25th July 2015, 19:48 | #4601 | Link | |
26th July 2015, 11:30 | #4602 | Link | |
LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") Odd....... I'm not sure I recall MeGUI ever having used a C plugin version of ffms2, but maybe my memory is bad as I found the following in the changelog: 2439 [FFMS Indexer] automatically switch to LoadCPlugin if required 2450 [FFMS Indexer] defaults to LoadPlugin if LoadCPlugin is also possible Maybe MeGUI is incorrectly assuming it needs to switch to using LoadCPlugin in your case, but if so, I don't know why. Edit: I just checked all the ffms2 versions in MeGUII's update_cache folder. The only C-plugin version I have in that folder is ffms2 r809 which is dated Dec 2013. None of the ffms2 versions since then (five more recent) appear to be C-Plugins. Not that it answers your question.... Last edited by hello_hello; 26th July 2015 at 11:42. |
27th July 2015, 10:19 | #4603 | Link |
Hi
I did try it. Default MeGUI script was Code:
LoadCPlugin("C:\Program Files (x86)\MeGUI\tools\ffms\ffms2.dll") Now I did try this: Code:
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\ffms\ffms2.dll") Seems MeGUI create wrong call in script. For me if no quality difference between L-SMASH and FFMS does not matter which used. Thanks for all you to clarify this issue. bye szabi |
27th July 2015, 10:26 | #4604 | Link |
The very first successful call of this script will have indexed the keyframes in the video stream, and possibly block starts in audio streams if audio processing was involved.
1st August 2015, 09:49 | #4607 | Link |
QAAC is still only a CLI frontend not containing any encoder; the Apple libraries are the place where the work is done.
You don't need to have any Apple application installed. Use makeportable to unpack the DLLs from a recent itunes6464setup.exe and place them with the qaac.exe, possibly even replace one huge DLL with a tiny dummy. Last edited by LigH; 1st August 2015 at 10:45. |
1st August 2015, 10:34 | #4608 | Link |
Downloaded makeportable from the same site aa qaac.
Placed the quicktime file in the same folder as makeportable.bat. Double clicked it and it extracted the necessary files which I then copied to qaac Me GUI folder. Works just fine |
1st August 2015, 12:36 | #4610 | Link | |
6th August 2015, 01:09 | #4615 | Link | |
Has anybody managed to get KNLMeansCL working with MeGUI's OCE?
Running W10 Pro FULL LOG
A Man Eating Duck Last edited by tebasuna51; 6th August 2015 at 10:16. Reason: code -> quote |
6th August 2015, 07:10 | #4616 | Link |
MeGUI may use its own directory of AviSynth plugins. So don't rely on autoloading from your standard plugins directory (MeGUI's AviSynth may ignore that); explititly use "LoadPlugin"!
6th August 2015, 08:28 | #4617 | Link | ||
I've given load plugin a go and it still fails when it tries to encode the video. It does make it though the oneclick task where is uses the same avisynth script though which is strange.
OCE task that completes Quote:
A Man Eating Duck Last edited by tebasuna51; 6th August 2015 at 10:23. Reason: code -> quote |
9th August 2015, 15:58 | #4618 | Link |
2570 [HD Streams Extractor] improved language & name detection 2569 improved internal language handling 2568 [Muxer] removed FFmpeg Muxer from the muxer menu (regression of 2546) 2567 [Log] added Windows 10 support |
9th August 2015, 23:37 | #4619 | Link |
Perhaps the avisynth_plugins directory should be moved out of the protected Program Files directory? You can't extract to it, and since right-click doesn't have an "open as administrator" option for Notepad you can't even easily edit an avsi in it.
I put it in my user directory and made a symlink back. |
11th August 2015, 18:55 | #4620 | Link | |
LoadPlugin: unable to load "C:\Program Files (x86)\AviSynth\plugins\KNLMeansCL.dll", Proc not found. Update library version? |
