5th June 2018, 11:41 | #542 | Link |
VirtualDub2; select a range from one keyframe to another, to possibly avoid recompresion (using "Video - Direct Stream Copy" mode). BTW, which video format is contained? (File - Information)
5th June 2018, 11:59 | #544 | Link |
avi format. the videos are not captured by me from VHS, and there is something wrong with them....i just want to encode them, to fix the picture if i can and make them with smaller size.
VirtualDubMod 1.5.10.2 says: Code:
VirtualDub cannot decode 4:2:2 Motion JPEG frames with image widths or heights that are not multiples by 16. EDIT: video sample 3sec https://we.tl/2Hr8YMgkDk Last edited by heartagram; 5th June 2018 at 12:13. |
5th June 2018, 12:29 | #545 | Link |
VirtualDub2 is not VirtualDubMod...
_ Frequently asked question: smart deinterlacers with motion prediction (like QTGMC) need steady and continuous motion; cartoons have discrete motion (a.k.a. "Stop Motion"). QTGMC is not suitable for this kind of material because it will predict motion wrong. Well, in this special case, one frame would have told us enough... it just had to be visible. Unfortunately, I don't know a "cartoon-safe" deinterlacer right now... Last edited by LigH; 5th June 2018 at 12:31. |
5th June 2018, 15:42 | #547 | Link |
I believe cartoons may get an advantage from a specific kind of decimation (forcing the TV-common frame rates down to cartoon-original low frame rates by combining and averaging the most similar fields). Such issues will have their own topics already.
5th June 2018, 18:55 | #548 | Link |
sanimebob
See My Avisynth Stuff |
6th June 2018, 10:22 | #550 | Link | |
https://forum.doom9.org/showpost.php...&postcount=547 i did you scipt and here is the result - - source -with tfm, assumetff,tdeint |
6th June 2018, 19:43 | #552 | Link |
Please post the complete script. I saw nothing like that when using this script:
AVISource("balu-clips-no-deinterlace.avi") AssumeTFF() tdeintted = QTGMC(FPSDivisor=2) tfm(CThresh=5,clip2=tdeintted) return last https://www.sendspace.com/file/z802gg |
6th June 2018, 20:04 | #553 | Link |
your sample looks great!
This is the script i tried Code:
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\TIVTC\x86\TIVTC.dll") DirectShowSource("D:\anime\A Bad Reflection on You 2.avi") # Crop(20, 2, -22, -10).LanczosResize(720,576) AssumeTFF() tdeintted = QTGMC(FPSDivisor=2) tfm(CThresh=5,clip2=tdeintted) return last Last edited by heartagram; 6th June 2018 at 20:16. |
6th June 2018, 20:16 | #554 | Link | |
6th June 2018, 20:21 | #555 | Link |
thanks
this seems to work fine now. what do you think? i had to add converttorgb32 because there was issue with the colors... in that case crop function seems to be the problem, adding converttorgb32 fix the problem. i dont know if this is ok. Code:
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\TIVTC\x86\TIVTC.dll") DirectShowSource("D:\anime\A Bad Reflection on You 2.avi") # AssumeTFF() tdeintted = QTGMC(FPSDivisor=2) tfm(CThresh=5,clip2=tdeintted) Crop(20, 2, -22, -10).LanczosResize(720,576) ConverttoRgb32 return last Last edited by heartagram; 6th June 2018 at 23:46. |
7th June 2018, 19:56 | #556 | Link |
Don't use DirectShowSource as your source filter if you can avoid it. In your case, the built-in AviSource is much better.
Why was the video 720x540 if the source was a VHS tape? Why wasn't it captured as 720x576 to begin with? I think you said earlier you didn't capture the tape? If you know the capper, you should advise him. By cropping and resizing as you did (for DVD, I presume?), you've changed the aspect ratio. Maybe you don't consider that a problem, not sure. |
7th June 2018, 20:21 | #557 | Link |
AviSource gives an error. something like "Avisource couldnt locate a decompressor for fourcc mjpg". (using virtualdubmod 1.5.10 to load and preview)
I'll check google/doom9 and try to solve it. Yeah i met the guy on the internet, we shared some anime videos at that time. I told him that this captures could be done much better. ALso i asked him if its possible to send me the tapes because I had VHS recorder with internal TBC plus i was looking to buy external tbc, but he refused my offer... No i'm not planning to make dvd. Some of the series has 2gb filesize... as i said i'll just try to make them smaller and keep the quality or make it better! Thanks to you it will work out! btw should i leave it 720x540? I was thinking it is good idea to fix the resolution, nothing more.... ALso i'm using Megui loaded with x264 profiles, there is anime toons profile which im planing to give a try! any ideas for the encoding option? Last edited by heartagram; 7th June 2018 at 20:32. |
7th June 2018, 22:00 | #559 | Link |
Cedocida is a DV codec. Wrong example.
Roelofs Coaching |
7th June 2018, 22:13 | #560 | Link |
Sorry, I had in mind that it is a combined codec... sieve mind.
Well, a quite good and free MJPG VfW codec would be part of ffvfw in ffdshow; but in general, ffdshow is obsolete as DirectShow filters. Maybe via custom installation. |
