3rd February 2016, 10:47 | #4921 | Link | ||
3rd February 2016, 19:40 | #4923 | Link | |
DVD Magistrate
can we get a check box for:
4th February 2016, 09:18 | #4925 | Link |
Latest release on SourceForge: Stable build 2624 (extract the ZIP archive to a directory outside the UAC protected "Program Files" directory branch).
After unpacking and starting, you may want to change the updater in the configuration to the development server. Stable updates are rare. Last edited by LigH; 4th February 2016 at 09:23. |
4th February 2016, 14:26 | #4926 | Link | |
thank you very much, it worked |
4th February 2016, 17:52 | #4927 | Link |
I have this error now and I don't know how to solve this before I formatted my pc, it was working well, also I was using the megui that I installed with offline .exe installer, this latest version in zip file doesn't working for my video projects I installed everything correctly, avisynth, codec mega pack etc, it was really working flawless before :/
4th February 2016, 18:09 | #4928 | Link | |
4th February 2016, 21:15 | #4929 | Link |
yes, I tried, it says the same can't do my projects anymore, I can't update the offline installer version of meGUI, I updated this zip version as Ligh said but now I get this error on my videos, also I checked my Avi script text, there was no mistake on it.. I hope update server can go up again so I can use offline installer version of MeGUI, btw my OS is win10 home 64bit.. before was same too..
4th February 2016, 23:43 | #4930 | Link |
Where did you install MeGUI to?
Hopefully not under C:\Program Files... The most common reason not being able to update and even to run a conversion may be that the UAC blocks exchanging of files in subdirectories there. But to be certain: |
5th February 2016, 10:44 | #4931 | Link | |
as for zip version, I extracted it to D drive where my games data files are, it updated from developer server, but keeps giving this avisynth error I guess this is the log file, sorry I am very noob at this Last edited by adem940; 5th February 2016 at 10:53. Reason: forgot to post log file. |
5th February 2016, 10:54 | #4932 | Link |
Which error? Did you quote it anywhere? Did you post a log file anywhere?
Recommendable steps: Start MeGUI; try to provoke the error message with few steps; quit MeGUI as soon as it popped up; look into MeGUI\logs for the latest logfile, copy its content from a text editor, and paste it either here in a CODE bbCode block or in a "pastebin" service. Attaching it to the post will waste a bit time, moderators need to approve attachments. |
5th February 2016, 10:57 | #4933 | Link | |
5th February 2016, 11:21 | #4935 | Link | |
https://goo.gl/8ko8u1 there. this was working before I formatted my pc and before I was using offline installer version of MeGUI.. maybe it will work again when update servers are alive |
5th February 2016, 11:26 | #4936 | Link |
Redirection to MEGA ... for a few hundred bytes?
SetMemoryMax(512) SetMTMode(3,4) PluginPath = "C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\" LoadPlugin(PluginPath+"svpflow1.dll") LoadPlugin(PluginPath+"svpflow2.dll") Import(PluginPath+"InterFrame2.avsi") DirectShowSource("C:\Users\Adem\Desktop\no-name-anime.mkv", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001).ConvertToYV12() SetMTMode(2) #deinterlace #crop #denoise #resize InterFrame(Cores=4, GPU=True) I doubt MeGUI ships an own copy of svpflow?.dll and InterFrame2.avsi in its own plugins directory. And once again, people still prefer DirectShowSource, despite all warnings about possible unexpected low-quality filtering in DirectShow filter paths and recommendations to prefer L-SMASH Works or FFMS2 instead for MKV sources. It may be convenient if one suspects VFR, but that needs to be proven first, no need to fix problems which may not even exist. Last edited by LigH; 5th February 2016 at 11:32. |
5th February 2016, 11:33 | #4937 | Link |
Couple of things:
1. The log says it's using Avisynth 2.6.0.6 which is not SEt's MT version. The SetMTMode statements in your script should produce an error message. 2. I'd steer clear of DSS, LSmash is a much better choice these days. |
5th February 2016, 11:36 | #4938 | Link | |
in script configuration window, directshowsource is grayed out, I can't choose it, before my pc format, I had it checked, now I can't check it cause it is gray, as I said I never used zip version of MeGUI, always used offline installer, updated and did my projects... |
5th February 2016, 11:39 | #4939 | Link | |
how to change those filters? sorry I don't know |
5th February 2016, 11:42 | #4940 | Link |
Oh, I found the log. For some reason, I don't see images on tinypic as inline images because they get wrapped with a whole ad-loaded HTML page when deep-linked.
_ Not using AviSynth MT when your script contains SetMTMode() functions will certainly result in errors. If you enabled MeGUI always using its internal AviSynth, this is not AviSynth MT; you would have to disable that and use the substitute MT avisynth.dll in your Windows\SysWOW64 directory. To test this suspected reason, comment out both lines with SetMTMode. _ To use another source filter instead of DirectShowSource, you could use the MeGUI tool "AVS Script Creator", open the MKV, and select the "Indexer"; the new generated AviSynth script will contain the code used to open the MKV with LwLibavVideoSource or FFVideoSource. Try to substitute the DirectShowSource line in your script with this entry (and the related LoadPlugin + Import if present). Last edited by LigH; 5th February 2016 at 11:47. |
