15th November 2020, 15:58 | #60702 | Link | |
16th November 2020, 21:15 | #60703 | Link |
Hi guys,
It's a bit OT, yestrerday i got a rx5700 xt but seems i lost totally deinterlacing capabilities, at the start i thought it was Madvr but even with vmr9 it's the same ..... anyone have similar experience with that card ? I noticed that before with rx460 i had more option under driver video custom setting, now there is only brightness. Already tried with DDU thank you for any help
AMD Ry 1500x - 8GB - RX460 4GB TV Philips 55pus6501+ Marantz 1608 avr WIN10(1903) 4K/444RGB Mediaportal - Mpc-hc MADVR-D3D11/10bit |
17th November 2020, 07:57 | #60704 | Link |
I finally obtained a 3090. It is crazy fast for madVR.
I can double 4K -> 8K -> 4K with NGU very high -> SSIM in 26ms at ~1900 MHz. Not that I want to but I can. Maxes out at 11808 MB of GPU memory used at these pointless settings. Try using DXVA2 or software decoding in LAV. Probably better to ask in that thread.
madVR options explained Last edited by Asmodian; 17th November 2020 at 08:00. |
17th November 2020, 09:14 | #60706 | Link | |
beware deint was broken with polaris too but they fixed it ~6 month later. BTW they had the same issue where is was using bilinear as deint but for some reason it got worse with navi and now is just combing most of the time. could be fixed next version could be never fixed. this is BTW by far not the only thing that's broken. |
17th November 2020, 09:37 | #60707 | Link |
indeed, SDR EVR renderer still broken and rendering in wrong colour space, still have to set up a 235-255 shader toggle but I rarely use this, its just annoying its been broken so long, cant think of anything else broken right this minute though that affects MADVR.
17th November 2020, 12:24 | #60708 | Link | |||
17th November 2020, 14:30 | #60709 | Link | |
This is really disappointing, my HD 4650 had the best hardware deinterlacing I've seen, even better than my 1050 Ti. This rules out any update to an AMD card for me whatever perf/watt they have as I still watch a lot of 1080i. Edit: read in the LAV thread that mrmojo666's issue doesn't happen with MS Films & TV app. Looks like AMD doesn't care anymore about backward compatibility with DXVA2.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 Last edited by el Filou; 17th November 2020 at 14:42. |
17th November 2020, 17:19 | #60711 | Link |
Is smoothmotion working without issues in the new "beta" release?
http://madshi.net/madVRhdrMeasure114.zip |
17th November 2020, 19:27 | #60712 | Link |
He said it is fixed and no one complained yet (I don't use it). But it's a time limited version.
17th November 2020, 21:40 | #60713 | Link | |
Not a solution, just to try to isolate the issue. I also use the report BT2020 flag and I don't have this issue in 8bits with the latest drivers (on 3090 see details in my sig).
17th November 2020, 22:10 | #60714 | Link |
I must say a 3770K paired with a 3090 is an awesome HTPC.
madVR options explained |
17th November 2020, 22:21 | #60715 | Link |
i guess anything paired with a 3090 is an awesome HTPC
17th November 2020, 22:34 | #60716 | Link |
My ryzen 5950X arrives this week-end, it was ordered on launch day but I missed the first batch so was on a waiting list
I have everything else ready (ASRock X570 Creator, 32gb RAM, 2 x 2TB Corsair PCI 4.0 SSDs etc). Not really a HTPC though, it's going to be primarily an editing / video creation workstation. Gaming and HTPC duties will be on the side The 3770K is still a great CPU though for a HTPC. I would have kept it if I didn't have other reasons to upgrade. It will end up in the family PC.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 18th November 2020 at 01:09. |
18th November 2020, 02:08 | #60718 | Link |
Yes SM is working well. v114 working very nice. Madshi said he'd release a new version before it stops working in March. You could also change the date on the PC and continue using v114 btw.
My HT: JVC X790R | 120" CineWhite | madVR 169 RTX 2070S | mpv 0.36.x | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe | 4 x ADX Maximus w/ Dayton Audio SA230 | 40" HDTV w/ MoviePosterApp |
18th November 2020, 10:53 | #60719 | Link | |
it's over an year now and they didn't even notice... if i have to prove it yet again i can do it. |
18th November 2020, 12:08 | #60720 | Link | |
That's really interesting! I'll give 4k doubling a try on my 1060 6GB
