Old 13th May 2017, 19:57   #461  |  Link
hello_hello
sheck,
Thanks for the new version.
I've only had a quick play (MKVToolNix 10), and maybe it's an XP thing, but when running the the portable version it offers an error message regarding "log_rotate.exe not being a valid win32 application", although after dismissing the error message the program seems to work okay. The installer causes the same error message to appear when installing.
I've also managed to bump into a kind of file name oddity with a bunch of files I tested. They're the only files I have that are named this way, but they just happened to be handy for testing. They look like this in version 0.6.0.8 vs 0.7.0.0 (I can't select the individual tracks for extraction and they make no appearance in the Batch section.
But the same files renamed:
And playing with the batch filter I discovered the drop down box #2 appears empty, so it makes no sense yet.
Only one instance of MKVCleaver at a time now. That's new. Is there a reason?
I don't know if they're all XP things but I'll play around some more later.
Thanks again for the hard work!
Old 17th May 2017, 02:13   #462  |  Link
sheck
sheck,
I included 64 bit log_rotate.exe by accident. It's not an essential part of MKVCLeaver and everything will still work.
A bug has been reported where files with an apostrophe in the name cause issues with the database. Apostrophe's have to be escaped in SQLite. Something I missed when learning SQLite.
The second dropdown box is empty because you haven't created any parameters yet. Click Menu->Parameters Config. It's in the help file.
The reason for one instance is because SQLite has a limitation of only one process being able to write to the database. To work with multiple instances I would have to write queue manager for SQLite queries. Something that I may do in the future, but it is a lot of work. I'm planing to attempt to make MKVCleaver multi threaded so a queue manager may not even be needed.
Please upload all files to ft.sapib.ca. Click Drop-off to upload files and follow the promts.
sheck is offline   Reply With Quote
Old 17th May 2017, 17:04   #463  |  Link
Tylerr
can you add title for subtitles to the custom filename options?
example from mediainfo:
Text #1
Format                      : ASS
Codec ID                    : S_TEXT/ASS
Codec ID/Info               : Advanced Sub Station Alpha
Compression mode            : Lossless
Title                       : Opening/Signs
Language                    : English
Default                     : Yes
Forced                      : No
Text #2
Format                      : ASS
Title                       : Vegapunk Subs
Language                    : English
Default                     : No
Forced                      : No
Text #3
Format                      : ASS
Title                       : Funimation Subs
Language                    : English
Default                     : No
Forced                      : No
Tylerr is offline   Reply With Quote
Old 18th May 2017, 15:38   #464  |  Link
sheck
Text #1
Format                      : ASS
Language                    : English
Default                     : Yes
Forced                      : No
Text #2
Format                      : ASS
Language                    : English
Default                     : No
Forced                      : No
Text #3
Format                      : ASS
Language                    : English
Default                     : No
Forced                      : No
I will look into this.
Old 19th May 2017, 22:24   #465  |  Link
sheck
v0.7.0.1 Realeased
Fixes:
* Fixed error with SQLite when files have apostrophe(s) in the file name.
* Fixed error when extracting simple chapters.
* Added back Send To menu in portable versions.
* Fixed error detection for chapters, tags and cues.
* Fixed log_rotate.exe hanging in some situations.
* Fixed json formatting when extracting time codes with default file naming options.
Old 22nd May 2017, 08:07   #466  |  Link
hello_hello
Thanks for the update.
Note for XP users..... so far, MKVCleaver seems to work happily with MKVToolnix 12.0.0 on XP even if versions of mkvtoolnix-gui.exe later than version 10.0.0 don't run on XP because they go "ding".
sheck,
As a side note, I have uBlock Origin installed in PaleMoon / Firefox as an AdBlocker. When I visit your site, I see your "please white list me" message even though I have in fact white listed blogs.sapib.ca, although after the page loads, if I then refresh it, I see the message replaced with an advertisement. I don't know who's fault it is, the adblocking detection method or uBlock Origin, but I thought I'd mention it.
Thanks again for the update!!
Old 23rd May 2017, 15:54   #467  |  Link
sheck
sheck,
Thx for letting me know. I had other users report the same, however, I can only sometimes reproduce the that behavior and so it is difficult to troubleshoot. I will continue trying to resolve it.
Old 24th May 2017, 06:15   #468  |  Link
hello_hello
Is it a caching issue, or maybe cookie related?
I have no idea, but I ask because I just went to your site and this time it went straight to displaying an ad, so it may relate to the fact I pretty much always clear cookies and temp internet files when closing the browser, something I haven't done for several days now, but as a rule I imagine I'd rarely visit your site without clearing everything in between. Maybe that'll help......
Edit. Then again...........
I tried a little experimenting, clearing temp files and cookies and restarting the browser but I couldn't duplicate the problem at all with Firefox. For Pale Moon, I could duplicate it fairly consistently, but it happened once even after I disabled uBlock completely and restarted the browser. Just see see, I disabled the "tell sites not to track me" option in PaleMoon's preferences and the "disable adblocker" message didn't appear after the next restart. Only problem is I've enabled both that option and uBlock again and now it's behaving as expected. I'm just seeing the ad even after clearing everything and restarting the browser. I don't know if that setting has anything to do with it, whether changing it and changing it back could make any difference, or whether it's just a huge co-incidence and the computer is messing with me, as they do, but that's what's happened so far.....
Old 29th May 2017, 21:54   #469  |  Link
o-l-a-v
Idea / Feature request:
- Batch remux mkv files, choose what files to keep / not to keep. Delete original mkv if success.
Use case:
1. I got 30 ish mkv files with two audio tracks, I only want to keep one of them. The second audio track is commentary, removing it will save me 100mb pr mkv.
2. "Update" your MKV's to the latest version, old versions might be lacking some features?
o-l-a-v is offline   Reply With Quote
Old 30th May 2017, 16:47   #470  |  Link
sheck
Use case:
Others had requested this as well, however, this is not a simple feature to add. MKVCleaver is an extractor and making it mux MKVs would mean I would have to write a batch muxer, which is a different application altogether, then join the two. I simply don't have the time at the moment to write a new application. Possibly in the future.
Old 30th May 2017, 16:48   #471  |  Link
sheck
v0.7.0.2 Realeased
Changes:
* Added [TrackType#] placeholder.
* Added auto recovery when MKVCleaver hangs.
* Added notification when MKVCleaver cannot connect to the Internet.
* Minor logging changes.
Fixes:
* Fixed “Check for Updates” was not following what’s in the ini file.
* Fixed MKVCleaver error when extracting by selecting tracks in the left pane.
* Fixed [Track#] being replaced by incorrect numbers in some cases.
Old 6th June 2017, 12:07   #472  |  Link
goLot
goLot is offline   Reply With Quote
Old 8th June 2017, 02:07   #473  |  Link
sheck
Originally Posted by goLot View Post
Can you post the full media info for that file ? Double click on the file name in the left pane.
Does it happen with any file or just that one ?
Old 8th June 2017, 02:18   #474  |  Link
sheck
I was able to reproduce this error only when I prevent mkvmerge from returning any data on query of a file.
Something on your system preventing MKVCleaver from reading mkvmerge CLI output. I've seen this before with Symantec security software. Possibly, MKVCleaver is being run in some sort of sandboxed environment.
Old 10th June 2017, 15:05   #475  |  Link
goLot
General
Unique ID: 235261905188639355233485557165109085697 (0xB0FDCB77DBAB058F8C28E66FD95D0601)
Complete name: K:\_k.720p\__tmp__\---pking\Shinjuku.Swan.II.2017.Japanese\Shinjuku.Swan.II.2017.720p.BluRay.x264-WiKi.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size: 4.80 GiB
Duration : 2 h 13 min
Overall bit rate : 5 155 kb/s
Movie name : Jubowo @ WiKi
Encoded date : UTC 2017-06-05 12:43:30
Writing application: mkvmerge v12.0.0 ('Trust / Lust') 64bit
Writing library: libebml v1.3.4 + libmatroska v1.4.5
Attachments: DFPHuaZongW5-B5 1.0.2005.12.28.ttf / 汉仪秀英体繁.ttf
Video
Format : AVC
Format/Info: Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames: 12 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 4 506 kb/s
Width: 1 280 pixels
Height : 538 pixels
Display aspect ratio : 2.40:1
Frame rate mode: Constant
Frame rate : 23.976 (24000/1001) FPS
Color space: YUV
Chroma subsampling : 4:2:0
Bit depth: 8 bits
Scan type: Progressive
Bits/(Pixel*Frame) : 0.273
Stream size: 4.19 GiB (87%)
Writing library: x264 core 129 r2245+704+36 8e61944 tMod+MixAQ [8-bit@4:2:0 X86_64]
Encoding settings: cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=4506 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1 / aq-strength=0.85 / aq-sensitivity=10.00 / aq-ifactor=1.00 / aq-pfactor=1.00 / aq-bfactor=1.00 / aq2=0
Language : Japanese
Default: Yes
Forced : No
Audio
Format : AC-3
Format/Info: Audio Coding 3
Format settings, Endianness: Big
Codec ID : A_AC3
Bit rate mode: Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions: Front: L C R, Side: L R, LFE
Sampling rate: 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth: 16 bits
Compression mode : Lossy
Stream size: 610 MiB (12%)
Language : Japanese
Service kind : Complete Main
Default: Yes
Forced : No
Text
Format : ASS
Codec ID/Info: Advanced Sub Station Alpha
Duration : 2 h 8 min
Bit rate : 87 b/s
Count of elements: 1711
Stream size: 81.9 KiB (0%)
Language : Chinese
Default: Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:12:42.761 : en:00:12:42.761
00:26:15.448 : en:00:26:15.448
00:34:42.205 : en:00:34:42.205
00:40:27.174 : en:00:40:27.174
00:52:57.674 : en:00:52:57.674
01:07:26.876 : en:01:07:26.876
01:17:39.363 : en:01:17:39.363
01:31:44.248 : en:01:31:44.248
01:45:00.377 : en:01:45:00.377
02:01:16.602 : en:02:01:16.602
02:08:14.269 : en:02:08:14.269
it happens sometimes, not just this one. (Since 0.7.0.0)
Not only WiKi's release.
Here's another:
This one, I use 'Duckweed.2017.乘風破浪' as the folder name in purpose. Chinese characters are included.
(Does MKVCleaver support UTF-8 or Unicode characters as filename?)
I changed the folder name to 'Duckweed.2017', MKVCleaver works fine again.
General
Unique ID: 242207038627877585463809162161532245660 (0xB63760FBE2DE9DE794D1AB00A24D169C)
Complete name: K:\_k.720p\__tmp__\---pking\Duckweed.2017.乘風破浪\Duckweed.2017.720p.BluRay.x264-WiKi.mkv
Format : Matroska
File size: 3.50 GiB
Duration : 1 h 41 min
Overall bit rate : 4 932 kb/s
Encoded date : UTC 2017-06-09 17:30:29
Video
Format : AVC
Bit rate : 4 294 kb/s
Width: 1 280 pixels
Height : 536 pixels
Frame rate : 24.000 FPS
Color space: YUV
Bit depth: 8 bits
Bits/(Pixel*Frame) : 0.261
Stream size: 3.04 GiB (87%)
Encoding settings: cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=2pass / mbtree=1 / bitrate=4294 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1 / aq-strength=0.85 / aq-sensitivity=10.00 / aq-ifactor=1.00 / aq-pfactor=1.00 / aq-bfactor=1.00 / aq2=0
Language : Chinese
Default: Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Bit depth: 16 bits
Stream size: 465 MiB (13%)
Language : Chinese
Default: Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info: UTF-8 Plain Text
Duration : 1 h 34 min
Bit rate : 37 b/s
Count of elements: 1407
Stream size: 26.4 KiB (0%)
Title: Simplified
Language : Chinese
Default: Yes
Forced : No
Text #2
Format : UTF-8
Bit rate : 37 b/s
Title: Traditional
Language : Chinese
Default: No
Forced : No
Menu
00:05:20.791 : en:00:05:20.791
00:13:02.166 : en:00:13:02.166
00:17:07.291 : en:00:17:07.291
00:22:44.458 : en:00:22:44.458
00:27:21.125 : en:00:27:21.125
00:31:40.291 : en:00:31:40.291
00:35:47.708 : en:00:35:47.708
00:41:04.625 : en:00:41:04.625
00:43:53.833 : en:00:43:53.833
00:47:14.375 : en:00:47:14.375
00:56:54.791 : en:00:56:54.791
01:00:44.875 : en:01:00:44.875
01:04:25.291 : en:01:04:25.291
01:10:06.916 : en:01:10:06.916
01:14:43.958 : en:01:14:43.958
01:23:15.833 : en:01:23:15.833
01:27:53.125 : en:01:27:53.125
01:30:42.333 : en:01:30:42.333
01:33:43.416 : en:01:33:43.416
this one, folder name has only ANSI characters, same as it's filename.
p.s.
I've tried it again with KIS disabled.
Old 10th June 2017, 21:30   #476  |  Link
sheck
I set up the same directory structure on my machine and was not able to reproduce the error even with the Chinese characters. Everything was extracting fine.
Can you please run the following command and post the output ?
1. Create a command.json file somewhere. C:\Temp for example. Open it with Notepad or other text editor and paste the text below. The only thing you have to change it the path to the mkv file with actual path to the file. Replace all \ in the file with \\.
Obviously, use the mkv file that causes that error.
"--ui-language",
"en",
"-J",
"full path to the mkv file"
2. Open a command line window and then cd into the directory where MKVToolNix is installed. Then run the following:
mkvmerge @"C:\Temp\command.json"
Assuming that your json file is in C:\Temp.
Then just post the output here.
Old 11th June 2017, 01:57   #477  |  Link
goLot
C:\Program Files\MKVToolNix>mkvmerge @"C:\tmp\command.json"
"attachments": [
"content_type": "application/x-truetype-font",
"description": "",
"file_name": "DFPHuaZongW5-B5 1.0.2005.12.28.ttf",
"id": 1,
"properties": {
"uid": 4362650260188525481
"size": 4134208
"description": "",
"file_name": "汉仪秀英体繁.ttf",
"id": 2,
"properties": {
"uid": 13901122490794128034
"size": 4342760
"chapters": [
"num_entries": 12
"container": {
"properties": {
"container_type": 17,
"date_local": "2017-06-05T20:43:30+08:00",
"date_utc": "2017-06-05T12:43:30Z",
"duration": 7999424000000,
"is_providing_timecodes": true,
"muxing_application": "libebml v1.3.4 + libmatroska v1.4.5",
"segment_uid": "b0fdcb77dbab058f8c28e66fd95d0601",
"title": "Jubowo @ WiKi",
"writing_application": "mkvmerge v12.0.0 ('Trust / Lust') 64bit"
"recognized": true,
"supported": true,
"type": "Matroska"
"errors": [],
"file_name": "K:\\_k.720p\\__tmp__\\---pking\\Shinjuku.Swan.II.2017.Japanese\\Shinjuku.Swan.II.2017.720p.BluRay.x264-WiKi.mkv",
"global_tags": [],
"identification_format_version": 6,
"track_tags": [],
"tracks": [
"codec": "MPEG-4p10/AVC/h.264",
"id": 0,
"properties": {
"codec_id": "V_MPEG4/ISO/AVC",
"codec_private_data": "01640029ffe1001967640029ac520d0140117e48400000fa40002ee023c60c636001000768e8ce0acf23c06ffa7f00",
"codec_private_length": 47,
"default_duration": 41708333,
"default_track": true,
"display_dimensions": "1280x538",
"enabled_track": true,
"forced_track": false,
"language": "jpn",
"minimum_timestamp": 0,
"number": 1,
"packetizer": "mpeg4_p10_video",
"pixel_dimensions": "1280x538",
"uid": 1
"type": "video"
"codec": "AC-3/E-AC-3",
"id": 1,
"properties": {
"audio_channels": 6,
"audio_sampling_frequency": 48000,
"codec_id": "A_AC3",
"codec_private_length": 0,
"default_duration": 32000000,
"language": "jpn",
"number": 2,
"uid": 9562527780952643742
"type": "audio"
"codec": "SubStationAlpha",
"id": 2,
"properties": {
"codec_id": "S_TEXT/ASS",
"codec_private_data": "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",
"codec_private_length": 1267,
"language": "chi",
"minimum_timestamp": 5000000000,
"number": 3,
"text_subtitles": true,
"uid": 15280138310350355339
"type": "subtitles"
"warnings": []
Old 11th June 2017, 02:09   #478  |  Link
goLot
"attachments": [
"description": "",
"id": 1,
"properties": {
"size": 4134208
"description": "",
"id": 2,
"properties": {
"size": 4342760
"chapters": [
"num_entries": 12
"container": {
"properties": {
"recognized": true,
"supported": true,
"type": "Matroska"
"errors": [],
"global_tags": [],
"track_tags": [],
"tracks": [
"id": 0,
"properties": {
"language": "jpn",
"number": 1,
"uid": 1
"type": "video"
"id": 1,
"properties": {
"language": "jpn",
"number": 2,
"type": "audio"
"id": 2,
"properties": {
"language": "chi",
"number": 3,
"type": "subtitles"
"warnings": []
Old 11th June 2017, 18:16   #479  |  Link
goLot
"attachments": [
"description": "",
"id": 1,
"properties": {
"size": 4134208
"description": "",
"id": 2,
"properties": {
"size": 4342760
"chapters": [
"num_entries": 12
"container": {
"properties": {
"recognized": true,
"supported": true,
"type": "Matroska"
"errors": [],
"global_tags": [],
"track_tags": [],
"tracks": [
"id": 0,
"properties": {
"language": "jpn",
"number": 1,
"uid": 1
"type": "video"
"id": 1,
"properties": {
"language": "jpn",
"number": 2,
"type": "audio"
"id": 2,
"properties": {
"language": "chi",
"number": 3,
"type": "subtitles"
"warnings": []
Old 7th July 2017, 15:55   #480  |  Link
Tylerr
did you look into it?
batch extract, extractor, matroska, mkv, mkv batch, mkv decoder, mkvextract
