4th September 2017, 22:06 | #45381 | Link | |
2.- not really, I'm not sure, I have two users, I will check playing a video on the other user and see if I get a result 3.- yeah 100% sure 4.- yeah, 1 frame drop every hour (is not that bad, but I want to improve it) Thank you very much! |
4th September 2017, 22:42 | #45383 | Link | |
@madshi
All zoom control options is deactivated excluding "move subtitles". It is on by default. Last edited by mparade; 4th September 2017 at 22:46. |
4th September 2017, 22:57 | #45384 | Link | ||
OS: Win10 1703 GPU: GTX 1070 (latest stable drivers) Monitor: LG OLED55B6V TV / Yamaha RX-A860 AVR Media setup: MPC-BE x64, madvr, lav filters (nightly) |
4th September 2017, 23:02 | #45385 | Link |
Yea, that's what I get for typing it and being lazy LOL. The queues were all full so those numbers should be duplicated 16/16, etc. It's weird. I've never seen it do that before where the queues are all full but video is frozen. When I change LAV to copy back and/or change D3D11 to use copy back instead of native it works fine. Very strange.
4th September 2017, 23:10 | #45386 | Link | |
But if I disable D3D11 presentation, I will have a poor image quality? Maybe a nvidia driver bug? Thanks |
5th September 2017, 02:00 | #45387 | Link | |
Probably, there have been a lot of driver oddities around applying and enabling custom resolutions.
madVR options explained |
5th September 2017, 05:50 | #45389 | Link | |
5th September 2017, 09:05 | #45390 | Link | |||||
Which is the exact list of display modes to switch to in your display's "display modes" tab in the madVR settings? And please create a debug log, zip it, upload it somewhere else (don't attach to this forum) and then link to it here. Quote:
Please see Asmodian's and Ava Pug's replies. |
5th September 2017, 09:13 | #45391 | Link | ||
5th September 2017, 10:25 | #45392 | Link |
Yep, I'm using 422 10bit atm, still no luck
5th September 2017, 13:39 | #45394 | Link |
Hi guys. I was wondering which option is better, using TV at 60hz and smooth motion on, or make it go to 23/24hz with smooth motion off?
I kinda like smooth motion on because there is no flashing on screen because there is no refresh rate change. Also I really don't know if my tv can actually handle 24p content, is a Samsung Eh6030, maybe 120hz because of 3D and accept various refresh rates. My brother's TV can change to 24hz too but is not a 120hz tv so I think is a waste making it change to 24hz everytime. So what do you guys think about this? |
5th September 2017, 15:27 | #45395 | Link |
Well I give up. I went and changed it back to d3d11 native to check on the OSD and for whatever reason playback is working. I've not, to my knowledge, changed anything since I last tried so I have NO idea what happened. Sorry to have troubled you with this one.
5th September 2017, 15:37 | #45396 | Link |
HEYYYY there we go! I got it to freeze again and maybe this'll shed a little light on the subject. Can someone with a 1060 try this and see what they get for results? With D3D11 Native mode enabled, watch a 3D movie for a couple minutes. Stop playback and then try to watch a 2D movie. It's now frozen for me. The average and max stats do seem to be changing in the OSD, but, the queues are full and no video is playing. That's...weird right?
Ok, I think I got this one figured out finally. If I exit out of JRiver MC23, go to display properties and toggle 3d off, then back on, I'm able to play the 2D movie again. So I have a feeling something's not getting reset on playback of a 3D movie.
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 5th September 2017 at 15:41. |
5th September 2017, 18:50 | #45397 | Link | |
@madshi
madVR OSD says: P016, 16bit 4:2:0. |
5th September 2017, 19:24 | #45398 | Link |
I was playing around with the hdr to sdr conversion. Why is the default display's peak nits set to 400?
I read sdr content is usually intentionally limited to 100 nits for compatibililty with older devices. I understand that newer devices allow for more nits but that's not exactly sdr anymore. So when conversion to sdr is needed wouldn't 100 nits (less than madVR even allows to be set) be the most sensible default? @mparade Your cpu utilization seems normal considering software decoding such a file. |
5th September 2017, 20:13 | #45399 | Link |
It seems, even these days there is no GPU assisted decoding method for main12 HEVC sources. After reading the specs of my card I was pretty sure it could be done at least via CUVID or DXVA. I was wrong, or just not having enough info.
5th September 2017, 20:26 | #45400 | Link |
Hi Madshi, would it be possible to add something like a 'lock-buttom' for a custom mode once a perfect setting was found ? I am asking because last weekend I spent hours trying to find a setting for a refresh rate but with each new measurement it got worse, e.g. dropped frames down to minutes until I remembered that I had already found a p.s. for that frequency.
But unfortunately that remark was changed to 'optimization available' after playing another file not long enough or with interruptions or whatever ... So after, say, a driver update it can get unlocked - tested - and locked again. |
