Old 6th January 2021, 05:36   #8141  |  Link
v0lt
Originally Posted by cmhrky View Post
I thought it was going to be tested with the MPC-BE debug version. I tried it with MPC VR debug build but could not see any log files in renderer directory.
As clsid correctly noted, you need a DebugView.
It would be nice if you can define the type of DVD-Video protection. You may need utilities like AnyDVD HD, CloneDVD or something similar from the Decrypting forum.
Old 6th January 2021, 12:10   #8142  |  Link
cmhrky
MPC VR did not create a log file.
cmhrky is offline   Reply With Quote
Old 6th January 2021, 12:53   #8143  |  Link
v0lt
@cmhrky
1. Run DebugView.
2. Run MPC-BE with MPC VR debug version. Open DVD-Video. Close MPC-BE.
3. In DebugView. File->Save As... log file.
Old 6th January 2021, 13:20   #8144  |  Link
cmhrky
Message #8135 picture
https://pastebin.com/raw/tVbKwZNM
DVD Copy-Protect Fail
https://pastebin.com/raw/AbYEJNei
Old 6th January 2021, 15:09   #8145  |  Link
v0lt
@cmhrky
Thank you.
Do Haali VR and madVR play these discs?
Old 6th January 2021, 15:49   #8146  |  Link
cmhrky
madVR: works good.
Haali VR: "DVD: Macrovision Fail" error.
Old 6th January 2021, 19:52   #8147  |  Link
clsid
It probably needs the implementation of setting AM_PROPERTY_COPY_ANALOG_COMPONENT.
https://forum.doom9.org/showthread.p...57#post1599257
Old 7th January 2021, 06:28   #8148  |  Link
v0lt
madVR: works good.
It's good.
I will ask you to make logs in this version
MPCVideoRenderer-0.5.1.1602_git2021.01.07-56966a8_Debug
Added:
@cmhrky
There are two test builds here (1602). Please check and report whether there was any improvement or not.
Old 7th January 2021, 10:06   #8149  |  Link
Klaus1189
Updated german Translation based on r5928
@users and translators:
To access the window: Mouse page -> middle mouse button -> select "..." in the dopdown menu -> the new window appears:
https://drive.google.com/file/d/1C0Y...ew?usp=sharing
@v0lt:
I added "&" to the new translation, so keyboard shortcuts work for this window. Is that OK, or do I have to remove them? I ask because there were none before. Perhaps there must be something added?
Old 7th January 2021, 11:35   #8150  |  Link
cmhrky
Originally Posted by v0lt View Post
It's good.
https://www68.zippyshare.com/v/cn9GCN0D/file.html
Added:
@cmhrky
"mpcvr-1602_COPY_ANALOG_COMPONENT_FALSE" It opened the DVD without any problems.
"mpcvr-1602_COPY_ANALOG_COMPONENT_TRUE" opens the DVD, but like the picture in message #8135.
Also, I don't know if this is a problem but there are no chapter marks on the Seek Bar. But there are chapters.
https://streamable.com/al2ge4
MediaInfo:
General
Complete name                  : I:\VIDEO_TS\VTS_01_0.IFO
Format                         : DVD Video
Format profile                 : Program
File size                      : 96.0 KiB
Duration                       : 1 h 6 min
Overall bit rate mode          : Variable
Overall bit rate               : 197 b/s
Video
Format                         : MPEG Video
Format version                 : Version 2
Bit rate mode                  : Variable
Width                          : 720 pixels
Height                         : 480 pixels
Display aspect ratio           : 4:3
Frame rate                     : 29.970 (29970/1000) FPS
Standard                       : NTSC
Compression mode               : Lossy
Audio #1
Format                         : AC-3
Format/Info                    : Audio Coding 3
Channel(s)                     : 6 channels
Sampling rate                  : 48.0 kHz
Language                       : English
Audio #2
Format                         : DTS
Format/Info                    : Digital Theater Systems
Language                       : English
Audio #3
Format                         : AC-3
Channel(s)                     : 2 channels
Language                       : English
Text #1
Format                         : RLE
Format/Info                    : Run-length encoding
Bit depth                      : 2 bits
Language                       : English
Text #2
Format                         : RLE
Bit depth                      : 2 bits
Language                       : French
Text #3
Format                         : RLE
Bit depth                      : 2 bits
Language                       : German
Text #4
Format                         : RLE
Bit depth                      : 2 bits
Language                       : Spanish
Text #5
Format                         : RLE
Bit depth                      : 2 bits
Language                       : Portuguese
Text #6
Format                         : RLE
Bit depth                      : 2 bits
Language                       : English
Menu #1
00:00:00.000                   : Chapter 1
00:04:21.333                   : Chapter 2
00:08:55.333                   : Chapter 3
00:13:30.899                   : Chapter 4
00:17:47.932                   : Chapter 5
00:22:14.332                   : Chapter 6
00:26:53.998                   : Chapter 7
00:30:38.698                   : Chapter 8
00:34:18.664                   : Chapter 9
00:41:10.130                   : Chapter 10
00:42:24.730                   : Chapter 11
00:45:56.830                   : Chapter 12
00:49:19.396                   : Chapter 13
00:53:18.829                   : Chapter 14
00:59:27.329                   : Chapter 15
01:06:23.329                   : Chapter 16
List (Audio)                   : 0 / 1 / 2
List (Subtitles 4/3)           : 0 / 1 / 2 / 3 / 4 / 5
List (Subtitles Wide)          : 0 / 0 / 0 / 0 / 0 / 0
List (Subtitles Letterbox)     : 0 / 0 / 0 / 0 / 0 / 0
List (Subtitles Pan&Scan)      : 0 / 0 / 0 / 0 / 0 / 0
Menu #2
Duration                       : 45 min 37 s
00:00:19.000                   : Chapter 2
00:00:22.560                   : Chapter 3
00:00:26.720                   : Chapter 4
00:00:29.200                   : Chapter 5
00:00:32.880                   : Chapter 6
00:00:48.880                   : Chapter 7
00:00:56.880                   : Chapter 8
00:01:30.880                   : Chapter 9
00:01:41.880                   : Chapter 10
00:01:44.360                   : Chapter 11
00:01:47.600                   : Chapter 12
00:02:07.600                   : Chapter 13
Old 7th January 2021, 11:38   #8151  |  Link
v0lt
@Klaus1189
Thanks. Updated in r5931.
The "&" symbol works for menus and buttons.
Old 7th January 2021, 12:09   #8152  |  Link
v0lt
Thanks. Used in MPC VR 0.5.1.1603 (92cc2ee).
Check in menu "Navigate -> Jump to".
If not, then the player has not received information from the DVD Navigator.
Old 7th January 2021, 12:24   #8153  |  Link
Klaus1189
If I see your video correctly, MPC-BE jumps to the chapters, but doesn't show them on seekbar. Be sure to enable this setting if you want them shown:
https://drive.google.com/file/d/137o...ew?usp=sharing
Old 7th January 2021, 14:14   #8154  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Test on some my DVD - working perfect. Upload iso - i'l check.
Old 7th January 2021, 14:16   #8155  |  Link
cmhrky
Thank you for new MPC VR.
All chapters already exist in this menu.
Already enabled. I've tried other DVDs, they are okay but this DVD is like this.
Old 7th January 2021, 14:19   #8156  |  Link
Klaus1189
How do I open the window with translation:
BEGIN DIALOGEX IDD_ITEMPROPERTIES_DIALOG LINES 11
Old 7th January 2021, 14:44   #8157  |  Link
v0lt
In "Organize Favorites -> Edit".
Old 7th January 2021, 15:19   #8158  |  Link
Klaus1189
@v0lt:
Thanks. I've never been in this window after all the years and found one translation which I had to fix:
Updated german translation based on r5931. If I had just seen it before the last update
Old 7th January 2021, 15:35   #8159  |  Link
cmhrky
@Aleksoid1978
Some parts of DVD. Title 1 - Chapter 1-4 fully watchable. ~19 min. ~1,53 GB
I think it is enough to check, because I have no possibility to upload the entire DVD.
https://we.tl/t-XUHkLMR6pv
Old 7th January 2021, 16:25   #8160  |  Link
v0lt
@cmhrky
This is not enough. The IFO file analysis algorithm ignores chapter 16.
What happens when you switch to Title 1, Chapter 16?
