showthread.p...71219&page=124
Old 22nd April 2019, 06:56   #55874  |  Link
hotripper
Anyone ever hear of getting lag/stutter but 0 dropped, 0 repeated(other than every 5 mins or so), 0 delayed, 0 glitches in osd while using Madvr display matching? Mainly happens with 23.975 content. Setting windows power option to "power saver" cures it, but this is not a solution. I'd like to give up on this but I have tried every setting I can think of.
3700X - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E
hotripper is offline   Reply With Quote
Old 22nd April 2019, 07:01   #55875  |  Link
https://forum.doom9.org/showpost.php...&postcount=151
don't attach screens to the forum they need approval which may takes time.
Old 22nd April 2019, 07:02   #55876  |  Link
tp4tissue
tp4tissue's Avatar
ur going to get repeats/ drops if the screen cadence isn't exact.
Ghetto | 2500k 5Ghz
Old 22nd April 2019, 07:31   #55877  |  Link
hotripper
Yes I know. Thats not the issue.
I tried the profileinspector. I loaded MPC hit apply and no different. Also ran the bat file for nvidia.
Old 22nd April 2019, 07:43   #55878  |  Link
austinminton
Originally Posted by hotripper View Post
Anyone ever hear of getting lag/stutter but 0 dropped, 0 repeated(other than every 5 mins or so), 0 delayed, 0 glitches in osd while using Madvr display matching? .
Try Fullscreen exclusive
austinminton is offline   Reply With Quote
Old 22nd April 2019, 07:57   #55879  |  Link
coolgit
Thanks. All the same except for hevc main. Any possible explanation as i have spent two weeks scratching my head trying to solve this. It's a new card and could it be faulty?
Madvr requires gpu card so the chance of someone having an answer is higher than elsewhere. Gpu card isn't a must for lav filter.
Old 22nd April 2019, 08:04   #55880  |  Link
hotripper
Yes I already run in fse, I have tried all options including all in general settings. BTW this happens not only with 4k content but also 1080 content. Tried all decoder options too in lav. Tried old drivers.
I get smooth playback if: Windows power setting is set to Power Saver every single time without a doubt
This is a big indication. Settings do nothing, this is backed by the osd results that do not show any issues with drops repeats, queues, etc, all show fine.
Could the hdmi port on the card be sending something like too much power to the display? So the display is freaking out? Thats why power saver fixes it by lowering something? (FYI I have gone out and tried 2 brand new 2070s and brand new PSU, same result)
