19th August 2020, 17:43 | #7621 | Link |
@beter
Thanks. Updated in r5431.
20th August 2020, 12:00 | #7623 | Link |
You can delete it self.
20th August 2020, 22:34 | #7624 | Link |
Requests/suggestions
Under Options > Player
I certainly have more important things to note, but I will experiment seeing the result of these ones first. And than you for the program, regardless of its characteristics being one way or another. Last edited by TheP; 1st September 2020 at 10:46. |
22nd August 2020, 21:22 | #7625 | Link | |
pretty sure it's not worth the dev time to fix this for a very lower number of files. maybe don't accept a DXVA2 incompatible colorspace when the stream is interlaced EVR doesn't accept P210 and get's YUY2 which works just fine. |
23rd August 2020, 06:34 | #7626 | Link |
MPC-BE 1.5.5 (build 5433) stable (SF.net) with digital signature.
MPC-BE Nightly builds: main file store, alternative 1, alternative 2 Also new and old versions can be found on VideoHelp.com. |
24th August 2020, 18:53 | #7630 | Link | |
To register a DirectShow filter in the system, use the following command: Code:
regsvr32.exe filter_file_name.ax
24th August 2020, 22:17 | #7631 | Link | ||
Small requests for mpc-vr: - can you modify the color of statistic from white to e.g. grey? - can you add lanczos for chroma upscaling as well? Quote:
Exclusive mode is working fine as well, and switching to it is way more faster than with madvr (also no black screen)! Setting it to 16bit float we can get 10 bit output with d3d11native in FSW and FSE. Really nice! Overall: the player is way more snappier with mpc-vr than with madvr Good job! HDR10 output would be really useful via Win10 API
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 24th August 2020 at 22:20. |
24th August 2020, 23:19 | #7632 | Link |
Can you guys add a configuration entrypoint to MPCVR to open settings through command line?
rundll32.exe mpcvideorenderer.ax,configure example code |
25th August 2020, 04:09 | #7633 | Link | |
Why is this necessary in practice?
@clsid Thank. I'll see.
25th August 2020, 16:02 | #7634 | Link |
great video player
Thanks to all those who worked
AMD Ryzen 1800X- Asus Crosshair VI Hero- Corsair 16GB DDR4 3200MHz- Asus MX27AQ 27- Evga GTX960 4GB- NOCTUA NH-D15- Corsair MP500 480G- CORSAIR CX 80PLUS BRONZE 750W- COOLER MASTER SILENCIO 650 PURE |
25th August 2020, 16:37 | #7636 | Link |
@Fred
1. Reinstall the player. 2. Remove Shaders and Shaders11 folders in %APPDATA%\MPC-BE\ 3. Start the player. 4. All standard shaders will be restored.
25th August 2020, 19:37 | #7637 | Link |
It's blindingly white, especially when font size is large
25th August 2020, 22:05 | #7638 | Link | |
Use the portable version. Inspired by your note, I copied the shaders directories from the program folder to %APPDATA%\MPC-BE\. |
27th August 2020, 14:57 | #7639 | Link | |
Example: foo.mkv foo.srt foo.EN.srt foo.GE.srt Related settings: - settings is saved into "ini" file - Playback -> Default track preference is checked -- Subtitles: en eng - Subtitles: -- Subtitle renderer: internal subtitle renderer -- Auto load paths: .;.\subtitles;.\subs;.\sub;d:\subtitles;d:\subtitles\series -- Prefer external subtitles over embedded subtitles is checked So, the external "foo.EN.srt" subtitle should be selected by default. Note, I use Lav splitter and Lav audio/video decoders. Edit: b5347 works fine.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 28th August 2020 at 13:20. |
29th August 2020, 08:13 | #7640 | Link | |
