#8321 | Link | |
If so, it doesn't help. In my screenshots there is no GPU icon in toolbar, so software decoding is used anyway, but with EVR cp and madVR the HW deinterlacer of the Nvidia gets triggered, but not in MPC VR. ![]() Would that be an option? |
#8322 | Link |
Disable in the decoder all formats that are not supported by your video card when using DXVA2 VP and D3D11 VP.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source |
#8323 | Link |
OK, thanks, I think I understand it now. I disabled "P210" (10-bit), then it displayed "P216" (16-bit) and deinterlacer didn't work either. Then I disabled "P216" and then it displayed YUY2 (8-bit) and deinterlacer works now.
In EVR cp it always shows YUY2. I think it converts P210 automatically to YUY2. This P210 is also very rare. I doubt this recording was broadcasted in 1920x1080 - 4:2:2 - 10 bit, was it? User who created it probably used an external recorder and set it up this way. Anyway. Thank you for clarifying and helping me to understand that issue. ![]() |
#8324 | Link | |
PS: I've been shown this file before and my solution remains the same. I have no plans to add a dedicated convector to MPC VR to support this file. I have many other more urgent tasks.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source Last edited by v0lt; 5th March 2021 at 18:46. |
#8326 | Link |
Actually satellite broadcasts are sometimes in such a format, but they are not meant for users but between distribution studios which then get re-broadcast in typical user formats.
#8328 | Link | |
And do not forget that an ordinary user does not have such interlaced files (only one person on the Internet forces this file). It is not possible to reliably identify interleaved or progressive video by media type. Many decoders issue the same dwInterlaceFlags for both cases.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source Last edited by v0lt; 6th March 2021 at 05:29. |
#8329 | Link | |
#8330 | Link | |
Why would anyone re-encode a digital signal in a recorder instead of just capturing it as-is? There is always a quality loss involved with that otherwise.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 6th March 2021 at 11:05. |
#8331 | Link |
People do weird things:
Example: There were people who played a DVD-Video in a standalone DVD-player and captured them over analog video. ![]() How is this accomplished to get such satellite streams? I can imagine that there is quite expensive hardware required, is it? |
#8332 | Link | |||
I tested it for 9 month and I still want it an option for it: Could you add a checkbox in last page in options so the user has the option to show full path of recent played files (rightclick on eject button). I really would like to have it back. It does not have to be default, no, but the option would be very nice to have. I really beg for it. It is important for me ![]() Checkbox could be called "Show full path in recent played files" default is unchecked and the user can check it if s(he) wants. |
#8333 | Link | |
I know quite expensive set-top-box receiver Azbox can receive and show 4:2:2 directly (without LAN translation to device with 4:2:2 decoder - MPEG2 100% can but may be H264 can't - btw now I sometimes watch H265 4K 4:2:2 feeds like 20180428-175510_4K ENC 3 RMAD VS LEG.ts (563 MB) https://disk.yandex.ru/d/m0s5ztpj3XnUyw as slideshow because there isn't hardware acceleration and my Athlon II x3 460 can decode just about 7 fps). Last edited by VictorLS; 7th March 2021 at 00:59. |
#8334 | Link |
In VLC player there is a preload buffer which I can adjust. The buffer allows not to read a file from a hard drive in real time, but to use this buffer before actually playing. This allows to have no interruptions while watching, for example due to high load of HDD from other software. Is there such feature in this player?
В плеере VLC есть функция "буфера предзагрузки видео", которая позволяет загружать видео в буфер в определённом объёме, прежде чем я по факту посмотрю этот фрагмент. Это помогает например в случаях когда другое ПО нагружает HDD и видео при просмотре прерывается и дёргается. Буфер помогает этого избежать. Если ли в этом плеере такая функция? Не смог найти. Last edited by XoJIogHbIu; 12th March 2021 at 15:30. |
#8337 | Link |
LAV Filters:
https://files.1f0.de/lavf/nightly/ https://forum.doom9.org/showthread.php?t=156191 It is a dedicated project which can be used as external filters in MPC-BE if you want. |
#8338 | Link |
Something Else
Maybe someone can help me with this annoying problem. I do not know if this is a bug with MPC-BE but when I play SDR material MPC-BE autochanges to the correct refresh rates I configured in the Fullscreen menu but not when playing HDR material. I have tested this with MPCVR as well as MadVR since they are the only renderers that allow HDR and the effect neither of them autochange to the correct refresh rate.
Selecting "Change display mode before starting playback" outright does not work and affect SDR as well as HDR. If anyone can help me with my problem, it will be much appreciated? Cheers |
#8340 | Link |
In LAV it is called "Queue Size". You'll find it in the Splitter app and don't forget to set the LAV filters as "prefered" in BE-options.
