17th July 2021, 12:11 | #7001 | Link | |
1) Megui -> Options -> Extended -> Auto Update -> Use development update server -> Save Megui -> Tools -> Update -> Show all packages -> Enable all packages -> Update MeGUI: 2913 to MeGUI: 2924 2) Disable Prefetch(6) useless for PointResize and exigent for RAM resources.
19th July 2021, 02:43 | #7002 | Link | |
Using NVenc with Handbrake works without problem. However using standard CPU encoding with HB caused a crash of that program as well 38% through the process. The only other thing i've not tested at this point is doing all this in Windows 10 rather than Windows 7. W7 is my daily driver for older games and a few other things. Last edited by MrBonk; 19th July 2021 at 05:13. |
19th July 2021, 10:50 | #7003 | Link | |
Must work in W7, the last test if you already preserve the "B:\2f11eawv.acl\taa.mkv.avs" file, the taa.mkv and B:\MEGUI2\
Create and run this test.bat file: Code:
"B:\MEGUI2\tools\x265\avs4x26x.exe" -L "B:\MEGUI2\tools\x265\x64\x265.exe" --preset slow --crf 16.0 --sar 1:1 -o "B:\2f11eawv.acl\taa_VideoN.hevc" "B:\2f11eawv.acl\taa.mkv.avs" pause Work fine in my PC. [EDIT]I forget other test because you have: Quote:
The included AviSynth+ version is 3.5.1
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 19th July 2021 at 11:07. Reason: add info |
19th July 2021, 21:11 | #7004 | Link |
Mux mp4 oneclick encoder
I use megui to encode files to x264. most of the files I get are in an mkv container.
Every time i try to encode mkv file to mp4 I get a "No container type could be found that matches the list of acceptable types in your chosen one click profile. Your restrictions are now being ignored." error Anyone any clue as to what might be wrong? There is no error listed in the log if any one asks... it just ignores my mp4 setting and reencodes to mkv. Thank you guys and have a nice day. |
19th July 2021, 23:26 | #7005 | Link | |
Remux that mkv to mp4 is not posible because AFAIK mp4 container don't support ASS subtitles.
20th July 2021, 02:55 | #7006 | Link | |
I reduced the clock by 50Mhz and suddenly no crashes... Was able to complete encoding with no issues on the normal up to date dev server version I normally used before. |
20th July 2021, 12:29 | #7007 | Link |
@videoh new DGIndex 2.0.0.5 error with megui. I think you change commands in 2.0.0.5, old ver still use normally. Megui still use old commands
https://sourceforge.net/p/megui/bugs/963/?limit=25#5d9c |
21st July 2021, 01:42 | #7009 | Link | |
Useful n00b
21st July 2021, 09:48 | #7010 | Link | |
You can add ass or srt files (soft mux not burn) to mp4 using mp4box included in MeGUI: MeGUI -> Tools -> Muxer -> MP4 Muxer Also with ffmpeg: ffmpeg -i infile.mp4 -i infile.srt -c:v copy -c:a copy -c:s mov_text outfile.mp4
28th July 2021, 15:04 | #7012 | Link |
L-SMASH Source 20210811
https://github.com/HomeOfAviSynthPlu...Works/releases Last edited by kedautinh12; 15th August 2021 at 04:30. |
2nd August 2021, 13:15 | #7013 | Link |
Hi guys..
about this: https://forum.doom9.org/showpost.php...postcount=6853 the bug is still there.. any chance to fix this? it's annoying to always check the destination file to be sure that has alla the subtitles.. |
15th August 2021, 04:30 | #7015 | Link |
ffms2_1c6169a
https://forum.doom9.org/showthread.p...99#post1949799 |
15th August 2021, 08:09 | #7016 | Link |
@Bazzu85:
There is no free EAC3 encoder supported by MeGUI I know of; I don't remember EAC3 being supported ever, and I know FFmpeg has some troubles with a few variants of this format (especially Blu-ray specific with 6+2 subchannels). |
15th August 2021, 10:09 | #7017 | Link |
I found a workaround to encode to eac3 with MeGUI:
In Audio encoding -> Encoder settings -> select a FFmpeg A-C3 preset and 'Config' (see the image): 1) Config like you want but ffmpeg can only create until 5.1 (and not Bluray compliant like LigH say) 2) In 'Extra' tab add: -acodec eac3 That override the default preset from ac3 to eac3 3) Create the new preset with a new name, for instance 'eac3' The new preset 'FFmpeg A-C3: eac3' can be selected after also in One-Click process, and the full output seems correct with EAC3 audio. When selected only for audio conversion the output file must have .ac3 extension, but internally is EAC3 and you can modify the extension without problems.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 15th August 2021 at 10:13. Reason: typo |
15th August 2021, 18:36 | #7018 | Link |
Having problems with indexing vob files, getting "Couldn't open input file in HIDE mode! Exiting...". It's probably after an update to dgindex 2.0.0.5. Haven't used MeGUI in a while, it seems I had dgmpgdec-158-32 before the update.
In one case a fast exit with an error: Code:
[Error] Log for job1 (idx, VTS_01_1.VOB -> 1_VTS_01_1.d2v) --[Information] [2021-08-15 19:08:59] Started handling job --[Information] [2021-08-15 19:08:59] Preprocessing --[Information] [2021-08-15 19:08:59] Job command line: "C:\Users\username\PortableApps\MeGUI\tools\dgindex\dgindex.exe" -SD=< -AIF=<C:\Temp\1\VTS_01_1.VOB< -OF=<C:\Temp\1\1_VTS_01_1< -FO=0 -exit -hide -OM=2 --[Information] [2021-08-15 19:08:59] Process started --[Information] [2021-08-15 19:08:59] Standard output stream --[Information] [2021-08-15 19:08:59] Standard error stream --[Error] [2021-08-15 19:09:01] Process exits with error: 1 --[Information] [2021-08-15 19:09:01] Job completed Code:
[Error] Log for job3 (idx, 2_VTS_01_1_1.VOB -> 2_VTS_01_1.d2v) --[Information] [2021-08-15 19:09:46] Started handling job --[Information] [2021-08-15 19:09:46] Preprocessing --[Information] [2021-08-15 19:09:46] Job command line: "C:\Users\username\PortableApps\MeGUI\tools\dgindex\dgindex.exe" -SD=< -AIF=<C:\Temp\2\2_VTS_01_1_1.VOB< -OF=<C:\Temp\2\2_VTS_01_1< -FO=0 -exit -hide -OM=2 --[Information] [2021-08-15 19:09:46] Process started --[Information] [2021-08-15 19:09:46] Standard output stream --[Information] [2021-08-15 19:09:46] Standard error stream --[Error] [2021-08-15 19:09:52] Process exits with error: 0xC0000409 STATUS_STACK_BUFFER_OVERRUN (-1073740791) --[Information] [2021-08-15 19:09:52] Job completed I just replaced everything in the dgindex folder with the old 1.5.8 version and everything worked OK. Hopefully it will update fine still, but it would be nice with a simple way to roll back updates. Maybe there is...? |
17th August 2021, 05:41 | #7020 | Link |
@videoh, can you share older ver in here??
http://rationalqm.us/dgmpgdec/ |
