Old 25th November 2018, 18:35   #361  |  Link
TTide
TTide KEYDB.cfg
TTide KEYDB.cfg
TTide is offline   Reply With Quote
Old 27th November 2018, 20:56   #362  |  Link
jcg
New user here, and trying to get FindVUK synchronize.bat to work and getting the error below. Any ideas?
11:35:44 - ----------- FindVUK 1.22 -----------
To close FindVUK simply press the ESC key
11:35:44 - Parameters detected
11:35:44 - SettingsFile: >C:\Users\jgiguere\Desktop\FindVUK_1.22\config\FindVUK.ini<
11:35:44 - Open Main-KEYDB file: >C:\Users\jgiguere\AppData\Roaming\aacs\KEYDB.cfg<
11:35:44 - Open Backup-KEYDB file: >C:\Users\jgiguere\Desktop\FindVUK_1.22\VUKbackup\KEYDB.cfg<
11:35:44 - Synchronize with OnlineDB
11:35:44 - DownloadURL >http://fvonline-db.bplaced.net/fv_download.php<
11:35:44 - MainKeyDB >C:\Users\jgiguere\AppData\Roaming\aacs\<
11:35:44 - Language >eng<
11:35:44 - BackupMode >1<
11:35:44 - BackupFolder>C:\Users\jgiguere\Desktop\FindVUK_1.22\OnlineDB_Backup\<
11:35:44 - Downloading OnlineDB - Progress: 0 bytes
11:35:45 - Downloading OnlineDB - Progress: 43351 bytes
11:35:45 - Downloading OnlineDB - Progress: 230231 bytes
11:35:46 - Downloading OnlineDB - Progress: 790871 bytes
11:35:46 - Finished download of OnlineDB - received 3487446 bytes
11:35:49 - ERROR! GetDifference failed!
11:35:49 - ERROR! Synchronize failed! >-904<
Please press ENTER or ESC to exit
jcg is offline   Reply With Quote
Old 28th November 2018, 11:40   #363  |  Link
nalor
I think there are problems parsing your local keydb.cfg file - can you upload it somewhere and send me the link so that I can take a look at it?
Already improved the output for this error for the next release ...
Old 28th November 2018, 19:19   #364  |  Link
jcg
I believe my keydb.cfg file came from my initial install of FindVUk 1.20.
http://s000.tinyupload.com/?file_id=...56886526893162
Old 28th November 2018, 21:19   #365  |  Link
nalor
Originally Posted by TTide View Post
Analyzed your file and it contains ~28600 duplicates - I've no idea how this could happen at all.
It starts with:
; ####### FindVUK Synchronisation 2018.11.12 22:02:42 ########
0x8B2AF38681441C28A5871A7173A97A88EDB202DC = _NONAME_ | D | 2010-01-19 | V | 0xFC2BAC8F3AEB930DEC3B084DFB265717 | M | 0x97DE4C42E30E7659345B262AE770ACC3 | I | 0x01AE5F2D3F12DDB88DDFE2A181E00780 ; (LEGACY) (NOTVALIDATED) (BD)
0x0000000000000000000000000000000000000000 = _NONAME_ | V | 0xE2E6AF276384A5DBE5E4C996498CE975 ; libaacs (LEGACY) (NOTVALIDATED) (BD)
and the section ends in line 28672, next there's another sync you#ve done and finally a full copy of the first sync appears? Really strange ....
0xDD88EF86119409B8A7BFCA81982372AC0A366318 = 70S SHOW A XXX PARODY ( '70S SHOW) | D | 2009-10-02 | V | 0xA7C2CF84E036D1E5F6DF70F7621D2152 | M | 0xDD183F94B1341D3DDCC6274D723F7406 | I | 0xB14ED8644DAB4BE7CBDFCC0DA36C36C6 ; (LEGACY) (NOTVALIDATED) (BD)
; ####### FindVUK Synchronisation 2018.11.13 12:12:35 ########
0xEFBD5BD1B3A1C10184899C37966FEEAF6D3725EA = Deadpool (Deadpool) | D | 2016-04-08 | V | 0x2407CC815BD562B78F328D6E6D863EE7 | U | 1-0xBCAA3F4D12BC9CA15B8BB4643B40C1C1 | 2-0x572F8FBCB8A9D3C69589FEA5110E83F0 | 3-0xE3C4F63B4634046A010ED2C9D3F9F854 | 4-0x945CCE49A17324B055FAA5D694E2F031 | 5-0x32422BFB669F3ADB1BA5B7D2C187B0CE | 6-0x3CA02AA85AE7C64ABC699E04F3B116A5 ; MKBv56/BD+/BEE/FindVUK 1.14 - MainPlaylist: 00800.mpls - VolumeSize: 49885609984 (LEGACY) (NOTVALIDATED) (BD)
Either you wait until it finishes deleting the duplicates (well - will take some time...) or you remove this 2nd section with the duplicates manually.
Old 28th November 2018, 21:23   #366  |  Link
nalor
Your file is working fine for me - so for the moment I'm clueless ...
In case there aren't any special entries in your file please try to delete it - findvuk will create a new entry with the entries of the online-database.
Next check if the synchronisation is working now.
Old 28th November 2018, 22:07   #367  |  Link
jcg
OK so I deleted the .cfg file and reran "findVUK - Synchronize.bat", and it worked fine. So a couple other questions:
- I downloaded the program so that I can use process monitor to find the correct playlist for obfuscated new releases. I assume a brand new release can't be played with VLC until I run findVUK and it updates the .cfg file. Is that correct?
- So assuming that's correct will FinkVUK work with DVDFab Passkey Lite? Or do I need to install the full version of DVDFab?
- Lastly will FindVUK actually find the unit keys on newly released obfuscated discs so that VLC can play them correctly?
Old 29th November 2018, 21:16   #368  |  Link
nalor
1) you always need an updated keydb.cfg file to play new files - you can either wait until someone else uploaded the required keys into the online-datebase or get them yourself with findvuk.
2) I think passkey lite is only working for dvds and very old blurays? So imho it's not enough... but usually it's always possible to find some free promotional licences in the net that are valid for usually 1 year.
3) from my personal experience dvdfab is very fast with support for new titles - so usually you get unit keys for new discs very fast.
Old 6th December 2018, 23:11   #369  |  Link
panoptika
I posted some VUKs to the "BR VUK-Thread", because the upload fails everytime after extracting the VUK by VUKFind.
Where can I find a current list of VUKs? The reason for my question: The latest update of keydb.cfg at https://vlc-bluray.whoknowsmy.name/ was in March.
thx
pano!
panoptika is offline   Reply With Quote
Old 7th December 2018, 06:03   #370  |  Link
nalor
Which version of findvuk do you use?
I think your problems come from a really old version.
Starbuck stopped his online database a while ago and since a few versions findvuk supports a different online database.
Gesendet von meinem H8324 mit Tapatalk
Old 7th December 2018, 17:14   #371  |  Link
panoptika
I use version 1.22 release - 20181124
Old 7th December 2018, 19:17   #372  |  Link
nalor
In this case there shouldn't be an error during upload.
Please post your log file to analyze the problem.
Does the synchronize feature work?
Old 23rd December 2018, 09:43   #373  |  Link
nalor
I've changed a few things for the processing of entries in the online-db during the last couple of days:
  1. the onlinedb uses a mysql database - change all tables to the innodb engine to allow transaction handling, next I disabled autocommit for everything and added commits where necessary. In case someone notices something strange during upload or so just tell me and I'll investigate
  2. in the past the keyb_<lang> files where always created after processing all newly uploaded entries - changed this to creation on demand. so the file for a specific language is only created when a) someone requests it and b) the file is outdated.
  3. all 'BlurayMetaXML' entries are archived into a zip file - in the past new entries were added during processing of newly uploaded entries, also changed it to add files when someone requests the archive.
Please note that the entries inside the zip file include all unprocessed entries as uploaded from FindVUK, those entries also include the small errors I've introduced and removed over time ... so the zip is really of no big use for the common user
Just in case you're still interested or already used the archive previously, heres the link for the archive-file :
Online DB - BlurayMeta Archive
I've changed the way the keydb download is processed on 2018-12-14 and also introduced a small logging so that I can see which languages are requested how often ... I can see that only ENG and DEU are requested at the moment and that ENG with 147 downloads during the last 9 days are the clear winner against DEU with 20 downloads.
In case someone needs the download url here it is (basically it's also visible in the configuration of findvuk - but download might also be interesting for readers not using findvuk:
KEYDB.CFG - ENG
KEYDB.CFG - DEU
You can change the 'lang' parameter to any language you want - in case no entries for the requested language are in the database you always get english as fallback.
Small note: no ip addresses or related informations are stored by my scripts! Only the language and the time are written to a small table.
During the next days I'll integrate the processing of BlurayMetaXML uploads into the upload - so that new entries are immediatly written to the database without the need to wait until I process again.
Once this is done I'll check if the same is also possible for LegacyUploads (those that come from the synchronization) - problem here: processing can take much longer ....
And finally I'll create a homepage for the online db
Old 28th December 2018, 11:42   #374  |  Link
nalor
Hello!
On 20th of december after 7pm someone submitted details about the movie 'My Neighbor Totoro' - interestingly with 2 different volume names and also different dates of the discid.
Would be great if the user who submitted this disc could send me a message so we can find an explanation of this strange things.
Thanks!
Old 28th December 2018, 18:27   #375  |  Link
Mr Wolf
Mr Wolf's Avatar
Hi!
I've just tried FindVUK for the first time and it worked like a charm.
The only little issue I had is that the ProcDump file it downloaded didn't work. I'm using a 32 bit Windows 7 virtual machine and it said it was not a valid 32 bit application. Can't say if it was only my problem or not.
I solved copying the ProcDump file I already had.
By the way, with VLC 3.0.5 I couldn't play blu-rays anymore.
Had to switch back to VLC 3.0.4.
P.S. The random question asked to post a message here is quite "annoying".
Mr Wolf is offline   Reply With Quote
Old 28th December 2018, 23:35   #376  |  Link
nalor
Originally Posted by Mr Wolf View Post
Hi!
Can you send me the logfile of the failed attempt to download procdump?
thanks!
ps: I think the random question is only asked until you reach a higher number of posts.
Old 3rd January 2019, 20:39   #377  |  Link
nalor
Fixed for next release.
Old 3rd January 2019, 21:48   #378  |  Link
Mr Wolf
Mr Wolf's Avatar
Thanks! I wasn't sure you received my PM.
By the way, is there a KEYDB.cfg database available, were all the keys found by FindVUK are uploaded?
Is there any problem to share my KEYDB.cfg on the forums? (for copyright reasons, I mean)
Old 10th January 2019, 02:38   #379  |  Link
MasterMeNL
During part one there is the "Get basic AACS data" step. It prints out "AACS folder on disc is reachable - ValidateVUK is possible" and then the entire drive freezes. I have a 2011 SH-B123L. I noted that trying to copy MKB_RO.inf or MKB_RW.inf manually from the AACS folder causes the drive to lock up completely too, requiring Windows 10 to reboot. When running Linux on the same hardware copying these files works fine, but of course FindVUK does not work there. I have tried setting PauseBeforeValidateVUK to 1 but this did not change anything.
DVDFab itself can rip properly without locking up the drive, so I suspect the validation is causing issues. Could you add an option to disable/skip validation even if the AACS folder exists? Or is there something else I could try?
MasterMeNL is offline   Reply With Quote
Old 10th January 2019, 15:40   #380  |  Link
nalor
Basically it sounds like a problem with your system when it's not even possible to copy those files with windows explorer.
Honestly I don't know how I can help in this case.
Maybe try to use a virtual windows with access to your drive? And see if you can copy the files there?
