31st December 2012, 01:02 | #2801 | Link |
2255 [AVS Script Creator] resize is enabled by default in the profiles (only for new profiles) [AVS Script Creator] suggest resolution is automatically pre-selected when doing a resize [AVS Script Creator] DAR changes also triggers a recalc of the "Aspect Ratio Error" [AVS Script Creator] avoid upsizing (if disallowed) when "Clever (TM) anamorphic encoding" is used [AVS Script Creator] some minor cosmetics / changes 2254 [Update] fixed a crash if the proxy has been enabled without server address |
31st December 2012, 02:03 | #2802 | Link | |
(576/768)*640=480 or (720/576)*(16/15)*480 = 640 However you do it, it comes out exact. StaxRip and the Yoda Resize Calculator both agree. MeGUI has always seemed to give slightly different results to other programs. Generally only by a couple of tenths of a percent I think, but I'm sure it always has. Many times I've opened a "strict" anamorphic encode and compared it to the original DVD and thought the aspect ratio was off by a pixel or two. I'd always assumed it's the way MPC-HC resizes, but now..... There's another little oddity in the "trust what MeGUI is telling me" department. It seems to happen regularly when opening video containing square pixels (I haven't played with anything else much yet). For example I just opened a 640x480 AVI and enabled resizing but left it on 640x480. MeGUI displays a slight aspect error (it's only around 0.16% but it's there). The only way to correct it is to manually select the input aspect ratio (1.333) and then adjust the resizing or cropping. Once you return the the cropping back to zero or the resizing back to 640x480, MeGUI will then display a zero aspect error as it should. I think maybe there's too much rounding happening when calculating the input aspect ratio although I'm not sure how it works. For me, opening a 704x384 AVI displays an input aspect ratio of 1.833, which is correct, but when enabling resizing it displays a 0.142% aspect error at 704x384. Changing the input display aspect ratio to 1.832 (which unless I'm going mad MeGUI actually did itself once) displays the same aspect error at 704x384. With an input aspect ratio of 1.834 the aspect error changes to 0%, but the problem is that's not the input aspect ratio MeGUI chooses when opening the file. Once again too, changing the input aspect ratio has no effect on the aspect error being displayed until cropping or resizing has been adjusted. Cheers. Edit: I just saw your previous post. I see input aspect ratio changes now cause the aspect error to be recalculated. Last edited by hello_hello; 31st December 2012 at 02:14. |
31st December 2012, 02:43 | #2803 | Link | ||
Please try 2256 and let me now if everything is fine. |
31st December 2012, 04:09 | #2804 | Link |
Anime addict
How its possible??
Yoda calc and me, obtain the same result than is very different to showed by megui. EDIT: Ok http://forum.doom9.org/showthread.php?t=22497
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 31st December 2012 at 04:26. |
31st December 2012, 10:45 | #2805 | Link |
MeGUI calculates it in this way:
AR Error = 1-((Input Width*Output Height)/(Output Width*Input Height)) (which is the same as in http://forum.doom9.org/showthread.php?p=130085#post130085) Which is in this case: AR Error = 1-((714*480)/(704*480))=1-(714/704)=-0,014204545454545=-1,4204545454545% You and Yoda are calculating it: AR Error = 1-((704*480)/(714*480))=1-(704/714)=0,0140056022408964=1,40056022408964% Which one is correct? You can say (with simplified values) that 100 is 33% larger than 75 - and 75 is 25% smaller than 100. So both are showing a correct aspect ratio error but the point of view is different. Staxrip for example is using the same as MeGUI. Which is the most common point of view? I can change it if required. Last edited by Zathor; 31st December 2012 at 10:51. |
31st December 2012, 11:37 | #2806 | Link |
Hi Zathor,
Here is the patch to use system proxy if a username is not supplied: http://pastebin.com/yaEMEcUc I have tested this here at work this morning and it works Of course this may require a stable build release otherwise those who rely on it won't be able to get the revision which fixes it |
31st December 2012, 11:45 | #2807 | Link |
Thanks - does this also work when using a proxy without user name / password? Or do I need to include a new setting if no credentials, specified credentials or default credentials should be used?
31st December 2012, 11:52 | #2808 | Link | |
Perhaps we should have an additional checkbox "Use System Proxy" Actually, thinking about it, the system credentials include the URI of the proxy so it needs to work differently anyway. Should be: Code:
Use Proxy?:- Yes: - Use System Proxy?:- Yes:- use CredentialCache.DefaultCredentials No: prompt for url/port/uid/pwd EDIT: I've found the MeGUISettings class - I'll have a play Last edited by Shevek; 31st December 2012 at 11:57. |
31st December 2012, 12:15 | #2810 | Link |
Maybe a combobox with all the 4 settings (no proxy, system proxy, proxy with and without user/pwd)
But isn't there a way to remove this whole part in the settings and use the system proxy (= IE proxy) setting all the time? |
31st December 2012, 12:45 | #2812 | Link | ||
Great, I now have the latest code, tx! |
31st December 2012, 15:04 | #2814 | Link |
Hi Zathor,
It will need to be the multiple options as there could be some users out there who use proxy servers which require a separate log in from their system account (i.e. windows clients on a network that uses a unix/linux proxy server) Proposed solution: Replace global setting "usehttpproxy" with an enum setting "HttpProxyMode": public enum ProxyMode { None = 0, SystemProxy = 1, CustomProxy = 2, CustomProxyWithLogin = 3 } On Settings form remove the checkbox and replace with drop down with options from the enum None, SystemProxy = address/port/uid/pswd disabled CustomProxy = address,port enabled, uid/pswd disabled CustomProxyWithLogin = address/port/uid/pswd enabled Logic in UpdateCacher.cs and UpdateWindow.cs updated to build proxy settings based on HttpProxyMode How does that sound? I'll get on with coding this and provide a patch. Let me know if you want anything tweaked. |
31st December 2012, 16:10 | #2816 | Link |
Having problems opening the Settings form
Could not find type 'MeGUI.core.gui.TargetSizeSCBox'. Please make sure that the assembly that contains this type is referenced. If this type is a part of your development project, make sure that the project has been successfully built using settings for your current platform or Any CPU. I'm using VS2010 on Windows 7 x64 (both fully patched) |
31st December 2012, 17:00 | #2819 | Link | |
Anime addict
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
31st December 2012, 17:29 | #2820 | Link |
Hi Zathor,
Here is the patch: http://pastebin.com/BW9dmF9k It should be applied in the trunk folder It includes a new helper class core/util/HttpProxy.cs as the proxy is used in both core/gui/UpdateCacher.cs and core/gui/UpdateWindow.cs |
